[ROM][5/23/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
dmmarck
Retired Moderator
Dec 28, 2011
8,348
2,594
[NOTE]Note -- I am not affiliated with DroidTh3ory in any way, shape, or form. I am simply an evangelist of his work, acting as the middle man to give, the fine members of Android Central, a place to find, download, and discuss all things related to his incredible work. If you enjoy DT's work, I strongly advise finding him on droidHIVE and throwing a donation his way. Further, if you enjoy any work done by associated developers, please donate to them as well. They do this for free and we reap the benefits of their generosity and genius!
[/NOTE]
[WARN]Remember, flashing is serious business. Don't mess around and be careful. If you take precautions, you will be rewarded with such pleasantries as 8 app lockscreens, sick boot animations, and buttery awesomeness.[/WARN]
This thread focuses on two of DT's creations--CROSSBREED and his nightly builds called PATIENT ZERO. Currently, CROSSBREED is "dead" (no longer updated), and PZ appears to be on the same path with the release of his newest rom, MORFR (see the MORFR thread in this same forum for more details). If you wish to download and flash these beasts, please continue reading. For more information, follow the respective information threads. Generally, DT can be found on droidHIVE, so when in doubt, check there!
DroidTh3ory's AXI0M CROSSBREED MONOLITH
[INFO]This rom is a 4.0.4 rom; it's a hybrid that DroidTh3ory created using Team Kang's AOKP (Milestone 4, currently), the leaked 4.0.4 base, and what appears to be highly complex sorcery. The latest stable release is Monolith B2. Unfortunately, however, it is currently "unsupported"--meaning its development is dead. As such, please use the informational links to find prior releases.[/INFO]
RootzWiki Informational Thread
droidHIVE Informational Thread
Latest Files:
[TIP]Here's what I did to install the above package. This is based upon what DT says to do, and it (obviously) worked.
(1) Put both files (if you want the new radios) on the SDcard
(2) Wipe DATA/FACTORY RESET
(3) Wipe CACHE
(4) Wipe DALVIK
(5) Go to Mounts/Storage in CWM, then FORMAT SYSTEM
(6) Flash RADIOS (if you want them--it's the Get Ready Package)
(7) Flash ROM
(8) Reboot
[/TIP]
[WARN]For the radios, this step is reversible. I know there's a 4.0.2 bootloader/radios package floating around here. Remember, unless a rom states otherwise, radios/bootloaders are separate beasts. Further, while I personally believe the flashing "order" is moot, it's advised that you flash the radios before the rom (hence the name of the package, I guess?). Remember, follow the instructions and be careful, and all will go well.[/WARN]
AXIOM CROSSBREAD MONOLITH FEATURES:
LEAK 4.0.4 WITH MERGED AOKP Source
FRANCO R85 Kernel
Advanced Install Script
Integrated Google Apps 4.0.4
Modded Busybox 1.20 (Large File Support/Color Fix)
FULL INIT.D Support
MasturMOD Settings
Cron Running
GAMMA Color Tweaks
FULL DSP Manager
VZW Support for APPS
Th3ory Go Faster Script (Speed, Fluidity, Battery Life, RAM Management)
Max FPS (240)
Cron Script
Force Home Launcher in GPU (Software)
Disable Kernel logging (Speed)
Max JPEG resolution to 100%
ZRAM Compatible (Settings/Performance)
SD Read Speed
Zipalign At Boot
MasturMODS Settings
Shorter Ring Delay (Connect Call Faster)
Proximity Sensor Hack (Light Up Faster)
VZW App Support
Launcher Choices:
Launcher2
NOVA Launcher
APEX Launcher (My FAV) Any others can be removed from /system/app
TON of Extras Tweaks
Latest changelog:
3/15:
New CMPLXTH3ORY Script
New INIT.D Management
Scaling VM (Dalvik) MAX HEAP
3/20
New Kernel (M2)
Latest B28 Commits Merged
Introducing My New CMPLXTH3ORY Script
Cleaned Some Bloat
Clean Up MORE mess
All PROVEN Tweaks from Patient Zero Merged
Many Fixes
Removed MasturMODS Dues to Compatibility Issues
Many System Tweaks and Tuning ( Be Fast)
For nightly programming, you want AXI0M PATIENT ZERO...
For more information, please visit droidHIVE's information thread.
(Note--do NOT download a new version unless DT (or us after hearing from DT) give the go-ahead!)
Want to crackflash & download this mother? Latest files . . .
