Page 40 of 59 FirstFirst ... 37383940414243 ... LastLast
Results 976 to 1,000 of 1475
Like Tree377Likes
  1. #976
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    ROM
    SKAnkCM10/Milestone6
    Default
    Quote Originally Posted by SeigaGen View Post
    1. You can get the Verizon Login Client here:
    2. Try out Wheatley for battery life. I'm finding it to be quite good!
    +1!
    Sent from my GneX via Tapatalk
  2. #977
    Default
    Thanks and as far as wheatly is concerned I'm a little confused on how to install it, do I go into recovery and flash it as a update?
  3. #978
    oxymoron's Avatar
    It's been real...
    Posts
    Default
    Quote Originally Posted by Isamu982 View Post
    It's in the OC/UV settings in Franco's app under scaling governor.
    *customized tapatalk signature*
  4. #979
    Default
    Quote Originally Posted by oxymoron View Post
    These are the only settings I have
    Attached Thumbnails Attached Thumbnails [ROM] Android Open Kang Project-uploadfromtaptalk1339266473301.jpg
  5. #980
    Default
    I think the wheatley governor is only available in the nightly release.
  6. #981
    Default Re: [ROM] Android Open Kang Project
    I'm using a GSM Galaxy Nexus (bought from the Google Play store). I flashed the Franco kernel nightly 181. When I was using the wheatley governor, it did some funny things with the display. At one point it would show snowy looking dots. After rebooting the phone, a gray and white line was showing through the middle. Everything went back to normal after restoring from a backup when I using the Franco kernel milestone 4.
    "Remember, today is the tomorrow you worried about yesterday." - Dale Carnegie
  7. #982
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    OK, so I downloaded installed the package and tried log in but get the error message that services are temporarily unavailable. And won't let me login.
    Any ideas, AOKP b38 and Franco m4.
  8. #983
    cadman's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,822 Global Posts
    ROM
    BB JB
    m38 seriously is the worst release yet of this rom......signal is non existant.
    if I roll back to milestone 5 do I have to restore from a nandroid or can I just reflash the rom?
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  9. #984
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by tony bag o donuts View Post
    You could do either... However, I disagree completely. 38 is very solid I've had no issues, and a ROM isn't going to have any effect on your signal anyways.
    If you're having noticeable issues in the usual places you don't then it's more likely just VZ network issues. That's also assuming you haven't changed your radios since. But yeah the ROM really won't have any effect.
    JkdJedi likes this.
  10. #985
    cadman's Avatar
    Posts
    Global Posts
    6,822 Global Posts
    ROM
    BB JB
    yeah usually it shouldn't but this one is.
    Same radios, same locations.
    No signal in Hoboken, NJ today in numerous locations.....No signal in Basking Ridge, NJ along Rout 78.
    No signal in Bethlehem, PA Lehigh University. Problems I had with 4.0.2 that disappeared with the 4.0.4 radios but with this nightly it's bad.
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  11. #986
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Default
    Quote Originally Posted by Xanth269 View Post
    What app are you trying to open? After installing, all I did was run the NFL mobile app and it went through.
  12. #987
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    Trying to access My Verizon Mobile to check account usage and such. Did not try NFL.
  13. #988
    mikestorm's Avatar
    Posts
    Global Posts
    980 Global Posts
    ROM
    AOKP
    My favorite ROM so far. My one gripe is you lose the bookmark pop up shortcut in the browser when you long press the back button. My options are to either enable the quick menu in labs or access the bookmarks by flick scrolling to the address bar and going in that way. Any suggestion?
  14. #989
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Default
    Did you download the Nexus only version from the play store?
  15. #990
    Default
    Quote Originally Posted by mikestorm View Post
    You could also tap on the menu button at the top and then tap on bookmarks.
    I wasn't aware there was a shortcut to the bookmarks in stock ICS. When you say hold down the back button, are you referring to holding down the back soft key button?
  16. #991
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    When I go to google play search my verizon mobile, select the galaxy nexus, it tells me I already have it installed (done on a PC) i tried on the phone, doesn't even show up. I have gapps installed obviously and can download apps, either by PC or phone.
    Also when I check apps, I only see My Verizon Mobile, when I just tried it I get message Unfortunately Verizon Login has stopped.
    Xanth-
  17. #992
    mikestorm's Avatar
    Posts
    Global Posts
    980 Global Posts
    ROM
    AOKP
    Quote Originally Posted by MooPenguin32 View Post
    Thanks. I was aware of the flickscroll to top/menu->bookmarks but miss the one click option.
    There is an browser shortcut to the bookmark folder in bone stock ICS. While in the browser, at any time if you longpress the back button softkey your bookmarks folder pops up. Once I discovered it I got very used to it. I find accessing bookmarks any other way clunky.
  18. #993
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Xanth-
    Hi Xanth,
    Just to be sure, you downloaded this one here right?
    If you got that one and you're still getting an error, try going into app details and clearing cache and data. Then go into recovery and clear cache there. Reboot and try to see if you can log in. If not, chances are something funky happened and you might need to do a clean install of AOKP and GAPPS.
    EDIT: I just realize that you aren't the only one having this issue after reading some of the feedback. Ok, this isn't your problem but rather a VZW issue.
    Last edited by SeigaGen; 06-10-2012 at 12:42 PM. Reason: More people have this issue.
  19. #994
    timber's Avatar
    Posts
    ROM
    Jelly Belly
    Default
    I get the services not available error if I try to login for the first time while on wi-fi. Shut off wi-fi and give it a try. After the initial login I can use the myverizon app from anywhere.
  20. #995
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    Hi Xanth,
    OK went in to apps, I only see my Verizon mobile nothing about Verizon ans nexus. Cleared cache there, turned off wifi and reboot, same issue. Which cache to wipe in recovery?
    Not sure if it stopped when I changed to AOKP or vz had a update to myverizon app. Maybe there's a newer apk.
  21. #996
    Poseign's Avatar
    Mobile Enthusiast
    Posts
    Global Posts
    601 Global Posts
    ROM
    AOKP JB B1/Franco M5
    Default
    I have actually noticed problems too. After flashing b38 I had random data drops, an issue with my dialer that would sometime bug out and bring up an "in call" screen anytime someone called me so I couldn't see their caller Id, and worst of all it would randomly put the person on the other side of the line on hold mid call. I would be talking to someone and suddenly they'd be like "hello? Hello?" I'd look at my phone and it would say "on hold".
    As far as this last issue, I just got 4g last week in my area, hope that issue isn't related to that. I reverted back to a Android of b37 and am going to stay here for a while to make sure everything's good.
  22. #997
    svfd757's Avatar
    Posts
    Global Posts
    693 Global Posts
    ROM
    Cm 10/Franco
    Quote Originally Posted by Poseign View Post
    I've experienced data drops as well. Thinking seriously about going back an update. Not liking b38 right now
  23. #998
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    ROM
    JB Viciousness
    arent data drops related to the radios? i am experiencing these too, my 4g keeps dropping off to 3g, and im in midtown NYC, supposedly my lte signal should be quite strong.
    this is the worst time for data issues, i need to watch my footy at work!!! lol
  24. #999
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by nycinek View Post
    Radios + kernel can affect data signal and drops.
    Thanked by:
  25. #1000
    ekinnyc's Avatar
    Posts
    Global Posts
    424 Global Posts
    ROM
    JB Viciousness
    im on 4.0.4 radios with b38 aokp and r181 franco... which is the culprit, lol
