Page 15 of 59 FirstFirst ... 12131415161718 ... LastLast
Results 351 to 375 of 1475
Like Tree377Likes
  1. #351
    SuperChargedJ's Avatar
    Posts
    ROM
    Rascream + Trinity kernel
    Default
    Haven't downloaded M4 yet but I definitely will.
    Question for those who are running this ROM with Lean kernel + Lean tweaks. Haven't you noticed any SOD or random reboots? If so, what did you do to resolve them?
  2. #352
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,441 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Default
    Quote Originally Posted by SuperChargedJ View Post
    Running M4 with LeanKernel and leantweaks and no random reboots or SOD so far. I don't undervolt beyond the slight undervolting that is in the stable version of LeanKernel. Overclocked slightly to the 1350 slot as the max.
    Sent using Tapatalk
    zero neck likes this.
  3. #353
    Posts
    ROM
    Default
    Quote Originally Posted by NotJustAPhone View Post
    Sent using Tapatalk
    Thanks for the info. I'm gonna try this when I download M4.
    Update: Flashed M4 without a wipe and everything is going good. Just a thought but I read that others were having issues when not wiping. I downloaded M4 from the same mirror as B27.
  4. #354
    BringMeBack9801's Avatar
    Posts
    ROM
    AOKP
    Default Re: [ROM] Android Open Kang Project
    Is M4 4.0.4 or 4.0.3? (Sorry for the newbish question)
  5. #355
    Posts
    Global Posts
    10,441 Global Posts
    ROM
    Default
    Quote Originally Posted by BringMeBack9801 View Post
    It is based on 4.0.3. Google has not yet released the source code for 4.0.4.
    Sent using Tapatalk
    Thanked by:
  6. #356
    Posts
    ROM
    Loving M4 so far with Lean kernel and tweaks.
  7. #357
    dannye123's Avatar
    Posts
    ROM
    CyanogenMod9
    Hey guys, I really need help. I just got a replacement nexus and I unlocked the bootloader, rooted it, backed it up, and tried flashing aokp b27. I am not in a bootloop and do not know what to do!
  8. #358
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by dannye123 View Post
    You need to do a battery pull - then replace the battery, then boot back up while holding VOL UP, VOL DOWN, and POWER ALL AT THE SAME TIME.
    This will bring you to fastboot - you can select recovery mode by navigating with volume keys, then pressing enter to select.
    From there just restore your backup and make sure you get a good download (check md5) and you'll be good.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
    Thanked by:
  9. #359
    BSG75's Avatar
    Custom User Title
    Posts
    Global Posts
    1,055 Global Posts
    ROM
    Jelly Belly
    I'm running AOKP M4 on my Galaxy Nexus and Galaxy Tab. I don't have YouTube installed or available in the market on my GT. It's there on my GN, though.
    Please use the Thanks button below and to the right.
  10. #360
    Posts
    Global Posts
    10,441 Global Posts
    ROM
    Default
    Build 28 is out.
    Sent using Tapatalk
    Thanked by:
  11. #361
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    b28 with francos 98 is very smooth. i overclocked to 1344, it's almost as snappy as axiom. might give trinity a try out tomorrow.
    i'm a simple man, with simple needs. jk but it's nice to get back to an aokp build.
  12. #362
    I installed M4 a couple days ago and everything seemed to be working fine except gmail sync didn't work. Last night I updated to build 28. Before flashing the latest gapps I wiped the cache and the dalvik cache (as recommended earlier in this thread). It didn't change anything and I still can't get gmail sync to work. All my other accounts sync fine, it's just gmail.
    Any ideas?
  13. #363
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by MarcSaegesser View Post
    Any ideas?
    You have "email" checked off for the gmail account in Settings-Accounts and Sync - i assume?
    I havent seen this issue before, have you tried clearing data in Settings-Apps-Gmail App?
    Have you tried other roms aside from aokp to see if it works on them?
  14. #364
    Quote Originally Posted by zero neck View Post
    Clearing data for GMail had no effect. I think there may be problems syncing with other Google products as well. There were some error messages in logcat about bookmark sync and Google Talk can't connect
    E/GTalkService(361): connectionClosed: no XMPPConnection - That's strange!
    Watching logcat sometimes shows TONS of out of memory and GCs. Seems to be mostly related to the MediaScanner. When this happens the phone gets slow and hot and the battery level drops really fast.
    I was on the leaked 4.0.4 ROM before trying AOKP. That was working pretty well so I think I'll restore my nandroid backup and make sure things still work on that ROM.
  15. #365
    Posts
    ROM
    Default
    Flashed B28 and not experiencing any lags. No wipe coming from M4. Using LK 2.6 Exp Build 8 w/ Lean tweaks 12.2.
  16. #366
    Can someone confirm to me that it's not possible to run AOKP with the 4.0.4 radios...I assumed since it's based & ran on 4.0.3 then it would only bootloop if the 4.0.4 radios were flashed.
  17. #367
    I have the 4.0.4 radios on my Nexus running build 28.
    Thanked by:
  18. #368
    Default
    Quote Originally Posted by ultravisitor View Post
    Yup! Me too.
    Sent from my Galaxy Nexus using Tapatalk 2 Beta-3
    Nexus 4 / Stock | Nexus 7 / Stock | TFPrime / Hairy Bean 2.1.1
    @digitalslacker
    +digitalslacker
    Thanked by:
  19. #369
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,243 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default
    Quote Originally Posted by 901boy View Post
    You can use the 4.0.4 radios with AOKP without any issues.
    Sent from my GT-P6800 using Tapatalk 2 Beta-3
    Thanked by:
  20. #370
    Posts
    Global Posts
    10,441 Global Posts
    ROM
    Default
    Build 29 is out and incorporates the 4.0.4 code that Google released yesterday. Because this is based on a new version of Android, a full wipe is required.
    Sent using Tapatalk
    Thanked by:
  21. #371
    Posts
    ROM
    Flashed B29 and haven't experienced any issues. Using Lean Kernel as well.
  22. #372
    Posts
    Global Posts
    10,441 Global Posts
    ROM
    Default
    AOKP build 30 is out. Will flash when I get a chance.
    Sent using Tapatalk
    Thanked by 2:
  23. #373
    Sent using Tapatalk
    I haven't done an official aokp in ages. 30 sounds like a good number to get on it again.
  24. #374
    Defconrock's Avatar
    Posts
    ROM
    AOKP / Bugless Beast
    Really digging build 32. No problems yet (only been an hour or so).
    @Arevill
    Thanked by 2:
    davey11 and zero neck like this.
  25. #375
    Quote Originally Posted by Defconrock View Post
    +1
    32 is fine. Better for me than the other roms. Its just solid. Others had quirks. My opinion.
