DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Page 1 of 3 123 LastLast
Results 1 to 25 of 66
Like Tree22Likes
    Default [ROM] Clean AOSP 4.1.1 build 5 (JRO03R)
    Clean AOSP 4.1.1
    build 5 (JRO03R)
    for the Verizon LTE Galaxy Nexus (toro)
    Twitter:
    Based off of the AOSP "android-4.1.1_rX" branch. it's a mostly bare ROM, basically just rooted. I'll slowly add the previous features back in subsequent builds. I redid everything clean, from the ground up, for 4.1.1.
    NOTE: I don't know if this 4.1.1 release will bring a new kernel with it, when Verizon releases it. As well, I don't know if there will be a new radio/etc, but this ROM does not include those if so. radio.img's aren't released via AOSP as far as I know. Feel free to correct me, if I'm wrong.
    Modifications:
    The only modifications that I have made are listed below, mostly they include enabling features that are already included in AOSP's source code, but weren't enabled by default:
    Here's what's made it so far for 4.1.1:
    1. Root/Superuser (ChainsDD)
    2. Wi-Fi Tethering Subscription Check Removal
    3. Enabled Backup/Restore
    4. Google Movies access fix (peteralfonso)
    5. Root Settings/Selective Root (cyanogenmod)
    6. Custom "Clean extras" settings panel
    7. Settings shortcut to Clean extras for easy access
    8. SIP+VoIP
    9. Battery Percentage in Status bar (Icon, Text, or Both)
    10. Fixed Facebook Contact Sync (romanbb)
    11. Reboot/Safe mode Options in Power menu
    Here's what's to come in the near future:
    1. Screenshot Options in Power menu (DvTonder)
    2. Airplane/Silent Mode toggles via Custom extras
    3. Number of home screens Option in Clean Extras
    Aside from the explicit credit given above, I also spent tons of time looking through the git repo's of cvcps, peteralfonso, cyanogen, and many others. As well, I often used howto.ccroms.net and source.android.com/source as references. I'm sure there are others I'm not giving credit to that should be getting it.
    Let me know what you think or if anything is broken! This is still a learning experience for me. Nobody's perfect.
    Current Version:
    MD5: 023271a54f428bb2197e667b9033ffe4
    GApps:
    Previous Versions:
    4.1.1 for us with gapps:
    build 4: , md5: 3cc96cc0d703300a52ca885e49f73139
    build 3: , md5: f3dea30b0922e2d67926510a6afd2a31
    build 2: , md5: cbbcadf2ed7a4ca7a516389abe6338af
    build 1: , md5: 69d101d025037c554ea2d0b25b55ad25
    build 0: , md5: 3ad6f6134656b7adf65c6b48c8f5805f
    4.0.4 for use with gapps:
    build 5: , md5: eb0daa742d56189b770ff0662a984b12
    build 4: , md5: 1ec18075db77936b4972a7593a5878ec
    build 3: , md5: fbcde7d07617ead21a369756df306304
    build 2: , md5: e989c25388feaabee5da92c6c0965b7c
    build 1: , md5: 590c36c905cd50a072027bbf9da8b1d1
    4.0.3
    build 4: , md5: fc1b733d37c8d61c21a3f248b8b6a2b7
    build 3: , md5: 53dc910d5e1c23c32c7e4a696d679790
    build 2: , md5: 56ccfc3856e0f6ea8e7aaecbbdc7b799
    build 1: , md5: a373793a69fb193ca162f24a719636b3
    Thanked by 6:
    bjs188, davidnc, zero neck and 2 others like this.
  2. Thread Author  Thread Author    #2
    Default Re: [ROM] Clean AOSP 4.0.3
    Just a heads up, I'm in the process of migrating everything over to . As well, I'll be adding facebook sync and possibly one or two more tweaks hopefully tonight. Also, starting with the next release, I'll be naming them "Clean AOSP x.y.z build #". So, the update hopefully coming tonight will be "Clean AOSP 4.0.3 build 2". Any further tweaks / modifications will probably be added to a separate ROM, possibly Clean AOSP+, because I really want to keep Clean AOSP tweak free.
