Results 1 to 3 of 3
    TabGuy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How do I use an OTG cable?
    I bought a new OTG cable for my Nexus (I am using Euroskank's AOKP ROM). When I plug in the cable with a thumb drive attached I see a message recognizing the external USB drive in the notification area. When unplug it I see a similar notification telling me it's unplugged. However, when it's plugged in I can't figure out how to see what's on the thumb drive. I go into file manager and don't see it show up there at all. What's the trick to exploring the information on the thumb drive?
  2. #2
    oxymoron's Avatar
    It's been real...
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  3. #3
    Nechasin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Something new!
    Default Re: How do I use an OTG cable?
    I use Eurostanks CM10 so you may be little different. Since it is recoginizing the drive when you insert and pull it, I don't think you need stickmount. On my GN, when I plug in my drive, it tells me preparing USB Storage. My onboard storage is located at /root/sdcard or /root/storage/sdcard0. my usb storage is located at /root/usbdisk or /root/storage/usbdisk
    goodluck
    oxymoron likes this.
  1. How do I use a Nexus 4 on an existing AT&T connection?
    By Rishabh Singh in forum Google Nexus 4
    Last Post: 12-25-2012, 11:49 PM
  2. How do I use OTG cable to access SD Card?
    By dougltc in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-20-2012, 04:00 PM
  3. How do I add an accoutn to use Microsoft active sync
    By rdefino in forum General Help and How To
    Last Post: 10-06-2011, 09:13 PM
  4. Added an sd card. How do I use it?
    By rosariorose9 in forum Verizon Droid Incredible
    Last Post: 05-23-2010, 09:43 AM
  5. How do I use folders?
    By macjazzy in forum Verizon Droid Incredible
    Last Post: 05-08-2010, 11:24 AM
