Page 8 of 8 FirstFirst ... 5678
Results 176 to 193 of 193
Like Tree47Likes
  1. #176
    Default Re: [Guide] How To Backup, Restore & Install ROMs on The Galaxy Nexus
    Okay I understand that but when you do a clean install people suggest a factory wipe. Doesn't that wipe everything completely?
  2. #177
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Quote Originally Posted by StarfishP View Post
    No. A factory wipe only wipes a couple partitions. None of those have the sdcard folder.
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    Thanked by:
  3. #178
    Ahh thank you very much you helped clear things up!
  4. #179
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    You're welcome. I highly recommend reading my Don't Panic guide too
  5. #180
    So, how do I find your Don't Panic guide? Sounds like a good read
  6. #181
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by djgdroid View Post
    Its stickied.. and in his signature
    Thanked by 2:
  7. #182
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Quote Originally Posted by 2defmouze View Post
    This
    Sent from my Overly Suspicious Robotic Grouper
    Thanked by:
  8. #183
    Default Re: Install ROMs/Kernels/Themes/Mods with ROM Manager
    Do I need to wipe the cache partition and Dalvik cache if I am just flashing different radios?
  9. #184
    NotJustAPhone's Avatar
    Posts
    Global Posts
    11,772 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Quote Originally Posted by garyk66 View Post
    No need when flashing radios.
    Sent from my SGSIII
  10. #185
    Do I root before installing backup app?? I am confused. please help. My phone broke, I have the replacement on my desk, but need a full backup before starting with the new phone!! Have windows computer. How do I do the rooting?
  11. #186
    I'm pretty new at this so if this has already been answered I apologize. I'm currently using CM10 which is the first ROM I've used. I'd like to try some others but I don't want to lose my app data again like when I unlocked. I installed my backup pro and it tells me my busybox is on 1.19.4 and1.20.2 is needed. I've tried a few busybox installers from the market but they are all at 1.19.x. Does anyone know how/where I can get an updated version?
    GNex (Toro) running AOKP
  12. #187
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by jms67 View Post
    I suggest Titanium Backup. It includes its own busybox, and there's a link in my signature to my guide on how to use it properly
    Thanked by:
    jms67
  13. #188
    It's my first time trying to root and flash a drive. I rooted the phone using WugFresh's Toolkit and tried flashing MMuzzy's Jelly Bean - 4.2.1 - JOP40C on my Verizon Nexus. I realize now that this is probably the wrong build and I think I might have messed something up. When I try to boot the phone, it's been stuck on the rainbow X forever. I'm stuck, please help me get the phone started and the right ROM flashed. I just want me some 4.2!
    Thanks all!
  14. #189
    Quote Originally Posted by rossnovak123 View Post
    Thanks all!
    Ok, I flashed back to stock. Looking for a good ROM for 4.2 for JRO03O build?
  15. #190
    Quote Originally Posted by Cyber Warrior View Post
    INDEX OF THIS THREAD
    Post #1: Backing Up & Restoring ROMs/Nandroid >> You're Here <<
    Post #2: Installing/Flashing ROMs, Kernels, Themes & MODs >> Click Here <<
    Post #3: List of ROMs/Kernels/Themes/Mods >> Click Here <<
    _______________________________________
    In order to use ROM Manager, you must be rooted.
    Ok, I'm rooted and I'm trying to flash a different (4.0.4) stock ROM. I downloaded it from . Now, I can't see it from either CWM or in recovery mode. What am I doing wrong? And please do talk down to me, I'm just teaching myself how to do this; I need someone to explain it as non-technical as possible.
  16. #191
    scarryman04's Avatar
    Posts
    ROM
    Jelly Bean/ Thors ICS
    Just wondering why do you want to back to ICS?
    CWM is your recovery if you have flashed that during the rooting process or though ROM Manager.
    When your in recovery you want to select install and then you wil have to navigate to the folder it went in once you downloaded the ROM which is most likely the Download folder, so it should be in /sdcard/Download.
    You can download a file manager app from the market such as ES File Explorer to check before booting into recovery to make sure its exact location.
  17. #192
    I am trying to backup to flash CM 10.1. However,
    1) the toolkit on XDA, while it preferred TWRP for recovery, can't do a TWRP backup.
    2) the Wug toolkit isn't up to 4.2.x yet so can't use that
    3) when going into TWRP manually there are a ton of options under backup that I have no idea what they are. Which things should be checked? Options are system, cache, data, boot, recovery and EFS. System, boot, and data are preselected.
    Note: I did a MyBackup backup of apps and data but would like to do this one too, to be safe.
    Thx.
    Sent from the Superuser account on my newly rooted Sprint Galaxy Nexus
  18. #193
    Posts
    ROM
    Quote Originally Posted by gnr_2 View Post
    Thx.
    System and Boot are MANDATORY, the rest are optional...just go with the default preselected options and you'll be fine.
    Thanked by:
    gnr_2
B
