Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 58
Like Tree7Likes
  1. Thread Author  Thread Author    #26
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by vwdriver67 View Post
    ok please help me I messed something up big time and now im stuck at boot up. I changed the permissions on the framework-res.apk and unchecked them all after i was having no lock removing the verizon logo. I made sure to make a back up before i tried this but when i try and enter recovery i get a RED ! over the android any ideas??? I THINK i can get it back to stock but i would like to use that backup that i have to restore it
    Never got the red ! Before. Not sure how to get around it. You should be able to flash a backup if you can get it. Even if you wipe I'm not sure if it deletes that part if the phones memory since its like a SD card. I would hope it leaves that section alone. Let me know what happens
  2. #27
    VAVA Mk2's Avatar
    Posts
    ROM
    CNA 3.5.0/Franco N248
    Default Re: [MOD] Removed VerizonWireless From Lock and Drop Down
    Quote Originally Posted by tntdroid View Post
    It's been some time since I made some mods but I wanted to share this. It is for stock framework. It will remove VerizonWireless from your lock screen and your drop down. Install is simple. Download the file and and place on your phone. Using root explorer find the framework file and copy it. Then go into system/framework and paste. Before you paste make sure you are in R/W mode. Once you hit paste it will just reboot. Give it a moment and it will boot back up and it will look like in the photos.
    No Verizon -
    Google -
    Galaxy Nexus -
    Stock -
    How did you get the power center/controls in your notification bar? Totally doing the stock one with that in mine tomorrow.
  3. Thread Author  Thread Author    #28
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by VAVA Mk2 View Post
    Just a app called widgetsoid in the market. Its free and very handy.
  4. #29
    "Google" version worked great for me on AndroidRevolution HD and stuck after reboot. Thanks!
    Thanked by:
  5. #30
    VAVA Mk2's Avatar
    Posts
    ROM
    Sweet! You rock! Will try both!
  6. #31
    I just copy/pasted the google one on stock rooted/unlocked 4.0.2 and now get stuck on constant boot animation.....
    Reflashed recovery and restored to a backup I made before messing with this, phone is up and running but back to Verizon. Any suggestions?
  7. Thread Author  Thread Author    #32
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by tysoncrosby21 View Post
    How long did the animation go for? I had it boot for a minute or two. The stock animation is sometimes hard to tell if boot looping. Once you copy and paste if it didn't reboot just start hitting the back button. Should then freeze and reboot. Also check the permissions so they are set to read and write. Since you have the backup try it again. As always good thing you made one. Hopefully it will work for you. I just flashed a new rom so I'm back to the Verizon wireless need to do some work tomorrow and fix that .
  8. #33
    I let the animation go for almost 5 minutes. It immediateley rebooted after pasting and I checked permissions to make sure they were checked exactly as described in the picture previous.
  9. #34
    Could you please tell me where in the APK that the 'verizon wireless' strings are located. I have found the lockscreen 'roaming indicator' and was able to replace it, but where is the other one for the pull-down screen.
    I'm trying to remove 'Verizon Wireless' from Axiom V2.2 by decompiling the framework apk. If you know of an easier way, please lemme know.
  10. Thread Author  Thread Author    #35
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by number3pencil View Post
    System/framework/framework-res.apk/Res/xml. You will want to pull the Eri.XML file. Using a xml editor (forgot what one I use) you will see the code on the left and the text break down on the right. Find the Verizon wireless line and overwrite it or space over all the text to erase it. Then drop the file back into the folder with 7zip and save it. Push the framework-res.apk file back to the phone or copy paste over the stock.
  11. #36
    Terrigno's Avatar
    Italiano Papi
    Posts
    Global Posts
    3,527 Global Posts
    ROM
    iOS 5.1
    Default
    Sweet. But I actually like the words Verizon? Lol
    Just swapped out the Xoom Tablet for an IPhone. I never ever thought I would get an IPhone. Im currently eating my words. Apple has a lot going on here....Im loving both platforms.
  12. Thread Author  Thread Author    #37
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by Terrigno View Post
    Lol when you do delete it it kinda looks off cause your used to seeing it.
  13. #38
    Nick_IT_NC's Avatar
    Posts
    Global Posts
    316 Global Posts
    ROM
    CM7.1 Chevyno1 1.0 ulv
    Default
    Works great. Thanks man.
    [ROM] CyanogenMod 7.1 on Moto Droid
    [Kernal] Chevyno1 7-slot 1.0 ghz Ultra LowVoltage
    [Recovery] CWM
  14. Thread Author  Thread Author    #39
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by Droid_Man View Post
    No problem!
  15. #40
    Default
    If having a issue with this sticking make sure the permissions are set like this. Then reboot.
    Are you sure the permissions aren't supposed to be rw-r-r-- ?
    I looked at mine, and those are the permissions of mine before I flash. It might help everyone who has had problems?
    ____________________
    "King of the 'Self-Edit'"
    "Patriotism is supporting your Country at all times. And your government only when it deserves it" --Mark Twain
    Are you an Ameri-CAN? Or an Ameri-CAN'T?
    Dyssomnia likes this.
  16. #41
    mtmjr90's Avatar
    Posts
    Global Posts
    647 Global Posts
    ROM
    Stock (for now)
    Hm...I just flashed CM9 alpha (4.0.3) and it doesn't seem to work. I'm getting the boot looping problem Any ideas? It's not the end of the world...but I rather liked the "Google"
  17. Thread Author  Thread Author    #42
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by mtmjr90 View Post
    The framework in cm9 is different than stock. This will only work on stock. I posted a quick how to. Try it out and get it running for cm9.
  18. Thread Author  Thread Author    #43
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by firefighterguy View Post
    That's how mine were set up. Its worth a shot as you laid it out. I would just click all the buttons. It can't hurt. Can't break this thing
  19. #44
    Default
    Lol. True...unless I drop it and then complain that it's not built well enough, side-stepping the fault being mine.
    Isn't it funny how when you put the word "The" and the word "IRS together, it spells "theirs? " Coincidence? I think not.
  20. #45
    Just did this on my phone. Downloaded the file to pc then moved to phone. I didn't mess with the permissions just replaced the file. Happy to say that even after multiple reboots the change still sticks.
    Side note, this is the first thing i've done to my phone since rooting it. Thanks for the work you did making this mod and the details on how to install it. Made it easy for a super noob like me to do!
  21. Thread Author  Thread Author    #46
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by acidfruitloop View Post
    Glad it went OK for you! Enjoy and thank you.
  22. #47
    When you open the xml file in an editor, does it have a bunch of ASCII characters in it like this?
    Just curious because it doesn't seem to be a text file.
  23. Thread Author  Thread Author    #48
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by Fahrenheit View Post
    Yes that's it. Just write over it or space over to delete it.
  24. #49
    No Verizon -
    Google -
    Galaxy Nexus -
    Stock -
    MegaUpload is dead. Killed by FBI. RIP. Where else can I get the file do remove Verizon Wireless lockscreen?
    Thanks
  25. Thread Author  Thread Author    #50
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by AlSat View Post
    Thanks
    Yea I noticed. I dislike most other file sites. What's a good one that's not under attack right now and I'll move them.
