1. Zman06's Avatar
    Hi Everyone,
    I'm new to the Verizon Galaxy Nexus. I just rooted my phone using the Galaxy Nexus Toolkit. The rooting seems to have gone through properly. I have now tried to root the phone 3 times. I do have super user installed, but when I go into fastboot, and then into recovery mode I'm unable to get access to the CWM menu screen to install the ROM that I want to try.
    What I get on my phone's screen is a picture of the android laying on his back with his chest open, and a red explanation mark inside of a triangle.
    It someone can please let me know what I need to do next in order to move forward with installing ROM's that would be great.
    Thank you,
    12-29-2012 07:24 PM
  2. estods3's Avatar
    That's an easy one. Download ROM manager from the play store. Open the app then click on "flash clockwork mod recovery" then click on Google galaxy nexus (Verizon) and then "flash clockwork mod recovery" at the bottom of the screen. The triangle android is Verizon's fault they put that there to stop us. Do the steps I told u each time you wanna go into recovery its your best bet.
    sent from my Verizon galaxy nexus running 4.2.1 ROM
    12-30-2012 09:32 AM
  3. estods3's Avatar
    Here are some screen shots if you need them
    Attached Thumbnails Newbie- Needs Help!-uploadfromtaptalk1356881563799.jpg   Newbie- Needs Help!-uploadfromtaptalk1356881574558.jpg
    12-30-2012 09:33 AM
  4. oxymoron's Avatar
    Or... you could just delete or rename the recovery-from-boot.p file from your /system folder.
    12-30-2012 11:35 AM
  1. Newbie needing help
    By mgindi26 in forum Verizon Fascinate
    Last Post: 01-20-2011, 08:05 PM
  2. Hi! newbie needs help!
    By Sidney Law in forum Introductions
    Last Post: 01-20-2011, 10:27 AM
  3. newbie need help
    By sethlamb in forum Verizon Droid Incredible
    Last Post: 09-04-2010, 12:37 PM
  4. Newbie needs help with contacts
    By muddy13 in forum General Help and How To
    Last Post: 08-10-2010, 08:39 PM
  5. Newbie needs help with Calendars
    By bunjy in forum General Help and How To
    Last Post: 08-06-2010, 09:15 PM
