Page 11 of 59 FirstFirst ... 891011121314 ... LastLast
Results 251 to 275 of 1475
Like Tree377Likes
  1. #251
    Default Re: [ROM] Android Open Kang Project
    anyone know why I keep getting bootloop when i install 25?
  2. #252
    Quote Originally Posted by sw33tooth View Post
    You have to give more details...how did you install? Did you wipe? Check md5? Any other pertinent info?
  3. #253
    Quote Originally Posted by davey11 View Post
    intalled off of cw yes i wiped and i checked md5
  4. #254
    Go back into cwm, under advanced, wipe dalvik, then wipe data/factory reset then flash rom again and flash gapps and it *should* boot.
  5. #255
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,115 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Default
    When I first saw the vid teaser on wiki for the nav bar hide mod, I was whoa gimme somadat. Now in actual use, BLEH. You kinda get caught up in all the hype of an upcoming build, and those guys at wiki can whip up a frenzy.
    Just gotta tell yourself to calm down I guess.
    Sent from my Galaxy Nexus using Xparent Blue Tapatalk
    Same here. Was really looking forward to the option to hide the navigation bar, but after trying it out I haven't used it. I do like the new option to replace the signal bars with a dBm value. Unfortunately, it doesn't show the LTE signal properly but I expect that will be fixed soon enough.
    I tell myself that I will wait until the next milestone but even I don't believe that. As soon as the next build drops, I'll be flashing it.
    Sent using Tapatalk
  6. #256
    davidnc's Avatar
    Posts
    Global Posts
    5,624 Global Posts
    ROM
    Nexus(AOKP-jb_4.2.1)
    Anyone on AOKP update to the new version of Nova Launcher yet ?
    It's out of beta now also in the market .
    I just update to the Black Ice version of AOKP havent update my Nova Launcher yet
    SGSIII : White 32 gb model with 32 gb sdcard
    RoM : CleanRom 5.5.1_ jb
    Kernel : n/a
  7. #257
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by davidnc View Post
    yeah i updated and bought prime for 4 bucks. only difference are gestures. not really worth four dollars but i figured i'd support the guy for the launcher that kills stock.
    nice thing about gestures tho - i have swipe up set to voice commands. no more looking for little mic button.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
    Thanked by 2:
  8. #258
    davidnc's Avatar
    Posts
    Global Posts
    5,624 Global Posts
    ROM
    Default
    Quote Originally Posted by zero neck View Post
    yup i would have to add funds to my pre paid card before I bought .l only have 65 cents on it currently ha
    sent from my Htc Incredible
    Kernel : n/a
  9. #259
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    ah true my market is set up to a credit card.
    the more i think about it, prime is worth it for me, bc i bet there will be more features eventually, although i have no evidence of this of course. anyway, the gestures are turning out to be pretty useful.
  10. #260
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    lol just had a SOD. Was downloading 1.0. Have you guys had success? I'm going to wait until I'm home and plugged in before downloading.
  11. #261
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by dmmarck View Post
    when i downloaded the prime key it took about 4 minutes to register that i had paid for - i hit the button to try to get the activation code like a thousand times before it worked.
    in the end, i didnt even have to use the code, i guess the payment wwent thru and i had prime.
    not sure what SOD is tho - haha
  12. #262
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Sleep/screen of Death. Won't turn on without batt pull.
    Prolly kernel related though.
    Thanked by:
  13. #263
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    ROM
    CLΞΛNЯOM
    just went into the Nova Settings... did a check for updates.. it said 1.0 is available and now in the market. I hit update... instead of taking me to the market it asked if I would like to install the apk... said yes and I now have 1.0 on the phone.. wasn't charged anything.. it just installed right over beta 14
    Edit... never mind.. its says I have 1.0 but I don't have the prime version. I tried going to gestures and it brought up the pop up to enter the activation key.
    zero neck likes this.
  14. #264
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Yeah I just updated to 1.0. Score!
  15. #265
    davidnc's Avatar
    Posts
    Global Posts
    5,624 Global Posts
    ROM
    Default
    I updated nova but will hold off purchasing til friday.
    Kernel : n/a
  16. #266
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    I'm waiting for Prime until I see what CM9 does
  17. #267
    Posts
    Global Posts
    10,115 Global Posts
    ROM
    Default
    Nice use of gestures. May get the Prime version for that feature.
    Sent using Tapatalk
    Thanked by:
  18. #268
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    oh true.
    the gesture for voice commands is already really helpful. i have my second and third docks (swipe dock either direction) with just voice command activation, to make it alittle easier to get to, but this far outstrips that method. and less clutter which is nice.
  19. #269
    SuperChargedJ's Avatar
    Posts
    ROM
    Rascream + Trinity kernel
    AOKP + Nova Prime =
  20. #270
    Posts
    Global Posts
    10,115 Global Posts
    ROM
    Have you guys seen Roman's interview on Droid Life? For those who may not know, Roman is the developer behind AOKP. Good stuff.
    Thanked by:
  21. #271
    Posts
    ROM
    Quote Originally Posted by NotJustAPhone View Post
    Have you guys seen Roman's interview on Droid Life? For those who may know, Roman is the developer behind AOKP. Good stuff.
    Definitely a great and entertaining read.
    Thanked by:
  22. #272
    goph_man's Avatar
    Posts
    ROM
    Axiom Patient Zero
    Can anyone help me by telling me what zip/gapps to download for aokp? I tried to download 1 mirror file but was confused about it and it did not work. Any help would be greatly appreciated!
  23. #273
    Default
    Just read it. Great read. What's interesting are the comments below the article, about some thoughts on the cnd rom.
  24. #274
    Default
    Quote Originally Posted by goph_man View Post
    Can you explain further about "it did not work"? If you used the one on the aokp website should work. Check the md5 also.
    When I flashed b25 I used kejar's 404 gapps package and that worked great.
  25. #275
    goph_man's Avatar
    Posts
    ROM
    Axiom Patient Zero
    I went on to this website: and I downloaded the mirror 1 zip for the cdma galaxy nexus and I also downloaded the gapps at the bottom of the page. When trying to install it however it went into an infinite boot loop. Am I doing something wrong? I just tried installing both through sd card rom first then gapps. Thank you for helping I am still a beginner!
