- 06-21-2012, 08:36 AM #326
Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
Ok, just had to restore back to stock to see if it fixed a DRM issue in Hulu+ but I wanted to keep root. Problem is, I have no busybox, can't install it using Superuser (can't gain root). Is it due to the 4.0.4 update?
- 06-28-2012, 11:04 PM #327
just used this method unlock worked perfectly, I cant seem to gain root though. 4.0.4
Devices: Galaxy Nexus and Nexus 7 - 06-28-2012, 11:07 PM
Thread Author #328
Former moderator & advisor.
HTC - the One to rule them all.
- 06-28-2012, 11:31 PM #329
thank you good sir! you have been most helpful wugs tool worked perfectly !
Devices: Galaxy Nexus and Nexus 7 - 06-28-2012, 11:34 PM
Thread Author #330
Glad to hear it
- 06-29-2012, 11:24 AM #331
OK, here's my issue. I rooted on 4.0.4, have the Super User app but keep getting an "Error occurred while attempting to run privileged commands" in ClockworkMod. I assume SU permissions aren't being granted properly.. I see there's a 4.0.4 zip for updated SU permissions and to flash it from recovery, but how can I do that if I dont have clockwork mod flashed?
- 06-29-2012, 04:22 PM #332
- 06-30-2012, 05:47 PM #333
[INFO]Guide updated for rooting the 4.04 update[/INFO]
- 06-30-2012, 08:26 PM #334
What is the average length of time it should take for the phone to reboot after being rooted?
Sent from my Verizon Galaxy Note 2, Verizon Galaxy S3, or N7, or MacBook Air - 06-30-2012, 09:00 PM #335
I'm not sure what I'm doing wrong here. I have unlocked the bootloader but, so far I've been unable to root the phone. Not sure what I'm missing.
Sent from my Verizon Galaxy Note 2, Verizon Galaxy S3, or N7, or MacBook Air - 07-02-2012, 08:49 AM #336
when i type ''adb reboot bootloader'' into the command prompt i get the standard not a internal command any help on this??
nevermind missed the whole from folder part lolLast edited by Yung_Dilla; 07-02-2012 at 08:54 AM.
- 07-02-2012, 09:00 AM
Thread Author #337
- 07-03-2012, 08:49 AM
Thread Author #338
Greetings, earthlings:
I will be updating both portions of this guide, but mostly the Mac portion in the coming week or so.
That is all
- 07-07-2012, 01:47 PM #339
I had to replace my Galaxy Nexus due to a cracked screen, so I took the opportunity to follow the steps in the first posts to unlock and root the phone.
The unlock part was easy enough, but I had a minor issue with my Win7 Pro laptop loading the device driver and had to do disconnect from the laptop, reboot the phone and do it again. Worked the second time.
The root part also was straightforward after I re-read the instructions six time!
Since everything else was PC based through a command prompt, I was thrown off by the first step to copy SU.ZIP to the phone! I kept looking on my laptop to figure out where I was supposed to save it - DUH!!!! :lol:
After I got it rooted, I still wasn't sure it was rooted, because I kept looking under Security > Device Administrators, thinking something would be listed, but of course I should have looked for the Superuser app in the app drawer. Maybe this would be helpful to have in the instructions so the process can be verified.
Thanks for the instructions - now I'm rooted and I'm off to see what damage I can do.
- 07-14-2012, 08:01 PM #340
- 07-15-2012, 10:32 AM #341
So I had the same issue with the the android on his back and the caution sign above him, and i tried to rename that file with root explorer and I got a messasge saying "recovery-from-boot.p cannot be renamed because the file system is read-only." Any help would be greatly appreciated.
- 07-15-2012, 10:42 AM #342
On top of the screen of the root explorer app you will see a grey box that says "Mount R/W".. You need to switch that to" R/O" so that to the left of the box it will say "mounted as read/write"... Now you should be able to make your changes to the file.. When done switch it back to" mounted as read only"
- 07-16-2012, 03:50 PM #343
Yea, I just figured that out. Noob mistake. Lol. Thanks
- 07-16-2012, 05:32 PM #344
- 07-16-2012, 06:09 PM
Thread Author #345
- 07-16-2012, 06:14 PM #346
- 07-16-2012, 06:15 PM
Thread Author #347
What happens when you tap reboot into recovery?
Sent from my Galaxy Nexus using Android Central Forums - 07-16-2012, 06:18 PM #348
- 07-16-2012, 06:20 PM
Thread Author #349
- 07-16-2012, 06:51 PM #350
So I followed the guide you posted near the end of that thread.
I placed the CWM recovery image in the r3 folder, did the terminal commands, etc.
Was able to use CWM recovery to install the new SU.zip.
Went into rom manager and I was able to flash CWM successfully.
At the end of the guide you posted you said something about renaming a file or something rather? Do I need to do that even though I was able to flash CWM through Rom manager, or am I finally good to go and can start installing my jelly bean goodness? Thanks for the help man, you are truly awesome.
Reply
