Re: [Automated] Wug's Galaxy Nexus Root Toolkit
For anybody having problems, make sure you do STEP 5 in the FAQ. I will paste it below as a shortcut.
5.) I am having trouble, I think its a driver issue.
Ok, make sure to configure it properly. To manually configure the driver. You need to be in bootloader mode on your phone.. The unlock script will do this immediately for you. And then, on your computer;
1. Open device manager on your PC.
2. Right click on Android 1.0 with the yellow ! mark on it.
3. Choose update driver.
4. Choose browse my computer.
5. Choose Let me pick from a list.
6. Scroll down and find the Samsung driver with newest date. Should be the driver you downloaded above. (Possibly dated 11/25/2011 ).
7. It will give you a warning about installing the driver, just click yes.
YOU should see a prompt on your phone now, stating YES or NO to unlocking the bootloader.
Hope this helps! In the rooting process now.
