- 12-25-2011, 08:08 PM
Thread Author #1
Phone died and won't charge?
Hi guys. I'm running the latest version of Rootzboat. My phone died earlier today. I left it plugged in to a wall charger for ~3 hours. The phone wouldn't turn on. I plugged it into a different wall charger and connected it to my computer through usb. Nothing appears to be charging it. Any ideas on what's wrong? Should I just go in to Verizon tomorrow and get a new battery? Thanks!
- 12-25-2011, 08:43 PM #2
If the wall don't work and the computer I'd take it in. Is it the stock charger and USB cable?
- 12-25-2011, 09:54 PM
Thread Author #3
Re: Phone died and won't charge?
Hey thanks for the response. Yeah I used the stock wall charger and USB cable initially. My phone started working again. I tried powering it on while holding the volume down button while it was plugged into the computer by USB and it took me into Odin. I'm not sure if it just needed to cool down (was running pretty hot right before the battery died) or if doing this somehow allowed it to boot. Once it turned on it was able to charge again. Just a heads up if anyone else runs into this problem.
- 12-25-2011, 09:58 PM #4
Very good. I had issues like this with my Xoom. The screen would not turn on and it would not do anything. Hitting volume up and power would force a reboot and it would work again. Glad its working.
- 12-26-2011, 04:33 PM #5
- 01-14-2012, 12:48 PM #6
Hey Guys,
This happened to me as well and I got it working again.
I went to bed and when I woke up I turned my phone on but the unlock screen was unresponsive. I pressed and held the power button and I felt it vibrate which normally happens when you are presented with the power down options, however nothing came on the screen, it was still at the lock slider. So I did a battery pull, reset it, checked a web page and then went back to bed. When I woke up again, there was nothing but a black screen and pressing the power button did nothing.
I figured maybe the battery had fully discharged. I plugged it into the wall with the supplied charger for a few minutes, nothing. Plugged it into the computer with the supplied USB cable, nothing. Plugged it into the wall using my Blackberry charger, nothing. Tried doing all of the volume + power button combos while plugged in, nothing. Tried battery pull and still nothing.
To get it working again I unplugged it from the USB and then took out battery and the SIM card. While the battery and SIM were out I held the power button down for 10 seconds, thinking that there might be some built up power/static that needed to be discharged. I replaced the SIM card and battery and as soon as I plugged the USB cable in, the battery charging symbol appeared. Left it for a few minutes and then pressed power and voila, it was back.
Now, as I said before I thought that maybe the battery had fully discharged... However upon powering up my battery was at 45% Very weird.
Anyways, that's my story. Maybe my idea of holding the power button with the battery and SIM card out had an effect, maybe not, I don't know. But if you find yourself in this situation I'd say that it's worth a shot.Thanked by 7: - 01-14-2012, 08:43 PM #7
- 01-15-2012, 07:27 PM #8
NordicNinja and exliontamer,
I had the exact same problem with my brand new Galaxy Nexus. It just died all of a sudden, wouldn't turn on, couldn't get it to even charge. Unplugged the usb charger, took the sim card and battery out, held the power button for 10 seconds, replaced the sim card and battery, tried charging it again and it recognized the charge and I was able to turn it back on! The battery was at 58% though so I don't know what the problem was. Any ideas on how to prevent this from happening again or what the problem is?
Thank you for the fix! - 01-18-2012, 01:56 AM #9
NordicNinja, I made an account just to tell you you are the man.
I had the same problem, I left my Nexus alone, and when I walked back to my room, it wouldn't respond- nothing. I tried charging it, taking out the battery, still nothing. I tried your technique and it worked... turned back on with 61%. I just wanted to say thanks... let's hope this is not a recurring problem. - 01-18-2012, 07:24 AM #10
Mine worked fine until I went to bed. Turned it off to charge as normal and stuck on charger(didn't pay attention to see if it lit up). Woke up and it is dead. Tried to hold down volume buttons + power, tried taking out battery & sim card then holding down power for 10 seconds, and tried another battery that's fully charged(I have the extra battery & external charger). Zilch, a completely dead phone.
I am running a custom ROM but have had zero problems in the 3 weeks I've owned it. I haven't downloaded a new app in at least a week maybe longer. The computer won't recognize it at all so I can't unroot or do anything to the phone. Please help!! - 03-05-2012, 07:55 PM #11
- 05-12-2012, 10:41 AM #12
- 07-17-2012, 07:52 AM #13
Just happened to me and tried your method, worked perfectly!! Thank you so much!!!
- 08-13-2012, 09:33 AM #14
- 08-14-2012, 11:43 AM #15
I tried it, but my lockscreen says its discharging at 100% wtf? This just happened this morning. Tried nordicninja's technique, then plugged into computer via usb, no luck
Update: works now!!Last edited by Jeenyus; 08-14-2012 at 12:04 PM.
- 10-18-2012, 12:59 AM #16
Idk how to use this.
but I left my phone Home charging and when back my phone didn't churn on i tryed different chargers and usbs no working but i put different batteries and it churns on but it won't get the main battery my phone SGH-T679 first time -_- what do you think? - 10-27-2012, 10:43 AM #17
- 10-31-2012, 01:15 AM #18
nordicninja, i joined just to say thank you! I don't even have the same phone (I have a crappy Samsung Gem), but it was having a similar problem. plugged in but wouldn't turn on or even say it was charging, but now it does say it is charging and I am going to try and turn it on in a sec.
Thank you! - 11-14-2012, 12:36 AM #19
- 11-25-2012, 08:47 PM #20
- 01-29-2013, 06:34 PM #21
Okay, you are a genius. My phone was dead so I put it on the charger but it wouldnt charge. I could turn it on, but then it would power right back off. I tried everything that you did, I even tried taking the sim card and battery out, I just never thought of pressing the power button while it was out! Thank you.!!(:
- 01-29-2013, 08:31 PM #22
I have heard if you pull out the battery and then hold the power button for 10 plus seconds it will relieve static electricity or charge or something like that. Then out the battery back in and try again. Reply back if that works. I don't know if it will work though.
Sent from my Galaxy Nexus using Android Central Forums - 02-06-2013, 03:32 PM #23
Unbelievable! Wow....I'm sitting here with a replacement phone trying to return my previous phone to stock and accidentally ran across this thread. I can't believe my phone is charging. THANK YOU!
Oops....it stopped charging again. Time to restore the phone back to stock. - 02-08-2013, 06:23 PM #24
- 02-28-2013, 07:26 PM #25
I had same issue, I solved by getting into bootloader mode, I suppose Odin mode would work as well, and letting it sit on the charger about 30 minutes. By then it finally had power enough to boot into twrp and I allowed it to charge in recovery until I could boot. But strange thing is it wouldn't boot, hung on Google logo. I had to restore the boot partition from a nandroid. All good now but wtf?
Reply
If I had hair I'd be pulling it out right now!!!
