[Guide] How To Backup, Restore & Install ROMs on The Galaxy Nexus
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
NotDiabl0
13
Re: [Guide] How To Backup, Restore & Install ROMs on The Galaxy N
Does rooting completely wipe my phone? Im trying to make a backup and save everything because ive been running this phone since the day it came out, just havent tried customizing it yet.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Rooting doesn't, but unlocking the bootloader wipes everything including the SDcard.
Reactions: Cyber Warrior
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
Rooting won't but unlocking the bootloader will... Wugs toolkit guide will back everything up for you so you don't lose anything.
Reactions: NotDiabl0
NotDiabl0
13
Appreciate the help, i take it unlocking the bootloader comes after you back it up...lol
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
lol yes. Like CW said, Wug's toolkit will backup everything for you. I also like to backup stuff manually (photos, downloads, etc.) just in case.
Enjoy your unlocked/rooted Nexus, like God and Andy Rubin intended it to be :).
NotDiabl0
13
Cyber Warrior, is your guide that you posted above just for bootloading? Or is there a seperate Rooting guide, im downloading the Wug toolkit right now.
NotDiabl0
13
I guess im confused by the guides doing the bootloader first and then rooting.. unless im completely missing the point and i have to bootload before i root lol.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Correct. You unlock first, then you root.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
Yes... bootloader needs to be unlocked before the phone can be rooted.
Unlocking the bootloader wipes thee entire phone including your internal storage (sd card). The rooting does not wipe anything.. its just a superuser file that gets flashed to the phone. I never used Wugs method (I used my guide) but it supposedly backs up your entire phone before unlocking the bootloader. I would plug your phone into a computer and back everything up also though just in case.
NotDiabl0
13
Okay, yah i dont want to lose anything. Now i just need to figure out how to back it up on my computer first....
Cyber Warrior
Robots Will Kill
Nov 28, 2010
7,239
2,519
If you're not using Wugs guide.. I'd recommend downloading MyBackup Pro from the app store.. backs up call logs, messages, bookmarks, etc.
And for your sd card... go into the phones settings.. development.. turn on usb debugging.. connect phone to computer with usb cord that came with the phone.. go to the phone disc drive (folder) on your computer (My Computer) and copy and paste the folder to somewhere on your computer. When you're done hacking the phone.. move the files back onto the phone.
NotDiabl0
13
None of the files that are on the Nexus "Hard drive" would effect anything if i decided to bootload and root. As in the files that are all on the sd card are for apps or music or contacts and would have no effects on the actual os system on the phone.
GNex Girl
732
36
I unlocked and rooted using this method. Now I want to unroot. How do I do it? Thanks!!
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
This guide isn't his unlocking/rooting guide.
This is ==> http://forums.androidcentral.com/ve...ock-bootloader-root-verizon-galaxy-nexus.html
Wug's Toolkit, also advisable ==> http://forums.androidcentral.com/ve...y-nexus-root-toolkit-v1-3-updated-1-22-a.html
For your current dilemma, I suggest getting Wug's and flashing stock recovery. If you want to not go through all of those steps, simply manually install the OTA.
Reactions: zero neck
gary keels
Active member
Jul 6, 2011
25
When i try to flash clockworkmod recovery a popup appears that says " An error occured while attempting to run privileged commands!" Any suggestions?
fallingOutOfLoveWfithTech
