Results 1 to 6 of 6
    Default After flashing ROM....Nexus stuck in boot. Need Help Bad
    I need help. I used the Wug's Galaxy Nexus Root Toolkit, to root and unlock. I downloaded rom manager and flashed clockwork mod. After several attempts I even got it to load in recovery mode. I then tried to install "codenamed-droid" ROM and when it restarted it just gets stuck in the 4 color boot animation.
    I have pulled the battery 4 times and still nothing...I can't even get to recovery mode to factory reset it. I really need help.
  2. Thread Author  Thread Author    #2
    Default Re: After flashing ROM....Nexus stuck in boot. Need Help Bad
    nevermind... I got fixed
  3. #3
    what did you do to get it going?
  4. #4
    usually bootloops are caused by forgetting (or not wanting) to wipe data/cache
    at least that's been my experience.
    Nexus 4 / Stock | Nexus 7 / Stock | TFPrime / Hairy Bean 2.1.1
    @digitalslacker
    +digitalslacker
    Default
    Quote Originally Posted by Tonyo50138 View Post
    It took a moment but I pulled the battery and as soon as I put it in I held the volume buttons and power and got into recovery mood. After that I factory reset and it restarted. I then flashed the rom without rom manager and it all worked.
    Default
    Quote Originally Posted by digitalslacker View Post
    I wiped it clean, because I had done a complete backup. I think I had a bad download of the rom.
