DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Page 4 of 8 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 193
Like Tree47Likes
  1. #76
    BayRican's Avatar
    Posts
    ROM
    CodeName 1.3.3
    Default
    Quote Originally Posted by Cyber Warrior View Post
    Yea not sure about bugless beast... never tried it... but with Codename and AOKP the soft key mods are built into the ROMs settings amongst other great features.
    Basically what you need to do is:
    Go to the main page of the developers ROM (its in the first post of the links I gave you)
    Download the latest version of the Codename ROM and download the Gapps (Google apps... Gmail, Gtalk, Google +, etc..)
    Boot into Recovery through ROM Manager
    Wipe Data, Wipe Cache, Wipe Dalvik
    Go to Install from SD Card and choose the Codename ROM
    After it is installed.... and you're still in Recovery
    Wipe cache, Wipe Dalvik (No Data Wipe)
    Go to install from SD Card and install the Gapps zip file
    Once that's done... reboot your phone and you're all set to go. The ROM has pretty much every single kind of built in modification that you can think of built right into the settings.
    Your awesomeThank you I will try this when I get home.
  2. #77
    BayRican's Avatar
    Posts
    ROM
    CodeName 1.3.3
    Default
    Worked perfectly I'm now running codename with Gapps. Im loving it Just didn't get the blue soft keys. Thanks again Cyber Warrior.
    zero neck likes this.
  3. Thread Author  Thread Author    #78
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    Default Re: [Guide] How To Backup, Restore & Install ROMs on The Galaxy N
    Quote Originally Posted by BayRican View Post
    Go into the phones settings... codename settings... on-screen controls... on-screen control color. You can change the keys to whatever color you want. Browse through the codename settings... there's alot that you can do
    Thanked by:
  4. #79
    BayRican's Avatar
    Posts
    ROM
    CodeName 1.3.3
    Default
    Thanks wow so many options. Now its perfect.
  5. #80
    llocknload's Avatar
    Posts
    ROM
    JellyBellyV3.6/FrancoR220
    Help! I wiped data. wiped cache. wiped dalvik.
    I went to install zip from sd card and hit the power button to select. It did not bring up the list of ROMs on the sd, however my screen now shows the android standing upright with a blue 3D octagon shape spinning.
    No menus. Not sure what to do. I dont want to pull the battery and end up messing up the phone real bad.
    Saw a message that said "back menu button disabled".
    I'm not using the touch based CWM recovery.
    EDIT: Pressing the power button gave me a menu back. scrolling down through the menu (so that it went back to the top), re-enabled the back menu button. and then I was able to proceed normally.
  6. #81
    farbster's Avatar
    Posts
    Global Posts
    42 Global Posts
    I did this (got root explorer and changed the name) and it worked. When I rebooted I got an error message "unfortunately, the process android.process.media has stopped"
    Any thoughts? I googled it and one place said it had to do with the camera and another said about Titanium Backup and the contacts.
    I also got an error (?) when backing up - "no /sdcard/.android_secure found. skipping backup of applications on external storage
    no sd-ext found. skipping backup of sd-ext"
    The rest of the backup (from cwm) seemed fine. I would expect that there is no sdcard, but not sure what this means or what affect it has (or is it effect?)
    Thanks!!!
    Thanks!
  7. Thread Author  Thread Author    #82
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    Quote Originally Posted by farbster View Post
    Thanks!!!
    Thanks!
    The two messages about the sd card/extension are completely normal. As you mentioned.. it skips the backup because 1. There's no sd card and 2. Nandroids do not back up the sd card to begin with... so that's perfectly normal.
    The message about the media process stopping... I would need to look up. Sometimes those type of messages pop up and then never come back. Something could have caused the app to crash. Its fine as long as you're not repeatedly getting that error and that everything is working. It could have been something that interfered with some type of media app as the phone was booting up. The process will force close and then re-open itself when its ready. Not a big deal and like I said... I wouldn't worry about it as long as its not happening every two seconds. Chances are one process was interfering with another one so it shut itself down and then restarted again when it was ready. I don't think it was contacts... it was most likely the sd card didn't read all of the files stored on it and it force closed. Everytime you boot the phone up... the phone reads/checks the sd card for new files and prepares itself for the phone.
    Thanked by:
  8. #83
    farbster's Avatar
    Posts
    Global Posts
    42 Global Posts
    I was able to flash the latest Bugless beast. Thanks so much for your help!! Seems like the error message from above has resolved itself.
    A couple of questions:
    1) when using mybackuppro - do I need to back up data and apk, or will just data work?
    2) i had so many contacts (i use xobni for my contacts and i believe it pulls the emails from every email - say all the parents on a email blast from their lacrosse leauge) and i got a message after setting up again that said "delete limit exceeded. There are 708 deleted items for Contacts, account . What would you like to do? delete items/undo the deletes/do nothing for now. I keep hitting do nothing for now.
    The setup took forever, mostly due to the contacts. Well over one hour. is this normal?
    Finally, is there a toggle on BB for cdma/4g? I saw 2/3g, but not 4g
    Thanks again for all your help!!!!!
  9. Thread Author  Thread Author    #84
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    1. Yes you can choose just data. If you want to backup the actual app.. choose apk.
    2. Don't backup contacts with MyBackup. Your contacts are automatically backed up through Google using your Gmail account. You're duplicating your contacts which is causing the phone to delete the first batch in order to restore the second batch which is causing the phone to crawl. I've made that mistake once.. unfortunately the easiest way around it is to wipe the phone and reflash the ROM.
