Clean AOSP 4.1.1
build 5 (JRO03R)
for the Verizon LTE Galaxy Nexus (toro)
Twitter: http://twitter.com/javroch_dev
Based off of the AOSP "android-4.1.1_rX" branch. it's a mostly bare ROM, basically just rooted. I'll slowly add the previous features back in subsequent builds. I redid everything clean, from the ground up, for 4.1.1.
NOTE: I don't know if this 4.1.1 release will bring a new kernel with it, when Verizon releases it. As well, I don't know if there will be a new radio/etc, but this ROM does not include those if so. radio.img's aren't released via AOSP as far as I know. Feel free to correct me, if I'm wrong.
Modifications:
The only modifications that I have made are listed below, mostly they include enabling features that are already included in AOSP's source code, but weren't enabled by default:
Here's what's made it so far for 4.1.1:
Here's what's to come in the near future:
Aside from the explicit credit given above, I also spent tons of time looking through the git repo's of cvcps, peteralfonso, cyanogen, and many others. As well, I often used howto.ccroms.net and source.android.com/source as references. I'm sure there are others I'm not giving credit to that should be getting it.
Let me know what you think or if anything is broken! This is still a learning experience for me. Nobody's perfect.
Current Version: https://dl.dropboxusercontent.com/u/66443039/clean_toro-ota-eng.josh-20120922.zip
MD5: 023271a54f428bb2197e667b9033ffe4
GApps: Goo.im Downloads - Downloading gapps-jb-20120726-signed.zip
Previous Versions:
4.1.1 for us with gapps: Goo.im Downloads - Downloading gapps-jb-20120726-signed.zip
build 4: https://dl.dropboxusercontent.com/u/66443039/clean_toro-ota-eng.josh-20120916.zip, md5: 3cc96cc0d703300a52ca885e49f73139
build 3: https://dl.dropboxusercontent.com/u/66443039/clean_toro-ota-eng.josh-20120905.zip, md5: f3dea30b0922e2d67926510a6afd2a31
build 2: https://dl.dropboxusercontent.com/u/66443039/clean_toro-ota-eng.josh-20120831.zip, md5: cbbcadf2ed7a4ca7a516389abe6338af
build 1: https://dl.dropboxusercontent.com/u/66443039/clean_toro-ota-eng.josh-20120829.zip, md5: 69d101d025037c554ea2d0b25b55ad25
build 0: https://dl.dropboxusercontent.com/u/66443039/clean_toro-ota-eng.josh-20120811.zip, md5: 3ad6f6134656b7adf65c6b48c8f5805f
4.0.4 for use with gapps: Goo.im Downloads - Downloading gapps-ics-20120317-signed.zip
build 5: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120418.zip, md5: eb0daa742d56189b770ff0662a984b12
build 4: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120413.zip, md5: 1ec18075db77936b4972a7593a5878ec
build 3: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120407.zip, md5: fbcde7d07617ead21a369756df306304
build 2: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120402.zip, md5: e989c25388feaabee5da92c6c0965b7c
build 1: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120329.zip, md5: 590c36c905cd50a072027bbf9da8b1d1
4.0.3
build 4: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120319.zip, md5: fc1b733d37c8d61c21a3f248b8b6a2b7
build 3: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120318-build3.zip, md5: 53dc910d5e1c23c32c7e4a696d679790
build 2: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120314.zip, md5: 56ccfc3856e0f6ea8e7aaecbbdc7b799
build 1: https://dl.dropboxusercontent.com/u/66443039/javroch_toro-ota-eng.tv.20120308.zip, md5: a373793a69fb193ca162f24a719636b3
build 5 (JRO03R)
Modifications:
- Root/Superuser (ChainsDD)
- Wi-Fi Tethering Subscription Check Removal
- Enabled Backup/Restore
- Google Movies access fix (peteralfonso)
- Root Settings/Selective Root (cyanogenmod)
- Custom "Clean extras" settings panel
- Settings shortcut to Clean extras for easy access
- SIP+VoIP
- Battery Percentage in Status bar (Icon, Text, or Both)
- Fixed Facebook Contact Sync (romanbb)
- Reboot/Safe mode Options in Power menu
- Screenshot Options in Power menu (DvTonder)
- Airplane/Silent Mode toggles via Custom extras
- Number of home screens Option in Clean Extras
Previous Versions:
4.0.3
