Results 1 to 7 of 7
    BringMeBack9801's Avatar
    Posts
    ROM
    AOKP
    Default Strange Charging Behavior
    Some strange things I've noticed with my battery:
    1. The battery level will say 100%, but it will still say "charging"
    2. If I don't take it off the charger when it reaches 100%, it will start to discharge again, even though it's still on the charger.
    Anyone else have these issues or do I have a bad battery?
  2. #2
    Default Re: Strange Charging Behavior
    Provide more details like modifications to the phone.. oem charger... etc.
  3. #3
    Also, have you tried a battery pull?
    Semper Fi
    I love my LG Nexus 4!
    Posts
    ROM
    AOKP
    Quote Originally Posted by jonsnowden View Post
    Rooted, AOKP Build 21, Franco Kernel, OEM charger, stock battery, never leave it on the charger overnight.
    Quote Originally Posted by greydarrah View Post
    No, haven't tried it. I have tried clearing battery stats, but to no avail.
  5. #5
    Default
    Battery is fine. It will say full when its truly at 100% so it will lie to you. Also power is cut off as to not damage the battery from over charging it will drop to a certain voltages then resume. If you Google charging lithium ion batteries it will give more information than you could ever want or need on the subject.
  6. #6
    Quote Originally Posted by gsxraddict View Post
    +1 on that
    the theory is that trickle charging lessen the number of charge cycles LIs can have. So rather than continually pumping juice into a full battery and risking damaging it, it'll discharge a few percent and then start charging again.
    At least that's what Google told me a while ago.
    Nexus 4 / Stock | Nexus 7 / Stock | TFPrime / Hairy Bean 2.1.1
    @digitalslacker
    +digitalslacker
    Posts
    ROM
    AOKP
    Quote Originally Posted by digitalslacker View Post
    +1 on that
    Good info. Thanks!
