Results 1 to 8 of 8
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Vitreous,JellyBelly,OEM
    Default Stock ICS UI sound files
    Does anyone have the stock ics UI sound files? They're in .ogg format. Found in system/media/audio/UI. Im running codename android 1.1.4 and it sounds to me like the UI sounds are from gingerbread. :thumbdown::banghead:
    ***GET IN WHERE YOU FIT IN***
    Snitches get stitches
    Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
    Living Dead-iPad3,GalaxyNexus,Razr MaxxHD
  2. #2
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Dl bugless beast and use something like 7zip to pull out of the media folder. I know that rom is all ics.
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default
    Quote Originally Posted by tntdroid View Post
    I had a buddy zip the sounds together for me. Skatedawg gets the credit for this one. I'll post a dropbox link for anyone else that may want the files as well. :thumbup:
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default
    Stock ICS .ogg sound files
  5. #5
    Default Re: Stock ICS UI sound files
    Can these just be flashed via clockwork?
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default
    no. The file needs to be "extracted" using a file explorer. I use root explorer. Then copy/paste them into system/media/audio/ui. It will replace the sounds you have. Then reboot. Enjoy yo self!
  7. #7
    Thanks for this, I hate the touch sound from Gingerbread, it sounds like Cesar Milan when hes training a dog, lol
  8. #8
    This is great just wish they were a little louder...
