Results 1 to 9 of 9
    dmx434343's Avatar
    Posts
    Global Posts
    52 Global Posts
    Default Nexus stuck on battery symbol - Wont turn on
    Need a bit of help.
    Was trying to get back to stock img and now my phone will not get past the battery logo (after battery pull)
    I have tried to get it to go into the bootloader but its just stuck on displaying the battery, computer will not recognize the phone so i cannot abd any commands. Any ideas?
    CWM is on the phone via Rommanger (unlocked and rooted)
  2. #2
    twindragons187's Avatar
    Posts
    Global Posts
    503 Global Posts
    ROM
    Stock!!!
    Default Re: Nexus stuck on battery symbol - Wont turn on
    is it disconnected from the usb cable when the battery symbol stays on? if all else fails, you can use odin to restore back to stock unrooted. this does not affect the bootloader(still unlocked) and just have to reroot the stock rom again. hit xda up for the how-to with odin
  3. #3
    So after a battery pull, if you hold down both up and down volume keys while holding the power button, that doesn't get you into recovery? If it does, you can restore the latest nandroid back up that I'm sure you made.
    Semper Fi
    I love my LG Nexus 5!
    Take better pictures with your cell phone camera...http://www.bigshotmoms.com/
    dmx434343's Avatar
    Posts
    Global Posts
    52 Global Posts
    Quote Originally Posted by twindragons187 View Post
    When not connected to USB cable it will turn off after a few minutes, when connected it always shows the symbol (as if my battery is not getting a charge)
    Oden will work even though i cannot get the phone to recognize???
    dmx434343's Avatar
    Posts
    Global Posts
    52 Global Posts
    Quote Originally Posted by greydarrah View Post
    Correct, holding power and up down volume does NOT get me into recovery. I made a backup using rom manager... which i cannot get to, as i cannot even turn on the phone at this point.
  6. #6
    Posts
    Global Posts
    503 Global Posts
    ROM
    Stock!!!
    volume down and power will get you into odin. check the how to over at xda, the phone should work with odin regardless.
  7. #7
    The links to the ODIN files in the OP no longer work. Post number 47 in the link below has them:
    [ODIN][ROM][ICL53F][FACTORY] Full Factory ODIN restore 4.0.2 with radios - unrooted - Page 5 - xda-developers
    Semper Fi
  8. #8
    From what you described, I can't help but wonder if your batter is completely dead. Do you have another charged battery you could try?
    Semper Fi
    dmx434343's Avatar
    Posts
    Global Posts
    52 Global Posts
    Worked like a charm!
    What ROM/Kernal do you recommend for best battery life but closest to stock?
    Thanks again guys appreciate it.
