- 07-16-2012, 06:53 PM
Thread Author #351
You may need to reflash cwm the same way you did if the file exists. I suggest checking out the link. It's a file within either system or system /lib and it says "recover from" something something.
Or look up "cwm recovery won't stick."
You may not even have it. A quick way to check is trying to go to recovery.
Sent from my Galaxy Nexus using Android Central Forums - 07-16-2012, 06:57 PM #352
- 07-16-2012, 07:04 PM #353
- 07-16-2012, 07:10 PM
Thread Author #354
Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
What file manager do you have? You need to change permissions from "read only" (r/o) to "read and write" (r/w). In ES File Explorer that's in the main settings; in Root Explorer, you should see a little tap-able toggle at the top of the window that says "make r/w."
Delete it, then turn it back to r/o, and you should be good.Former moderator & advisor.
HTC - the One to rule them all.
- 07-16-2012, 07:13 PM #355
- 07-16-2012, 07:15 PM
Thread Author #356
- 07-25-2012, 03:13 PM #357
Is there a new version of CWM available? The original post has a 5.* version... isn't 6.* out now? I have no idea where I go to get new versions of CWM.
- 07-25-2012, 03:24 PM #358
- 07-30-2012, 01:04 PM #359
Had mine rooted before the 4.0.4 update. I lost root, of course. I was still unlocked so just proceeded with the root tool. I've been at the Google lock screen for a good 20 minutes now. When should I start to worry?
Update: tried various things seen in this thread, ended up doing a battery pull. Everything is working fine (or seems to be), but no root. At least I'm not bricked.Last edited by Cowql8er; 07-30-2012 at 01:27 PM.
Galaxy Note II - 07-31-2012, 11:44 PM #360
*INCREDIBLE*MECHA*TORO*GROUPER* GALAXY S3 *
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 08-01-2012, 03:18 AM #361
Hi, first post an the what not.
So followed the initial unlock steps on my GNex just fine, all unlocked (thank you btw). Have 4.0.4 an tried following steps to root that version except when I attempt to boot into recovery mode to flash the suggested SU.zip (which is loaded into device) I get the sad dead android. I get very confused on that whole part as it is. Sorry if I overlooked someone already resolving this, if so, just direct me there. - 08-01-2012, 03:36 AM #362
Recovery isn't sticking, it won't until you root and remove the recovery-from-boot.p file from /system.
To boot into recovery and flash the su.zip just open the terminal as you did before inside the folder with your fastboot file and recovery.img you want to flash, have the phone in bootloader mode and connected. Type:
fastboot boot recovery nameofrecovery.img
And hit enter.
Note to change the nameofrecovery to the exact name of the img, and if the fastboot command needs to be entered slightly different make sure you do (you don't mention what OS you are using).
Also make sure the su.zip is the one for 4.0.4... I believe it's I am the OP or its been posted throughout this thread.
[GUIDE] Nexus 4 - Unlock & Root | [GUIDE] Nexus 4 - Factory Image Restore | [GUIDE] Nexus 7 - Factory Image RestoreNeed a Dropbox? Use this link to sign up and both of us get free bonus space http://db.tt/YOHANuCI - 08-01-2012, 09:09 AM #363
- 08-05-2012, 10:51 AM #364
- 08-09-2012, 04:36 AM #365
I got to step 7. Do I actually need an sdcard, or is does this system option include whatever is downloaded to "Internal Storage." I followed the directions and sent "su.zip" to the root of "Internal Storage."
After making the selection on step 7 I was given another screen of choices. One was to select "update.zip." I went back, then selected it again "install zip from sdcard" again. The options went blank leaving me with only the Clockwork logo in the middle of the screen (the black hat with the arrow).
I'm unsure what to do next. I never actually selected a file. - 08-09-2012, 07:57 AM #366
The option in CWM mentions the sd card, but the GNex doesn't have one. However, the internal memory has some space allocated as an sd card. So this is definitely the option you want to select.
Now, what do you mean by the options went blank? Go back isn't even listed as an option? - 08-09-2012, 09:26 AM
Thread Author #367
I would just try restarting CWM. CWM can do that--it will hang, occasionally.
- 08-14-2012, 10:10 PM #368
- 08-15-2012, 11:01 PM #369
- 08-20-2012, 02:05 PM #370
- 08-20-2012, 02:10 PM #371
How to I do this? Not working tried the superboot install and it never boots up... Gave phone like 20 minutes... Recovery isn't sticking and I'm not sure where to put the clockworkmod.. also when it's "booting" from the superboot it says the driver's aren't installed properly which I know is BS... tips?
- 09-04-2012, 10:56 AM #372
Help! My Galaxy Nexus sudden going through BootLoop (at Google logo).
I have new born baby photos and video that I need to pull them out to my PC.
This is original phone so I bootloader is still LOCKED.
I can not unlock bootloader because it will wipe all my photos.
Please help.
Here is what I have done..
1) Install the drivers (both for fastboot and ADB):
2) Download ClockworkMod 5.5.0.2 for Galaxy Nexus *GSM Edition* to C:\Android and rename it to recovery.img:
3) Download and extract the Android SDK so that I have fastboot.exe and adb.exe to C:\Android:
4) Open a command prompt in C:\Android
5) Turn off your phone and reboot into fastboot mode (vol up + vol down + power) and plug into PC
6) Type: fastboot boot recovery.img
Obviouly .. it complain that
c:\Android>fastboot boot recovery.img
downloading 'boot.img'...
OKAY [ 0.680s]
booting...
FAILED (remote: Bootloader Locked - Use "fastboot oem unlock" to Unlock)
finished. total time: 0.690s
c:\Android>
So my bootloader is LOCKED ..what do I do? I do not want to unlock since it will wipe/lose all my photos/video.
Also, I can get turn on Android Debugger Mode on my Nexus because it is doing the bootloop. Therefore my pc won't regnize adb driver nor adb.exe will not works due to bootloop at Google Logo.
ALSO, I cleared my cashe from recovery mode & then selection,
wipe cache partition
Still same issue.
Yes ... I can get to bootloader and download mode. (combination vol+, vol- + power).
HELP ME..!
Thank you
- 09-16-2012, 11:22 AM #373
- 09-19-2012, 12:40 PM #374
- 09-19-2012, 12:54 PM
Thread Author #375
Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexus
There's an updated zip. Look in my OTA thread in the general forum.
Regarding the links, I'll double check everything. I plan on redoing some stuff, just haven't had the time. For Windows users, I recommend following Jubakuba's guide or using Wug's Toolkit for the time being.Former moderator & advisor.
Reply
