Page 47 of 59 FirstFirst ... 44454647484950 ... LastLast
Results 1,151 to 1,175 of 1475
Like Tree377Likes
  1. #1151
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,243 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default Re: [ROM] Android Open Kang Project
    I like to use my GPS so I'll stay with 38 for now, thanks everyone for testing it for me
  2. #1152
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Default
    Latest Franco kernel 192 features 1651 mhz OC.
    Needless to say, my nexus didn't like that setting. I had some random freezes and restarts.
  3. #1153
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by SeigaGen View Post
    I ran it for an hour but did nothing of substance.
  4. #1154
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,872 Global Posts
    ROM
    BB JB
    Hopefully 40 drops soon to fix the gps issues but I have a feeling that will be a milestone release.
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  5. #1155
    Quote Originally Posted by 2defmouze View Post
    GPS just locked on here in about 12 seconds, Fwiw.
    Yeah, mine locks in pretty quickly also on build 39 using franco nightly 190, not sure what the cause of the problems for others is. Only time I had an issue was using linaro build.
  6. #1156
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by atlas9171 View Post
    I'd guess more often than not they didn't wipe when they flashed, restored bad data, are victim's of coincidence and just got some slow locks in a bad area or at a bad time, are exaggerating the issue (not on purpose probably, but still) .. Or some combination of all those possibilities
    As is the case when you experience bugs that most other people are not, it's usually, logically, something you did.
    EDIT: just tested again for the heck of it and it locked on in like 6 seconds..
  7. #1157
    Probably all pretty logical reasons, I know I came from a different ROM so I wiped which could be why I'm having no problems, I checked mine a few times and every app locked in within a few seconds.
  8. #1158
    AZDROIDX's Avatar
    Posts
    ROM
    Bugless Beast- GNex
    Quote Originally Posted by dmmarck View Post
    I've tried 14xx and currently on 13xxMHz, really don't see much over 12xxMHz where I usally stay at. I do like the new 576MHz though. Love AOKP and Franco combo!
  9. #1159
    Posts
    Global Posts
    6,872 Global Posts
    ROM
    BB JB
    Did a full wipe, restored data, didn't work. did full wipe, downloaded app, still no go. I am in a fringe 4g area though.
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  10. #1160
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Default
    Yeah, my phone is getting redonculously hot with the new nightly kernel 192 Franco. Phone will restart on high cpu usage like GPS.
  11. #1161
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    What are your settings?
  12. #1162
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Default
    1.5 ghz high, 729 low, Wheatley gov. Voltage settings haven't been touched.
  13. #1163
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    It's probably the overclocking, if I had to pinpoint it to anything.
  14. #1164
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Default
    Which was fine on build 191. I've reset it to 1228 and just wait for an updated build to try it out again.
  15. #1165
    bbudnick5001's Avatar
    Posts
    ROM
    AOKP/CM10/AXIOM ROMs
    Default
    Updated build out r194
    Sent from my GT-I9300 using Android Central Forums
    Thanked by 4:
  16. #1166
    build 40 is out
    Thanked by 3:
    dmmarck likes this.
  17. #1167
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by ultravisitor View Post
    build 40 is out
    Yes it is
  18. #1168
    DroidDev's Avatar
    Superstar Status
    Posts
    Global Posts
    689 Global Posts
    ROM
    AOKP M5 / Franco
    Default
    Anyone notice when you lock the phone it will still allow you to pull down the notification shade? Defeats purpose of lock screen. Anyone know how to disable that?
    I'm on build 39.
  19. #1169
    oxymoron's Avatar
    It's been real...
    Posts
    Default
    Quote Originally Posted by DroidDev View Post
    I'm on build 39.
    As in slide to unlock? Because that's just AOSP ICS. If you have a password/pin/face unlock set and can still pull down the notification, that's another story.
    *customized tapatalk signature*
  20. #1170
    DroidDev's Avatar
    Superstar Status
    Posts
    Global Posts
    689 Global Posts
    ROM
    AOKP M5 / Franco
    Default
    Quote Originally Posted by oxymoron View Post
    So being able to pull the shade down while phone is locked is per requirements? There a way to not allow the shade to be pulled down when phone is locked like in GB? I don't like people being able to see texts when phone is locked
  21. #1171
    KineticMD's Avatar
    Would-be Doc
    Posts
    ROM
    Friggin' Jelly Bean
    I'm on build 39.
    Isn't that just a standard feature of Ice Cream Sandwich? The 4+ months I was unrooted I could do that with my GNex too.
    EDIT: Wow, lots o' folks beat me to the punch!
  22. #1172
    KineticMD's Avatar
    Would-be Doc
    Posts
    ROM
    Friggin' Jelly Bean
    Question: When you're just upgrading to a new build (ie. 39 to 40) do you still need to wipe your whole phone before flashing, or can you just flash overtop of your current ROM?
    I be a root noob.
  23. #1173
    oxymoron's Avatar
    It's been real...
    Posts
    Default
    Yep. Stock ICS. As for a way to circumvent the circumvention... not sure. It doesn't bother me. I just use a pin lock when I leave my phone laying around (I.e. at work). It's in my pocket 99% of the time however. I hear ya about the texts though.
  24. #1174
    oxymoron's Avatar
    It's been real...
    Posts
    Default
    Quote Originally Posted by KineticMD View Post
    I be a root noob.
    Best practice = yes. You can get away with not doing a complete data wipe many times when flashing from one build to the next (considering there aren't major changes... devs will let you know), but you can't expect any ROM support if you have issues and you didn't do a full wipe.
    I've done it a lot, and MOST of the time it's okay. Occasionally it isn't, then a full wipe is required to fix it anyway. Soo... it's up to the flasher's discretion (but I recommend a full wipe always).
    You'll have fun either way though
  25. #1175
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Everything Oxy said. If you want to dirty-flash, wipe cache, dalvik and (recommended) format /system. Flash the ROM and Gapps. If you run into any issues at all, force closes, errors, weird glitches, whatever, assume it's probably because you dirty-flashed, you dirty, dirty vagabond (jk, I do it sometimes), and you'll need to do a full wipe and flash to fix.
    Thanked by 2:
