Halo
Re: Can't Get Phone to Charge or Connect to adb after Flashing Ke
Okay, that makes more sense. So as long as you're in the bootloader menu, you're able to initiate adb commands.
With that said, you'll have to be in the bootloader menu before you start typing commands. In my factory reset steps above in Step 4: the first thing you do is type "adb reboot boatloader"
This is not going to work for you seeing as your phone/computer only communicate when your phone is in the bootloader menu. So you'll just have to manually get your phone into the bootloader and then proceed with the command directly after that one "fastboot flash bootloader bootloader-toro-primekk15.img" And then continue from there.
Thanks, I'll try your factory revert method and get back to you. As for Odin, I am familiar with it as I used it with my old Droid Charge as well, but I thought you had to actually have a working PC connection for that. My computer refuses to acknowledge the phone unless it's in bootloader/fastboot. I'll try it anyway, I haven't had to use it since I got the gnex.
