- 12-16-2011, 07:54 PM
Thread Author #1
Stuck in ODIN mode!
I tried to flash a mod for fixing the poor auto-brightness and once i rebooted I encountered numerous force closes to the point where the phone would lock up and a battery pull was required. Prior to the flash I did a nandroid backup through Clockwork Mod. After the battery pull I held volume down and power to get into recovery, however I get stuck in ODIN mode and can not access recovery. I tried ADB to push the stock images or to reboot into recovery and it says a device cannot be found. Starting to panic a little, however I think/hope this is just a soft brick issue. If ANYONE can give me a little advice it would be GREATLY APPRECIATED!!! thank you all!!
- 12-16-2011, 09:17 PM #2
Re: Stuck in ODIN mode!!!!
When it gets to the point where adb says device not found, you need to go into your windows control panel and add a driver for the device under 'other devices'. i think it shows up as like Android1. Choose update driver and 'let me specify the driver to install' scroll down to Samsung Android phone or similar and install that. Try adb again. GL.
- 12-16-2011, 09:40 PM
Thread Author #3
Thank you for the reply. I actually just figured it out and was coming back here to share my results: After numerous tries I was able to get ADB to reboot into recovery. If you get stuck in ODIN, reboot the phone while connected to your PC. If you are able to get past the boot animation, do not try to unlock your home screen if you previously experienced numerous force closes. Allow the phone to get to your lock screen and then use adb to reboot bootloader. From there you can get into recovery. I'm sure this is probably a well known thing, but coming from the original DINC, I never had to use adb. This was a lot of stress and eventually a huge sigh of relief once I figured it out.
- 12-17-2011, 05:59 PM #4
The process for getting into the bootloader is actually different on the GNex.
You have to hold BOTH volume buttons down and then the power button.vanquish (stock rooted)
d2spr (CM 4.2.2 nightly)
manta (stock rooted)
Follow me on Twitter
Email/GTalk
Google+ - 12-19-2011, 10:14 PM #5
- 12-19-2011, 10:33 PM #6
- 12-19-2011, 10:35 PM #7
of course
- 11-05-2012, 06:18 PM #8
- 11-06-2012, 05:18 AM #9
- 12-20-2012, 04:12 AM #10
Reply
