Page 5 of 5 FirstFirst ... 2345
Results 101 to 111 of 111
Like Tree27Likes
  1. #101
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    ROM
    JB Viciousness
    Default Re: [GUIDE] Return to Stock: Factory Images for the VZW Galaxy Nexus
    dm, can you update with download link to the new 4.1.2 image?
  2. Thread Author  Thread Author    #102
    dmmarck's Avatar
    Retired Moderator
    Posts
    Global Posts
    10,930 Global Posts
    ROM
    What do you think?
    Quote Originally Posted by nycinek View Post
    If it's out for Verizon, yes. I'll get to it tomorrow.
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    Thanked by:
  3. #103
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by dmmarck View Post
    I don't believe it is anyways..
    EDIT: just checked and it is not
    Thanked by:
  4. Thread Author  Thread Author    #104
    dmmarck's Avatar
    Retired Moderator
    Posts
    Global Posts
    10,930 Global Posts
    ROM
    What do you think?
    Quote Originally Posted by 2defmouze View Post
    Yup. We would have known b/c it would have been an OTA. It's ok, we'll get that OTA in a few months
    2defmouze and ekinnyc like this.
  5. #105
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    7,047 Global Posts
    ROM
    BB JB
    ok..mouze was trying to help me out.
    I screwed my device up.
    I am up and running and verizon updated it's software.
    So now I have unlocked bootloader with 4.1.1 from verizon but lost root.
    Can't use wugs because it says no fastboot device found.
    I need help because I can't even enter the bootloader to flash su.zip. I get the red triangle with ! in the middle.
  6. #106
    sniff sniff had to do this today for my Galaxy Nexus. Alas it did not survive the drop from my pocket to the ground in subway and had to be replaced. At least I have a shiny new Galaxy S3....
  7. #107
    Selling my toro and this was excellent for getting back to stock. Thanks dmm
  8. #108
    DroidXcon's Avatar
    Posts
    Global Posts
    11,775 Global Posts
    ROM
    Stock for now
    Hey guys, ok so i get to this command
    [CMD]fastboot-windows w update image-mysid-jro03o.zip[/CMD]
    then under it says
    usage: fastboot []
    and gives me a list of commands and options:
    im sure its something obvious that im doing wrong , any help appreciated, thanks
    Edit-
    Nevermind found my answer. Thanks anyway
    If i've made life easier buy me a Macchiato
  9. #109
    Quote Originally Posted by DroidXcon View Post
    then under it says
    usage: fastboot []
    Edit-
    I had that same exact problem and I was copying and pasting the command. When I typed it in, boom it went through. Strange.
    Sent from my mako ()
  10. #110
    nevermind
    I voided my warranty.
  11. Thread Author  Thread Author    #111
    dmmarck's Avatar
    Retired Moderator
    Posts
    Global Posts
    10,930 Global Posts
    ROM
    What do you think?
    then under it says
    usage: fastboot []
    Edit-
    I know it's a bit late, but that one must always be typed out manually, not copied and pasted.
