Page 11 of 11 FirstFirst ... 891011
Results 251 to 272 of 272
Like Tree35Likes
  1. #251
    tcapote's Avatar
    Geek Freak
    Posts
    Default Re: [ROM][6/19/12] CyanogenMod Nightly Builds - OFFICIAL!
    Anyone else looking forward to the next nightly with updated CM wallpapers!
    And of course more rom fixes too!
    There is no place like 127.0.0.1
  2. #252
    hyminameisderek's Avatar
    Posts
    ROM
    JellyBean! Franco Kernel
    Default
    Quote Originally Posted by tcapote View Post
    I wish they'd incorporate more customizations. I switched to AOKP last week and haven't looked back yet
  3. Thread Author  Thread Author    #253
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    That does look interesting. Hate how "blurry" the stock CM wallpapers are on this phone.
  4. #254
    tcapote's Avatar
    Geek Freak
    Posts
    Just flashed 0624 nightly, wallpapers look good. Lots 'O patches!
    Also flashed Franco r194, will monitor.
    Thanked by:
  5. Thread Author  Thread Author    #255
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: [ROM][6/26/12] Official CyanogenMod - Nightly & RC Builds!
    Updated with 6/25 nightlies PLUS the 6/26 Maguro/GSM RC1!
    Thanked by:
  6. #256
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,107 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Default
    Hope the RC for toro is available soon.
    Sent using Tapatalk 2
  7. Thread Author  Thread Author    #257
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: [ROM][6/26/12] CyanogenMod 9 - Official Nightly & RC Builds!
    Quote Originally Posted by NotJustAPhone View Post
    If you define "soon" as "now," then your wish is my command.
    Thanked by 2:
  8. #258
    00_wrath_00's Avatar
    Posts
    ROM
    Running Quattrimus ICS
    Default
    Downloading now !
    dmmarck likes this.
  9. Thread Author  Thread Author    #259
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    All Galaxy Nexus models have an RC1. Please check the OP for your corresponding model, and also, don't forget GAPPs!
  10. #260
    Default
    Should we do a full wipe before install of the rc, or just do the standard dalvek/cache wipe?
  11. #261
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by captaincaveman View Post
    As usual, do whatever you like.. If you dirty flash and have issues you know what to do
    zero neck likes this.
  12. #262
    chubb's Avatar
    Posts
    ROM
    Stock Xoom, Nexus 4 AOKP
    Default
    For the nightlies I didn't. But for the RC I used Titanium backup(Pro is worth the money since you can restore all apps and data at once not app by app like the free one) and did a full wipe just to be safe. After flashing just install titanium from the market and restored my apps + data and I'm right back to where I was. Love not having to resign in to all my apps and not losing any game progress!
  13. #263
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by chubb View Post
    Make sure you don't restore system data or Google app data with tibu, otherwise that's fine. Most apps that sync are a bad idea to restore data to. Signing into everything again only takes a few minutes, while taking a shortcut that results in errors and FC's will usually require you to do a full wipe all over again.
  14. #264
    chubb's Avatar
    Posts
    ROM
    Default
    Quote Originally Posted by 2defmouze View Post
    That's true. Another thing I just restore what has a Smiley face next to it, I don't restore ones with a check. I believe those are mostly system apps. But I have been lucky so far with banking apps, tapatalk and a few others having no problems with sign in after restore. But what you said is something to keep in mind. As they say YMMV
  15. #265
    any word on the next CM9 linaro release? or is it already in the nightly
  16. Thread Author  Thread Author    #266
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by PrimeDirective View Post
    Kondik came out like a week ago and said they've been incorporating bits into it but whatever optimizations (I think a toolkit) were "shown off" aren't going in immediately. Let me find the post on G+ and link it...
    NM, here it is:
  17. #267
    bgapfire's Avatar
    Posts
    Global Posts
    89 Global Posts
    ROM
    Stock/ rooted
    QQ's... What is an RC? I am currently using a nightly from 6/24. Would the RC be a better version to use at this point? This is the first ROM I've ever flashed and it is pretty cool. I now understand the frenzy and excitement of owning a Google device, specifically the Nexus.
    Also, is it safe to assume that CM will build upon JB in the near future? JB's features look great.
    Thanks in advance for any response.
  18. Thread Author  Thread Author    #268
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by bgapfire View Post
    An RC = release candidate. It's a great, "stable" version of the CM9 rom.
    I presume CM9 will build on JB once the source code comes out (although it'll probably called CM10!)
    Thanked by:
  19. #269
    bgapfire's Avatar
    Posts
    Global Posts
    89 Global Posts
    ROM
    Stock/ rooted
    I really appreciate your quick response. You are a beast on these forums!
    Thanked by:
  20. #270
    tcapote's Avatar
    Geek Freak
    Posts
    Can anyone tell me what the updates on the 0703 nightly, specifically:
    Battery Light: Add ability to configure (Part 1 of 2)
    Battery Light: Add ability to configure (Part 2 of 2)
    Do these add a battery light status/notification? Charging, charged, low?
    Thanks in Advance!
  21. #271
    tcapote's Avatar
    Geek Freak
    Posts
    Default
    Great news, Google Voice VM play back in the call log is working again, in the 0708 release! Yeah, progress!
    Transmitted from a banned Toro Gnex running CM9 and Franco, via Tapatalk2
    Thanked by:
  22. Thread Author  Thread Author    #272
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    I've been sorely neglecting this. I'll get to it today
