captaincaveman
5/2 is out (two of them actually)
I think another one just came out today (3 total)....i guess we can call these "hour-lies" now
5/4 is up and the next nightly is a huge change log
Can you point me to the change log. I searched and just found the commits. Would like to view the entire change log.
Thx.
here's the log for VZW device. Others are also on the first page http://cm-nightlies.appspot.com/?device=toro
Thanks. I forgot to go back and check the OP
Looking forward to some features being added to the nightly.
5/7 is up and as promised lockscreen shortcuts are available and themes as well. However only the system theme is available right now
With most all other Androids that had developer support, it seemed like Cyanogen was the "it" ROM to have...coveted by all. Why does it not seem this way for the gn? Is the Cyanogen team loosing their touch, or are just a ton of more active developers now? I'm not trying to start trouble, I just find it odd how quiet the whole Cyanogen world is for this phone.
Does anyone else have lag on CM9 when using it after a few minutes? When I grab my phone and hit the power button it lags when I try to pull down the notification bar or just unlock it. After it gets going it is fine but it takes like 5 seconds or so to get up to speed. I have the stock kernel and I have tried Interactive and On Demand for the governor setting with no change. Stock 4.0.2 was instant all the time.
I'm running the 5-7 nightly
