Results 1 to 2 of 2
    farbster's Avatar
    Posts
    Global Posts
    42 Global Posts
    Default battery life improvements
    I have the extended battery in my Verizon Samsung Galaxy Nexus. I'm rooted and running Gummy-TORO v.0.7.6 with Android 4.03, baseband version I515.09 v.ek05/I515.Ek02 and kernel 3.0.18-imoseyon-1.9.0-04417-gcef4285 imoseyon@ubunu#408
    I would like to improve the battery life and am open to suggestions. Not sure what to do on the Gummy Settings/Performance Settings screen.
    Thanks for all your help!
  2. #2
    Default Re: battery life improvements
    Franco kernel does OK for battery life but any additional gain is going to be minimal.
    Chances are if you are like most users the biggest drain is your screen, and by a pretty big margin.
    Nexus 4 / Nexus 7 / Transformer Prime
    @digitalslacker
    +digitalslacker
B