[TIP]For installation of the PZ roms, DT has included a script that will do the wipes for you. Can you still wipe on your own? Of course! But now it's no longer necessary. For new users, the CMPLX script wipes EVERYTHING--data, cache, etc. For prior users, it usually only wipes cache/dalvik. For ALL users, it wipes everything.
Therefore, trust DT and ==>
(1) Download it/place on SDcard
(2) Flash it
(3) Reboot[/TIP]
AXIOM PATIENT ZERO FEATURES:
FULL INIT.D Support
MasturMOD Settings
Cron Running
GAMMA Color Tweaks
FULL DSP Manager
CMPLXTH3ORY Script (Speed, Fluidity, Battery Life, RAM Management)
Max FPS (240)
Cooked in Color Tweaks
Cooked in Forced HotPlug Enable
Cron Script
SD Read Speed
Zipalign At Boot
MasturMODS Settings
VZW App Support
Boot Animation by "thatguy188"
Launcher Choices:
Launcher2
NOVA Launcher
Latest changelog:
4/2:
Rewrote and ReStructured Script
Rebased to 4.0.4 Source (DRIVEN)
Fixed Market
New System Tweaks
New UI
Bunch Of (Its all New)
4/7:
Full Re-Build
Overhauled CMPLXTH3ORY
Created CMPLX Script Set for INIT.D
Fresh AOKP B30 SWAG Integrated
Patched AOKP B30 Bugs
Updated ALL Apps
Switched to Franco R121 GPU384
Rewrote Logging for INIT.D
Patched For Lean Kernel Compatibility
Re-Tuned Everything
Minor UI Touch Ups
Screamer!!
For the latest news, roms, etc., please follow the given information links.
In the words of DT, "Outty."
[WARN]As of July 2012, DroidTh3ory has ended this rom project and it is no longer being supported or updated. I hope you all enjoyed it as much as I did, and please give credit and respect to all of these incredible developers :).[/WARN]
Re: [ROM][V.5][4.0.4]DroidTh3ory + AOKP = AXI0M Crossbreed
Just peeking in here. I am a total Crossbreed PIMP.
Nice to be first poster in what should be a healthy thread!
CROOSSSBRREEEED! :-P
I hope so!
Get flashin' maties!
Some guys are saying V6 has dropped. Not a peep from DT though.
I'm sure it'll drop today; but without DT himself saying so, I'll wait.
RW is a mass of hysterics, which is sorta adorable. Also, the guy saying he got it may be getting debunked as we speak. Who knows...
Hopefully this release is a simple update affair, because I'm dreading Titanium lol
Edit: I see it on his server as well. I'll wait though.
Flashing this later.
of course there will prolly be an update ten seconds later ..
If you are successful, this is what you'll find.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk
Be careful with this ROM....DT is a beast....I flashed v3 Wednesday, then v4 and v5 on Thursday. Great Time.
And V.6 is out!
Edit: Apparently we're getting another build of V6, if that makes any sense. Hang on to your butts!
Edit Edit: NM, correct build, some issue with what DT thought the filename was.
Lots of changes with this one, notably ditching franco.kernel for trinity. Thoughts, fellow flashers?
wow v 6 ha dt must be updating this every night now ha
PS: is everyone flashing the 4.0.4 radios and bootloader on this .I had the 4.0.4 radios for awhile just havent flashed the 4.0.4 bootloader...yet.
Guess I could just flash the rom and not update the bootloader ?
Maybe flash when I get back from gym
sent from my Galaxy Nexus
Just flash the radios package first and then v6. No harm done by doing that!
Reactions: davidnc
Re: [ROM][V6][4.0.4]DroidTh3ory + AOKP = AXI0M Crossbreed
Quick Question
I am currently on Axiom/AOKP b27 V1 and all of the themes and mods for AOKP work on it.
Will AOKP M4 themes work on this rom? I would like a green or orange theme for St. Paddy's day.
Quick Question
Honestly, I have no idea. You could always nandroid, try it, and restore if he'll breaks loose.
working on that right now, :-\
I will post back in a bit and let everyone know.
Had to pull the AOKP ringers/notification tones and add them to axiom.
otherwise, liking v6. very snappy. about to nand and flash m4 just for old times sake.
Tried two different themes for APOK M4 on this build and it was a no go.
bootloop on one and a loss of softkeys and navigation bar on the other.
AOKP M4 themes will NOT work on this ROM, it will delete some of your gapps because Axi0m is using 4.0.4 gapps. You will have to manually remove them from the M4 zip before flashing.
asnes
