Re: [Guide] How To Backup, Restore & Install ROMs on The Galaxy N
Do you have the superuser app in your app drawer? Check to see if there are any updates available for it in the Play Store. Also try rebooting your phone... and try using another app that requires root privileges like Titanium Backup and see what happens. You can also try uninstalling ROM Manager and reinstalling it... then try to flash CWM Recovery again.
When i try to flash clockworkmod recovery a popup appears that says " An error occured while attempting to run privileged commands!" Any suggestions?
