Basically just looking to use a cpu app to save battery when the screen is off. Has anybody tried cpu tuner or Rom toolbox pro? Just curious if anybody has and if their results were any better or if the app works any better on the Gnex....
I never really had much luck with the profiles in SetCPU. I know on the Nexus S it was recommended that it not be used at all because it had an adverse affect on battery life. I'm not sure of the reasons for that or if it applies to the GNex
Honestly, I think battery life is pretty good just stock. It's the same as the Nexus S and that's good considering the larger screen and LTE radio.
