- 12-16-2011, 11:07 AM #26
Re: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexu
Not sure yet, wish I had recovery installed to be able to wipe data that would have worked (maybe). Has to be a work around some where.
here is what i'm trying, I'll let you know if it works
Originally Posted by MBerlowitz5181 View Post
I just ran a system wipe/ recovery using the bootloader menu... back up and running.
All i did was get back into bootloader by holding both VOL up and VOL down then power. once in, i went used vol down to scroll to recover, and then used power to accept. after it ran (5 minutes) it booted fine! - 12-16-2011, 11:09 AM #27
I'm the ROOT man
G Talk: Upstreammiami3o5Let me help you ROOT your phone - 12-16-2011, 11:11 AM #28
are you kidding me? did we soft brick our phones? that sux what now? cyber going to put up some instructions?
- 12-16-2011, 11:16 AM #29
- 12-16-2011, 11:20 AM #30Thanked by:
- 12-16-2011, 11:24 AM #31
Never messed with ADB until today. Easy as pie. Unlocked and Rooted!!
- 12-16-2011, 11:24 AM #32
Mine was sitting at the google screen for a serious 15 minutes. I pulled the battery, booted up just fine and super user is working correctly. Installed Rom Manager and flashed Clockwork. Idk why you guys are getting boot loops. Maybe I got lucky?? Idk 15 minutes should be more than enough time to load the system images back up. To fix the soft boot wouldn't you just go to the stock recovery and delete data/factory reset?? I mean that's what I would do...
- 12-16-2011, 11:27 AM #33
ok so i've got a android guy on his back with a red triangle coming out of his stomach did i brick my phone?
- 12-16-2011, 11:28 AM #34
i get bootloop at google screen
I'm the ROOT man
G Talk: Upstreammiami3o5Let me help you ROOT your phone - 12-16-2011, 11:30 AM #35
- 12-16-2011, 11:32 AM #36
I'm the ROOT man
G Talk: Upstreammiami3o5Let me help you ROOT your phone - 12-16-2011, 11:33 AM #37
well i'm between google and the spash screen in between keeps saying android upgrading but its been doing it for over a half hour now, sure hope i didnt do anything to the phone just keeps looping between those two screens
- 12-16-2011, 11:33 AM #38
If you think someone is being rude its probably because you miss understood them. - 12-16-2011, 11:36 AM #39
- 12-16-2011, 11:37 AM #40
- 12-16-2011, 11:39 AM #41
- 12-16-2011, 11:40 AM #42
ok ty i'll keep refreshing this page for any new good news lol
- 12-16-2011, 11:51 AM #43
- 12-16-2011, 11:54 AM #44
ok guys this is what i did and it worked!! i went back to recovery and wiped data and cache, rebooted the phone and its fine now
- 12-16-2011, 11:56 AM #45
And for a question of my own. If i used this method to unlock the bootloader only, can I just skip to step 14 to root the phone or do I need to use another method to get root.
Was this answered? I have the bootloader unlocked but not rooted yet? - 12-16-2011, 11:57 AM #46
When I go into recovery I don't have any options to wipe or any other options
- 12-16-2011, 12:02 PM #47
If you are brave try this:
From the command prompt pointing to the folder with fastboot.exe, adb.exe and stock images:
Exact commands:
adb reboot bootloader
Gnex will then reboot into bootloader screen
fastboot flash boot boot.img
fastboot flash system system.img
fastboot flash recovery recovery.img
fastboot flash userdata userdata.img
fastboot erase cache
fastboot oem lock
Use volume rocker to select ok and then Gnex will reboot.
You are now stock, locked and unrooted.
Kanged from Steady Hawkin.
The four files (boot, system, recovery, userdata) are located in the image-mysid-icl53f.zip after downloading from Google. Unzip them and place in folder that fastboot.exe is located in.
It also contaings a "flash-all.sh" which will allow you to flash them all with one command.
Command is in this thread as well as link to stock images: http://forums.androidcentral.com/ver...axy-nexus.htmlIf you think someone is being rude its probably because you miss understood them. - 12-16-2011, 12:09 PM #48
its very easy guys if its done the way i did it, i'm just trying to remember how i went to recovery and was able to pull up the wipe data screen
- 12-16-2011, 12:10 PM #49
Here is how I fixed my loop - I just locked the bootloader up and then followed the guide again and without pulling the battery this time it worked. Miami let me know if your still having issues.
- 12-16-2011, 12:10 PM #50
So first install the samsung drivers,then install the usb drivers too .
Then I make sure there are no errors in device manager with phone hook up to computer with USB ticked on phone.So it looks like the picture in the link (samsung drivers first link in OP)
After that is all checked out download superboot and follow the pictures and instructions til completed.Steps 1-15. I think I m correct on all that ,lol
I have 2 question more
I already did the update yesterday so I am on Androd version 4.0.2 so has anyone use this method while on 4.0.2? This one of my biggest concerns Im not sure of.
Also I may wait and see how everyone is getting out of the bootloop some are having ,I see what some did to get out of the bootloop ,but also see others dont have the same options to use (ex:wiped data and cache)
edit: ok I see some more posts since I started tying about bootloop question have been postedSGSIII : White 32 gb model with 32 gb sdcard
RoM : CleanRom 5.5.1_ jb
Kernel : n/a
Reply