    Default Re: [ROM] Clean AOSP 4.0.3 build 2
    Build 2 posted, includes fixed Facebook Contact Sync. That's about it for now. Next thing I want to do is validate whether or not Google Wallet is working. I've been able to use NFC to beam, etc and everything else seems to be working fairly well so far. Let me know if anybody has any feedback for me
    I tried to see if I could get Twitter's Contact Sync working in a similar fashion, but it seems it's an issue on their end:
  4. #4
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    If i get a chance i'll flash this weekend and test wallet for ya at the gas station
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
    Quote Originally Posted by zero neck View Post
    Awesome, I appreciate it
    I'm not gonna add this as a "Modification" or anything... because I didn't really do anything to fix anything, but I just wanted to confirm that I was successfully able to use Google Wallet on Clean AOSP last night. Apparently, I just needed to "Reset Google Wallet" from when I flashed from stock
    today, i will begin working on implementing the new into clean aosp. i feel that this is really an essential feature for any ROM and so i think this is a necessary modification for clean aosp
    zero neck likes this.
  8. #8
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Javroch - i am going to flash your rom tonight for a test drive if i can finish my school work. I apologize i just haven't found the time yet. When i do i will check on wallet to double check its working. I appreciate the work you've done . let me get you some feedback tonight
    I'm currently uploading build 3. should be up tonight / tomorrow. it includes the root settings menu under developer options. the menu provides four options "Disabled", "Apps Only", "ADB Only", and "Apps and ADB". currently the default in build 3 is "Apps Only", however i will probably be putting out a build 4 which defaults it to "Disabled". my code is mainly based off of cyanogenmod's commits mentioned in the blog post , and functions much in the same way. cm doesn't build Superuser from source, but i do, so I also added some of my own code related to this in Superuser. basically in CM it would say that superuser had granted apps permissions if they were on the whitelist, even when root was disabled via the settings and they didn't actually have root. i plan on launching the developer's settings intent as well, if you get denied superuser permissions because the setting is disabled. this way you can easily re-enable it. but that isn't in build 3.
    i should note that this way doesn't seem to give you access to google play movies. i like to think of it as a selective root, rather than completely removing root altogether. but, the main purpose of this is security, not to enable google play movies. i've been leaving mine on "Disabled", and i really don't find that i have to re-enable root very often.
  10. Thread Author  Thread Author    #10
    Default Re: [ROM] Clean AOSP 4.0.3 build 3
    posted build 3...
  11. #11
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Loaded up. I have to say it's very smooth, and responds very quickly. The root disable feature is very interesting. Since videos doesnt work i dont really see much use for it, myself, but I understand the privacy risks and for the purposes of increasing security it seems like a good implementation.
    Havent tried wallet yet but i'll try to stop and use it this afternoon.
    Thanks javroch, really nice work.
    Thanked by:
  12. Thread Author  Thread Author    #12
    Yea, it's more for security purposes I think. So that some rogue app doesn't try to sneak Superuser privileges, etc. This way, I just turn it on when I need it. Especially with Google Wallet on the phone, I feel like it's much safer. I've actually thought about seeing if I can get it to lock the phone before allowing you to change the value as well, so a stranger can't just pick up your unlocked phone and change the setting at will without knowing your password/pattern, but we'll see how far I get with that.
    I appreciate the feedback. I've been using Google Wallet for a few days now no problem. If you have troubles after flashing between ROMs, etc just "Reset Google Wallet" from the Google Wallet App's settings, it does more than just clear the app's data.
  13. #13
    LNWJ's Avatar
    Posts
    Global Posts
    599 Global Posts
    ROM
    Stock
    This sounds like a very sweet ROM. Do you have future plans to make anything available like this for the Nexus S/Nexus S 4G?
    Haven't rooted yet... but this would probably make me.
    Peace!
