Page 4 of 11 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 272
Like Tree35Likes
  1. #76
    Default Re: [ROM][4/4/12] CyanogenMod Nightly Builds - OFFICIAL!
    I am on 3/31 with franco 3.0.8 with cpu_1 off when the screen is off and battery is good
  2. #77
    is there a axiom crossbread for GSM galaxy nexus
    I hope it is
  3. Thread Author  Thread Author    #78
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by cedric101 View Post
    I hope it is
    I believe there might be. Try looking in RootzWiki or droidHIVE.
    Also, wrong thread
  4. #79
    After flashing cyanogen and gapps, how can I restore my apps from my stock rom? I used Wug's Galaxy Nexus Root Toolkit and did an "apps backup" -- It has the option to restore apps but I'm scared to do that with a different rom installed. Is that the proper procedure?
    Thanks!!
    EDIT >> Decided to dive right in... did an app + data restore. It's in progress right now. Fingers crossed.
  5. Thread Author  Thread Author    #80
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Hope it works out . I never restore apps/data, I just let market restore do it's thing.
    BTW, I've returned home and am running the 4/4 Toro. Will post the link shortly!
  6. #81
    hyminameisderek's Avatar
    Posts
    ROM
    JellyBean! Franco Kernel
    can someone post the 04/04 changelog? It will not load at my work and I'd like to know what tweaks they did. I don't see that any of the "Preference Stubs" have filled in to add more features.
  7. Thread Author  Thread Author    #82
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    For some reason under 4/4 it's blank? There are 2 things for "the next nightly" though. Anyone else seeing that?
  8. #83
    Posts
    ROM
    I just decided to quit being lazy and pulled it up on my phone. yea there is nothing under the 04/04. The next nightly says they are fixing LTE support...I myself haven't experienced much problems with the LTE
  9. Thread Author  Thread Author    #84
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Me neither...I also have the 4.0.4 radios, so it'd be interesting to see what they do there.
  10. #85
    Posts
    ROM
    Are the 4.0.4 radios a separate flash or is it included when CM9 went from 4.0.3 to 4.0.4? I've only flashed CM on any of my phones and I usually don't do much tweaking or addl flashing other then the Google Apps because I know that's a necessity.
    But I hear other people talking about flashing different Kernels, etc...gets a little confusing
  11. Thread Author  Thread Author    #86
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by hyminameisderek View Post
    Flash separately. The radios are usually not "included" with a rom unless it explicitly says so. Therefore, the radios are always constant--you have what you have unless you change them.
  12. #87
    Posts
    ROM
    do you have a link for the radios? I use rom manager and I don't see that the radios are on there
  13. #88
    Posts
    ROM
    found em...I was still on 4.0.2 radios. It'll be nice to see what a difference this will bring
  14. Thread Author  Thread Author    #89
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: [ROM][4/7/12] CyanogenMod Nightly Builds - OFFICIAL!
    Updated for yesterday's builds!
  15. Thread Author  Thread Author    #90
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    For radios, a great package is featured in my AXI0M thread--it's called the get ready package. I've had zero problem running the 4.0.4 radios (and that package specifically) across 5 different roms at this point.
    I suggest wiping cache/dalvik before flashing them. In theory, you want to flash them before you flash a rom (so if you're going to flash 4-7-12 nightly, do ALL wipes, flash get ready, then flash the rom).
    However, you don't necessarily "need" to do it in that order. The radios really affect nothing with the rom, so you can just go in and flash. Also, I believe there was a 4.0.2 to 4.0.4 radio thread in this forum a while back. Check that out; there should be links to the 4.0.4 bootloader + radios package.
  16. #91
    Posts
    ROM
    Default
    Thanks. I got the radios but the didn't include the new bootloader. Is there an advantage or disadvantage of not updating the bootloader?
  17. Thread Author  Thread Author    #92
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Honestly, I have no idea. I know the package usually contains both, but why the bootloader + radios come together beats me.
  18. Thread Author  Thread Author    #93
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: [ROM][4/10/12] CyanogenMod Nightly Builds - OFFICIAL!
    Updated with the 4/10 Maguro build. Also, CM fans, if you didn't know, here's the new CM mascot, appropriately called CID.
  19. Thread Author  Thread Author    #94
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: [ROM][4/12/12] CyanogenMod Nightly Builds - OFFICIAL!
    For the folks on the nightly express, the OP has been updated with the 4/12/12 release
  20. #95
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Quote Originally Posted by dmmarck View Post
    I used to rock cm on my x but have been using bugless beast on the nexus. Might have to give cm a run this weekend.
    Thanked by:
  21. Thread Author  Thread Author    #96
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by tntdroid View Post
    I've run ~7 different nightlies, and each has been impressive. The new boot animation is awesome. I haven't flashed this one (yet), but I presume Cid will be on it (and if not, then soon enough!).
  22. #97
    FD2
    FD2 is offline
    FD2's Avatar
    Shadow Lurker
    Posts
    Global Posts
    376 Global Posts
    ROM
    Stock
    No CID yet. I like it this way.
    I'm not a star, somebody lied
    Thanked by:
  23. #98
    tntdroid's Avatar
    Droiderator
    Posts
    Global Posts
    5,662 Global Posts
    ROM
    Bugless Nexus
    Default
    Flashed this up tonight. I like it. Hopefully my battery likes it.
  24. Thread Author  Thread Author    #99
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    If not, try franco. I know that's like the "go to" of GN roms, but really, it's fantastic w/ CM9
  25. #100
    Posts
    ROM
    Default
    Anyone having call quality issues? I've noticed sometimes mine will make a loud beep and then there will be a lot of screeching through the convo. I don't make many calls but just noticed it on this nightly
