- 01-04-2012, 07:37 AM #251
Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
yes, other other devices androind 1.0 is there. i cannot update the driver no matter what i try! i will a usb in the back of the computer. i just tried a different computer, followed the instructions EXTACTLY and the same thing happened-- the computer does not recognize it. amazing!!!!!!!
- 01-04-2012, 09:04 AM #252
- 01-04-2012, 10:05 AM #253
- 01-04-2012, 10:11 AM #254
Follow the instructions in this link: [Guide] How To Backup, Restore & Install ROMs on The Galaxy Nexus
- 01-04-2012, 10:27 AM #255
- 01-07-2012, 02:28 PM #256
I am having the same problem you did. My computer can't find the drivers. When i select samsung phone in the device manager it says there are no drivers. Can you give a step by step because I'm not exactly sure which drivers to use or the file to pull them from.
Thanks for any help. - 01-12-2012, 12:37 PM #257
- 01-12-2012, 12:54 PM #258
- 01-12-2012, 01:24 PM #259
Sorry but I can't find the links for CDMA or GSM on the first post I am using the following link
http://http://forums.androidcentral....axy-nexus.html
My nexus will be the CDMA platform - 01-12-2012, 01:31 PM #260Thanked by:
- 01-12-2012, 02:19 PM #261
- 01-13-2012, 07:03 PM #262
- 01-18-2012, 05:25 PM #263
It honestly took me 4 or 5 tries maybe even more before I could get it to work. Not sure why and normally I would have given up but I was dfetermined to get it working.
I never did anything different just kept downloading and waiting, the downloads took forever for me.
Eventually it worked.
Im sorry I cant give you any technical reason or fix but this worked for me LOL - 01-19-2012, 05:34 AM #264
Just got my galaxy nexus today (16GB Telstra Australia) and rooted using the procedure here.
It was the easiest root ever! no problems at all and only a 2 minute wait to re-boot after the root.
No looping whatsoever, I almost couldn't believe it as I usually run into all sorts of problems with my past devices during rooting and I was expecting the same on this one. I'm glad it was smooth and stress free...thanks guys for the instructions and all your valuable inputs.
I just have one last thing in mind...
I saw a couple of earlier unanswered questions on this thread implying that Official OTA Updates will still work despite the root process we just did....Is this true??
Reason I ask is that I have read elsewhere that rooted GN owners have soft bricked their devices and had all sorts of drama with their phones after trying to install the official 4.0.2 OTA update..
..so that just confused me a bit. Will an official OTA update work after this root or are we gonna be forced to re-lock and unroot just to be able to get those official OTA updates to work?
That's the last thing I am not clear about so I hope anyone who knows for sure, or have tried it can share their accurate experience/answer.
Thanks! - 01-21-2012, 01:29 PM #265
- 01-21-2012, 01:54 PM #266
I followed the instructions. They worked perfectly. However, when the GN rebooted, it was _not_ rooted. Apparently the procedure did not wipe, since all the apps I had previously installed remained. Should I return to the bootloader and do a full wipe?
How can I be sure the phone is unlocked? - 01-21-2012, 02:00 PM #267
- 01-21-2012, 08:10 PM #268
- 01-22-2012, 06:01 AM #269
Hey guys, I'm running into some issues trying to unlock the bootloader. I keep getting "waiting for device" on my last command in Command Prompt. I decided to reinstall all the drivers and I noticed that when installing the Samsung driver v1.4.6.0 that I get:
SAMSUNG Mobile USB Composite Device: Ready to use
SAMSUNG Mobile MTP Device: Failed
SAMSUNG Android ADB Interface: Ready to use
I've tried downloading from different sources and Samsung with no help. Anyone got any advice? Thanks. - 01-22-2012, 05:58 PM #270
It looks like I can't install superboot. When I click the link it says:
All sharing functionality on FileSonic is now disabled. Our service can only be used to upload and retrieve files that you have uploaded personally.
If this file belongs to you, please login to download it directly from your file manager.
So I don't know what's going on. Maybe I should just unlock my GNex first then try and get root later. - 01-23-2012, 10:30 AM #271
Link for super boot not working. Anybody want to send it to me via db
Sent from my Galaxy Nexus using Tapatalk - 01-23-2012, 10:42 AM #272
- 01-23-2012, 10:57 AM #273
SGSIII : White 32 gb model with 32 gb sdcard
RoM : CleanRom 5.5.1_ jb
Kernel : n/a - 01-23-2012, 10:59 AM #274
- 01-23-2012, 11:12 AM #275
It looks complicated and drove me nuts but it worked unlocking the bootloader using sdk tools.
all you need then are the samsung drivers and the google drivers for it.
Reply
