05-02-2015 01:07 AM
48 12
tools
  1. artolonde's Avatar
    How long does it take to install the PdaNet on to the phone. Installing the USB drive took like seconds and then Setting up Network Drive took a minute, but the PdaNet installation in still installing and it has been 15min already. Is that okay.
    11-13-2012 04:09 PM
  2. mattcb's Avatar
    Thank you so much..saves me a headache.
    11-22-2012 10:29 AM
  3. dexsss's Avatar
    I would like to thank for successfully solver problem but I cannot
    I found those PdaNet driver in many places but it doesnt help me
    Is there any other solution for this problem (driver for android 1.0 in fastboot mode)?
    12-10-2012 04:09 AM
  4. nsf9206's Avatar
    Thank you soooooooooooooooooo much brother this helped me root my htc inspire 4g worked out great!
    01-18-2013 12:32 PM
  5. andrejsosipovs's Avatar
    Thanks A LOT!!!! U R A GOD!!!!!
    02-05-2013 11:26 AM
  6. hadlock's Avatar
    registered to say thank you(!) if you're wary about blind-downloading things, you can download this app directly from junefabrics' website
    if you're still having issues, triple check you have usb debug mode on in the developer options screen
    02-09-2013 09:00 PM
  7. Isaiahrs's Avatar
    You can also use the drivers here:
    http://dl.dropbox.com/u/4174784/usb_driver.zip
    It worked for me.
    PdaNet Did not work for me but this link did tnx alot
    03-16-2013 11:16 AM
  8. Gracen Ownby's Avatar
    thank you so much . working on my htc one x(at&t). been sitting here for 2 hours looking for the hboot/bootloader drivers so i could finish my root.U R EPICCC!!!
    03-19-2013 11:25 PM
  9. psa47's Avatar
    thanks thanks thanks
    03-21-2013 08:57 AM
  10. Mwa Wak's Avatar
    thnx alot........
    04-27-2013 07:02 PM
  11. Lady_KiWi's Avatar
    Oooh please answer me ! I know the post is old but i really need your help ! I followed all the steps, but the installation is blocked at this point : "Updating PDAnet on your phone.." The "updating" is still doing, for 30 minutes ! Before, i have done "installing USB driver" and "Setting up network driver", and im at this point, im blocked. I dont know what to do... Help me please
    05-10-2013 10:20 AM
  12. Lady_KiWi's Avatar
    I have the same problem. And PdaNet installation is not finished yet, im still waiting... :/
    05-10-2013 10:25 AM
  13. ProfWa3id's Avatar
    Thank you so much!!!!
    06-02-2013 06:14 PM
  14. susu74's Avatar
    I have been struggling for hours thanks a lot !!!
    07-12-2013 06:07 PM
  15. maxi57's Avatar
    but my process stuck at "step#7 waaiting for device and ,,,the superone click sofware show no response and pc windows show a messege that not responding.
    what i can do?
    07-26-2013 10:39 PM
  16. maxi57's Avatar
    can please someone help me?
    07-26-2013 10:45 PM
  17. danishsyed88's Avatar
    I'm probably the noobest person around here. Don't know much.
    I was following instructions on the net on rooting my Google Nexus S.Seemed simple but my computer wasn't able to recognize the usb drivers of the phone. I tried everything.
    Have been up since sunrise and trying things out.
    I think you have just done the thing for me. I'm not totally sure at the moment, but it did say that ADB was installed. Let's check it out
    THANKS!!
    07-28-2013 04:23 AM
  18. Nauman Alvi's Avatar
    is this pdanet file a virus? i am afraid it is !
    07-30-2013 08:27 PM
  19. Hei7's Avatar
    Thank you sooooooo much
    07-31-2013 12:12 PM
  20. susanbasnet's Avatar
    THANK$ DUDE I FEEL DAMN BLESSEd
    08-25-2013 09:17 PM
  21. carephonedanang's Avatar
    it's work .thank ^^ ,galaxy nexus S m200k
    09-07-2013 05:43 AM
  22. Haydon Lambert's Avatar
    Please help me it wont work it keeps saying windows could not find driver software for your device same as with the http://dl.dropbox.com/u/4174784/usb_driver.zip link.. Help
    04-28-2014 06:37 AM
  23. Tinkermaths's Avatar
    Registered just to post my thanks. This solved my issue that had been going on for hours.
    05-02-2015 01:07 AM
48 12