    3. Not sure about stock but there are custom ROMs that have the 3/4G toggle.
    Thanked by:
  10. #85
    farbster's Avatar
    Posts
    Global Posts
    42 Global Posts
    I hope this isn't going too far off topic - but are there any settings on Bugless beast that will increase battery life in some spectacular fashion? Or is that more something for a different custom ROM? Any suggestions on others to try? I see a lot of people talking about gummy...
    Android central and the folks here are so great. Makes me think I should short Blackberry stock in a big way!
  11. #86
    when restoring rom do i need to wipe/factory reset or can i just wipe cache/davlic? thanks!
  12. Thread Author  Thread Author    #87
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    Quote Originally Posted by vinzky View Post
    You really don't have to wipe anything. You can just flash your nandroid backup.. I sometimes do a full wipe.. but I'm just being over cautious.
  13. #88
    chriscw81's Avatar
    Posts
    ROM
    AOKP/Francos K/4.1.1
    flawless guide. mucho appreciated!!!!!!
  14. #89
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    So I can't find "recovery-from-boot.p" to rename it. Yet, there are no problems. CWM seems to stick, I can get into it from RM and from the Bootloader.
    Nonissue?
  15. #90
    ambrodsky's Avatar
    Posts
    Global Posts
    91 Global Posts
    ROM
    Official 4.0.2 Rooted
    Default Re: Install ROMs/Kernels/Themes/Mods with ROM Manager
    How long should the wipe data/factory reset step take? I'm going to flash a new rom for the first time and I booted into recovery and selected this option. It's been sitting at the Recovery logo (Top hat with a yellow circular arrow) for about 15 minutes. Not sure if it's doing it or if it's stuck.
  16. #91
    ambrodsky's Avatar
    Posts
    Global Posts
    91 Global Posts
    ROM
    nevermind, sorry. figured it out
  17. #92
    Hello,
    I am new to everything and I tried to flash a modaco rom on my 4.0.4 ICS verizon and it just kept looping the animation screen. So I pulled the battery and restored to stock. I tried again and it did the same thing, so I am trying to restore to stock and now it says that there is an error when backing up data. I did the wipe and restore and the dalvick wipe. I tried 3 times with 3 different restore points. I would love to use my phone again ASAP:0 Thanks
  18. Thread Author  Thread Author    #93
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    Are you using the GSM version of the phone or the CDMA/LTE (Verizon) version of the phone? For Verizon you don't want Modaca builds...you need to use Toro.
    I'm a little confused when you say that you are stuck trying to restore while backing up data. Do you have a nandroid backup of your stock ROM?
  19. #94
    Dracolan's Avatar
    Posts
    ROM
    CM 10 Euroskank
    I am sure this has been asked before and if so, if you could just point me to the right post/page with the answer. I was wondering how to go back to stock recovery as to receive the OTA update when it hits?
  20. Thread Author  Thread Author    #95
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    Flashing your Nexus back to stock to receive updates
    [HOW TO] Flash stock Recovery to VZW Galaxy Nexus before accepting an OTA update.
    This assumes that you:
    - have a factory image installed on your VZW Galaxy Nexus and have replaced recovery with ClockworkMod Recovery.
    - you have ADB setup corectly:
    1. Download the Android 4.0.2 factory images to your PC from Google:
    *We are interested in the stock recovery image named recovery.img.
    2. Unzip the file and its contents into your SDK/Tools folder (wherever your adb.exe and fastboot.exe files are).
    *Make sure they are not in their own folder, but have all been extracted to Tools.
    3. From within the Tools folder, open a command prompt (SHIFT + right click and select “open command prompt here”).
    4. Type the following commands, allowing each to finish before moving onto the next:
    adb reboot bootloader
    fastboot flash recovery recovery.img
    fastboot reboot bootloader
    5. Once you Reboot into the bootloader scroll down (volume keys) and select "Recovery mode" (power button).
    6. You should now see the default recovery not Clockworkmod recovery.
    7. Now you can install an OTA and it should install fine.
    An easier solution would be to flash a stock rooted 4.0.4 ROM .... why go through all the trouble to restore to stock when the awesome devs in the community will have a stock, rooted (usually debloated) version out ...
    There are a few 4.0.4 ROMs already out:
    Thanked by:
  21. #96
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    ^ Javroch's Clean AOSP Rom was also updated to 4.04 recently. That's a nice, close to stock (with some tweaks but minimally) option. Gets my stamp of approval.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
    Thanked by:
    Cyber Warrior likes this.
  22. #97
    Dracolan's Avatar
    Posts
    ROM
    CM 10 Euroskank
    Awesome thanks
  23. #98
    buckie bo's Avatar
    Posts
    Global Posts
    47 Global Posts
    Great guide...very easy to follow and I surely will refer to it often.
    Have a small issue however. I followed the guide to install a rom on my cdma nexus. The rom was pete_toro_ota_2012-04-09. I put it on the nexus and followed instructions to a T...created backup with Rom manager...etc.
    The install went fine until it rebooted to "normal mode" It has stayed on the boot animation screen for well over 30 mins. I removed the battery, booted back into recovery and I am restoring the backup I made because I cant be "down" on the phone for long.
    Any idea why this happened or what I might have done to cause it to do this?
  24. #99
    I have never done anything to this phone( Rom, root, flash,etc.) I finally decided i wanted to put 4.04 ota on this device. I downloaded the clockwork rom manager, and did the flash clockwork mod recovery, but everytime i do it i get an error that says an error occurred while attempting to run privileged commands!
    Any help?
  25. #100
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by NotDiabl0 View Post
    Any help?
    You need to be rooted to use Rom Manager. Thats probably the problem.
