wheezy276
Active member
Just got my NFC tags and love this idea. Props to Erik (gnapoleon2) above for setting me onto the idea.
No, with NFC Task Launcher you can set up a tag profile, basically applying 2 task sets to one tag. For instance, I have a tag on my work phone that I will use when I get in the office to turn on WiFi, vibrate, etc. When I leave, I will scan the same tag to turn off wifi and open my bus tracker. Took about 5 minutes to figure it all out and set up the tag.
EDIT: On a side note, does anyone know if NFC tags (standard Mifare Classic 1K) are safe to put near other device's screens? For example, I just stuck one inside the case of my Transformer Prime so that I can enable WiFi tether on my way to work. I just want to make sure that because it faces and touches the screen while inside the case that it cannot do any damage through any electromagnetic field or something like that. Doubtful but overprotective of my expensive gadgets.
Probably safer using a non-metal sticker to avoid interference:
Anti-Metal NFC Sticker - UL | BUYNFCTAGS.COM
Just a guess
