[ROM] Android Open Kang Project
How do you fix gamma and color stuff? I've never played around with too much advanced stuff for fear of screwing something up.
I use his recommendation and I do 1.2 for the other thing in there.
Reactions: bbudnick5001
Anyone having issues with your Google prepaid card on Wallet with b38? It was working fine until I flashed this. Now it says prepaid unavailable at this time.
Tried clearing data, uninstall, reinstall, blah blah blah... nothing. Maybe coincidence? Anyone else?
P.s. no, I did not restore app data. Using v1.1-R57v5
*customized tapatalk signature*
Lot of people having Wallet issues lately, so I'm pretty sure its on Google's / Money Network's end. Check the last page from here and you'll see a lot of the same issues, for example: http://forums.androidcentral.com/ve...oogle-wallet-1-1-r63-v12-may-16th-update.html
So hopefully they'll fix it on their end soon enough
Reactions: oxymoron
Word. Just updated through play store and still no dice. Oh well. Thanks for the link, man.
I have no idea. All I use is franco. He is fixing the app issue btw.
I'll be honest, as soon as I saw the screen go ultra dim with the purple tint, I started freaking out.... Like as if I just ruined another Nexus... LOL. After reinstalling it, I was able to fix the issue and normal colors started showing again. HA! Don't panic, because there is usually a way to get around things.
Thanks all.
I *think* the Franco app was updated because when I reinstalled it a little while ago, I got a change log that said the error was fixed. I think the version number was newer, as well; it said 4.9.2, and earlier I believe it said 4.9.1.
hah nice
OT:
me vs bugmailer, round 3.... wiped data/cache/dalvik, flashed b38, restored apps from google, and not doing ANY restore of data, well see if the bugmailer comes back :cool:
Running 38 now...a few hiccups when running.
How come google play always fc's after every rom installation? Works fine after the firs FC.....
love the new animation.
No idea, never happens here. Are you doing dirty flashing or full wipe? And using the latest gapps package (4/29)?
My play music never fc's either.
4/29 gapps here but never had that problem on earlier gapps.
probably cause I restore data from my personal apps (not system apps though).
User apps are generally fine .... I myself restore data to over 50 user apps and never have issues. Just make sure you don't restore any system data OR any data to Google apps, like those that we now download from the market which aren't in the gapps package, like Gmail, Play music, Maps, etc... Since us flashers download them separately, they do not register as System apps and if you aren't careful your backup app will restore data to them unless you tell it not to. Make sure you never restore to any google apps, or anything that actively syncs data in your accounts.
Best part about turning off the the bootani.... it says "jerk." One of many reasons I dig AOKP.
Reactions: NotJustAPhone
Ashok Dharshan
