Results 1 to 12 of 12
- 04-02-2012, 07:16 PM
Thread Author #1
CWM Recovery Won't Stick, Reverts To Old Recovery
Today I was deciding to flash a rom for the first time. I am unlocked and rooted. I had all the necessary things to get started, but I noticed that I did not have CWM flashed (I originally had, but it reverted). I flashed it through Rom Manger, and it came up. Once I reboot, it reverts back to the old recovery. I even did it manually (flashed CWM touch). It always reverts back. Can't seem to find a solution.
- 04-02-2012, 07:21 PM #2Former moderator & advisor.
HTC - the One to rule them all.
- 04-02-2012, 07:28 PM
Thread Author #3
- 04-02-2012, 07:32 PM #4
Re: CWM Recovery Won't Stick, Reverts To Old Recovery
Whats important is the step about deleting (or renaming) recovery-from-boot.p from /system. If that file is intact, then on the stock ROM you need to reflash CWR every time you reboot. When you flash a ROM you won't have the problem anymore anyway because its taken care of in every custom ROM.
- 04-02-2012, 07:35 PM
Thread Author #5
- 04-02-2012, 07:38 PM #6
flash touch recovery
I'm the ROOT man
G Talk: Upstreammiami3o5Let me help you ROOT your phone - 04-02-2012, 07:39 PM #7
- 04-02-2012, 07:43 PM
Thread Author #8
- 04-03-2012, 11:19 AM #9
I had the same problem and it took a little digging to find out why:
[Guide] How To Backup, Restore & Install ROMs on The Galaxy Nexus
As stated above, you need to overwrite the stock recovery. - 04-03-2012, 10:40 PM
Thread Author #10
- 04-03-2012, 11:07 PM #11
Rom manager app has been acting up lately. But, since you had recovery, and then flashed a rom, you should still have recovery, despite what rom manager says or does. (assuming you flashed a non-stock rom).
If you power off, you can boot to recovery manually.
Hold power, vol up and vol down all together - that takes you to the bootloader screen (fast boot). Use vol keys to scroll down to recovery, then press power.
See if that works.
*INCREDIBLE*MECHA*TORO*GROUPER* GALAXY S3 *
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 04-04-2012, 07:33 AM #12
Yes, do the all volume + power. Use the volume keys to find recovery, hit power to select, and boom, CWM should be there.
If you flash straight up 4.0.4 you'll lose root without rootkeeper or a similar precaution/app.
With newer CWM and rooting methods, the whole mysterious file that must be renamed/deleted is usually gone automatically. I've rooted on a mac and have yet to actually see the file, and thus have never had the issue of CWM not sticking.Former moderator & advisor.
Reply
