Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree1Likes
    C-3PO's Avatar
    Posts
    Global Posts
    45 Global Posts
    ROM
    CyanogenMod 9 ICS 4.0.4
    Default Beats Audio Mod
    Anyone have success installing Beats Audio on any custom ROM for our Galaxy Nexus? How do you know if its working or not once installed? On the Rezound when you go into music player there is a Beats notification at the top of the screen letting you know when Beats is enabled and you instantly hear the difference in the sound.
  2. #2
    10001110101's Avatar
    Posts
    Global Posts
    391 Global Posts
    ROM
    There will be many...
    Default Re: Beats Audio Mod
    I just flashed Beats Audio that I haven't had time to test yet. I am running Liquid v1.25. I'll report back later with difference in sound quality.
  3. #3
    Default
    Can you flash beats audio on axiom crossbreed or does it have to be liquid?
    BB Curve 8530
    Motorola DroidX
    Samsung Galaxy Nexus
    Samsung Galaxy S3
  4. #4
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by shanedroid1 View Post
    On the RootzWiki page it says it may work with others, but may not. I know Phase II of Patient Zero (the Crossbreed nightly) incorporated Beats Audio in it.
  5. #5
    Can you install this on a unlocked rooted phone? Or does it have to be installed on a Nexus with some kind of ROM on it?
  6. #6
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by imnotajedi View Post
    Probably the latter. I mean you can always make a Nandroid, flash it, and see if it does anything. Worst case scenario is you softbrick and have to restore your Nandroid . I don't recommend it, but hey, it's your device .
    At least one ROM (Patient Zero, currently at Milestone 1) has it automatically integrated. It's not that bad TBH, and I was a hater at first.
  7. #7
    Droid_Evo_8's Avatar
    Posts
    ROM
    Stock
    BIG difference with Beats Audio turned on on my Liquid 1.25. I don't have DSP Manager so I dunno how much better or different from Beats but I like it.
  8. #8
    vincentallen2's Avatar
    Posts
    ROM
    Stock Sense 3.6 ICS 4.0.3
    Default
    Do you think this could work on a Nexus S 4G? It would be amazing if it did =D
  9. #9
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    I think dsp is just a separate control for equalization and such. I'm digging the beats in PZM1 :-)
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk
  10. #10
    Posts
    ROM
    Stock
    Quote Originally Posted by vincentallen2 View Post
    I dont have a Nexus S so I can't confirm that. Best way to find out is to make a nandroid backup then flash that mod.
    Quote Originally Posted by dmmarck View Post
    I think that's what the Beats does that too. Either way, I'm digging the Beats also.
  11. #11
    rldev's Avatar
    Posts
    Global Posts
    113 Global Posts
    How do you enable it in Liquid 1.25. I flashed it, but don't see how to enable it. I see nothing under "Sound" in settings.
  12. #12
    Default
    I use equalizer with Franco kernel on my gnex...works very well.
    Sent from my Transformer Prime TF201 using Tapatalk
    Nexus 4 / Stock | Nexus 7 / Stock | TFPrime / Hairy Bean 2.1.1
    @digitalslacker
    +digitalslacker
  13. #13
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Quote Originally Posted by rldev View Post
    I think it's automatically integrated
  14. #14
    Posts
    ROM
    Stock
    It's under "Sound Effects", not settings.
  15. #15
    steveinil's Avatar
    Posts
    ROM
    aokp 34
    where is the download? did you clear data or cache or anything or just back up and flash it? sorry still new to all the rom flashing lol
  16. #16
    Posts
    ROM
    Stock
    Quote Originally Posted by steveinil View Post
    And you're welcome.
    Thanked by:
  17. #17
    steveinil's Avatar
    Posts
    ROM
    aokp 34
    thanks got it i didnt see it in sound effects though is it just automaiticly on?
  18. #18
    kca2000's Avatar
    Posts
    ROM
    "Shiny" Stock Android
    I was looking around for this last night on PZ? Any setting or notification to let you know its working or on? or do we assume its on all the time?
  19. #19
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Yes. Third party usage (i.e. Spotify/Pandora) probably doesn't work, but for native files/Play Music it should make a difference.
    Thanked by:
  20. #20
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by kca2000 View Post
    Like my post above, it should be on--functioning through DSP--nonstop for your native music and the Play Music app.
  21. #21
    kca2000's Avatar
    Posts
    ROM
    Sorry, when i posted i didnt even notice a second page, This is what i get for posting fresh out of bed... lol
  22. #22
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    No worries, I do the same. It does in fact work w/ Play Music. Was tinkering with DSP and such. I can also confirm that neither DSP nor Beats have any effect on Spotify/Pandora (been testing with my main earbuds, NuForce NE-700X where everything is crystal ).
  23. #23
    kca2000's Avatar
    Posts
    ROM
    Default
    Anyone know if beats works with AOKP? I'm gonna be switching from PZ to AOKP MS5 for awhile and I don't want to loose it if possible. Anyone have any experience with running it on AOKP? If so where did you download it from? Thanks!
  24. #24
    Posts
    ROM
    Stock
    I don't have any experience yet of the Beats Audio mod on AOKP, but if you want to try it, don't forget to make a backup first in case things go wrong.
    dmmarck likes this.
  25. #25
    I'm on AOKP, does it just show up under sound effects because I don't see it but I do have the default profiles under sound effects.