  14. Thread Author  Thread Author    #14
    unfortunately, i don't have the phones so it would be hard for me to maintain. theoretically, all i should need would be the results from extract_files.sh from their respective device trees. mainly because they're nexus phones. would be even harder if it was some other device that's not so dev friendly
  15. Thread Author  Thread Author    #15
    Default Re: [ROM] Clean AOSP 4.0.3 build 4
    I wanted to wait and get more features in, but I might be busy for the next week or so. So, here's build 4. The only change is that root is "Disabled" by default
  16. Thread Author  Thread Author    #16
    I just saw that . I'm gonna see if I can't get a build out in the next couple of days, probably just with the features I've implemented for 4.0.3
  17. Thread Author  Thread Author    #17
    Default Re: [ROM] Clean AOSP 4.0.4 build 1
    posted 4.0.4 build 1... as far as I can tell everything seems to work fine, GPS, facebook sync, keyboard auto-correct, wallet, etc. let me know what you guys think
    Thanked by:
  18. #18
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    My thoughts - very clean. and very quick with the stock kernel.
    no frills - a plus in many ways but at the same time it leaves me wanting a few certain things: namely, ROM control (aokp) - not necessarily all the options, but some of them i am so used to having that its hard to go without. Change the carrier label, enable vol buttons to change tracks when screen is off, fast torch, etc.
    Not sure what direction you're trying to take this in the future, but it's a great rom right now and seems like it can compete (on a functional level) with all the current "performance" centric, not options-crazy roms (like bugless beast).
    Anyway, great work man. Excited to see what comes next.
    Thanked by:
  19. Thread Author  Thread Author    #19
    Yea, the idea is to keep it as stock/bug-free as possible and be able to provide timely updates. I'm going to probably implement a bunch more ROM Control type settings in the near future, but I want to try and be as non-intrusive as possible/alter the AOSP code base as little as possible. Since that's part of what allowed me to get this update out so fast.
    I appreciate the feedback and I'm glad you like it so far.
    AZDROIDX and zero neck like this.
  20. #20
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by javroch View Post
    It's very smooth. I would highly recommend it for those who want a stock rooted feel.
    And the update was lightning fast. Thanks again for all the work.
  21. #21
    AZDROIDX's Avatar
    Posts
    ROM
    Bugless Beast- GNex
    May finally try something else other than Bugless Beast, just read Pete may not be updating soon due to school. I've also been tempted by LiquidSmooth with 1.2. This Clean ROM is interesting too.
  22. Thread Author  Thread Author    #22
    Quote Originally Posted by AZDROIDX View Post
    Let me know if you try it out. I'm more than happy to have you! haha. Feel free to leave me any feedback/suggestions you may have, if you do try it out, as well.
  23. Thread Author  Thread Author    #23
    Default Re: [ROM] Clean AOSP 4.0.4 build 2
    posted 4.0.4 build 2. it includes reboot and screenshot options in the power menu. as well, i've built out settings in Settings > Developer options to disable/configure these options.
    the reboot option in the power menu will by default simply reboot your phone when clicked. If you prefer the whole reboot options menu (regular, recovery, bootloader) you can configure this in Settings > Developer options > Reboot option. As well, if you would like to turn off the Screenshot option in the power menu you can do so via Settings > Developer options > Screenshot option. i generally leave it off as I think it's easy enough to take a screenshot in ICS as is via the volume/power key combo, but I figured some of you guys might like it.
    as always, let me know what you think
    Thanked by:
  24. #24
    ibmman69's Avatar
    Posts
    Global Posts
    85 Global Posts
    I installed this ROM last night, and really like it so far. Thanks for the nice work.
    Thanked by:
  25. Thread Author  Thread Author    #25
    Default Re: [ROM] Clean AOSP 4.0.4 build 3
    I just posted 4.0.4 build 3 which includes a "Clean extras" setting panel. This is now the home to all the settings I previously had in "Developer options". I also added a Settings shortcut to "Clean extras", so you can have a shortcut on your home screen if you like. In addition, I added a new setting to toggle the Battery Percentage Indicator that is now present in the Status bar.
    Enjoy
    zero neck and dmmarck like this.
