Results 1 to 6 of 6
    Coleus's Avatar
    Banned
    Posts
    ROM
    stock 4.0.2
    Default What Features of Titanium Pro Make it Worth the $6.58?
    compared to the free version? $6.58 seems like a lot for an app.
  2. #2
    orlanka's Avatar
    Posts
    Global Posts
    246 Global Posts
    ROM
    Atom on Nexus
    Default Re: What Features of Titanium Pro Make it Worth the $6.58?
    I wondered the same, but it really, for me anyway, came down to convenience.
    I am not that technical so I don't do much more than the batch operations of backing up, verifying my backups and restoring apps after loading a new rom. With the pro version I am able to do my restore with basically the one click to kicking off the batch run rather than having to agree to installing each app individually.
    I am sure there are others out there that can answer to the more advanced options
  3. #3
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,356 Global Posts
    ROM
    NOS M7 Sense 5.0
    Not really sure beside that like posted ^^^ you don't have to agree to each app when restoring, to me that feature is worth it if you flash new or updated ROMs a few times a week.
  4. #4
    jpprice's Avatar
    Posts
    Global Posts
    446 Global Posts
    I'm not sure if its still this way, but the Pro version lets you freeze system apps and such and the free version does not. I have not used the free version in a long time, but I think this used to be the case.
  5. #5
    dzyuba's Avatar
    Posts
    Global Posts
    29 Global Posts
    Also some of the handy features that I have used:
    1. Multiple backups per app
    2. 0-click batch restore
    3. Market Doctor (relink apps to Market)
    4. Sync to/from Dropbox
  6. #6
    The best part for me was when restoring apps you don't have to click install for every app. OMG that was annoying.
    Thanked by:
B
