01-03-2013 06:33 PM
154 ... 34567
tools
  1. reeper55's Avatar
    here is a screenshot from root checker
    06-30-2012 10:43 AM
  2. dmmarck's Avatar
    Go to the Mac method guide. Download the 4.0.4 superuser. Zero neck posted it. Flash it in recovery.
    Sent from Oliver, Destroyer of Worlds & Connoisseur of Bean-Shaped Confections
    06-30-2012 10:45 AM
  3. reeper55's Avatar
    Ok I know I sound like a maroon (this is all very new) how do I go about flashing the zip?
    06-30-2012 11:03 AM
  4. dmmarck's Avatar
    Download it, place on phone, reboot into clockwork recovery, install zip, find that zip on your phone, install, reboot system :-)
    zero neck and 2defmouze like this.
    06-30-2012 11:23 AM
  5. reeper55's Avatar
    I don't have clockwork recovery remember, I am unable to flash it.
    06-30-2012 11:55 AM
  6. dmmarck's Avatar
    You're going to need to fastboot it. If I had power I'd be able to help you, but unfortunately I don't so i'm like the Lawrence of Arabia of the DC area right now...constantly moving to find the juice!
    zero neck likes this.
    06-30-2012 12:01 PM
  7. zero neck's Avatar
    You need to DL cwm touch for toro I think iTS version 5.5.04 or something.
    then you put that in the adb folder that contains fast boot .exe
    Put the su zip on your SD card and turn USB debugging on.
    Connect tocpu with USB. Then boot phone into boot loader mode.
    Next CD to your adb folder with terminal commands.
    Then enter this command:
    ./fastboot boot nameofrecovery.img
    That should work let me know if you need more help
    I'm not home but I will be around five if you need clearer instructions.BTW that will boot cwm temp on your phone then you install the su zip in cwm.
    2defmouze likes this.
    06-30-2012 12:10 PM
  8. reeper55's Avatar
    That would just be like the procedure to do the unlock right?
    If so I think I can do it but i just dont know the "file name" to use.
    06-30-2012 12:11 PM
  9. dmmarck's Avatar
    Are you familiar with fastboot?
    If so...go to clockworkmod.com (or whatever the site is; google it) and download the touch recovery for our Nexus (toro). It is 5.8.0.2.
    Then, get to the bootloader (all volume + power when the phone is off) and cd to the directory the file is in and then
    "fastboot flash recovery recoveryname.img"
    For Ubuntu, it's simply cd'ing to the folder (like Downloads) and "sudo fastboot flash recovery recoveryname.img"
    06-30-2012 12:24 PM
  10. reeper55's Avatar
    Guys I am sorry but i am just not familiar enough with this sort of thing to follow what you are asking me to do.
    I believe I am going to need a private lesson and be walked through the process.
    06-30-2012 02:02 PM
  11. dmmarck's Avatar
    You may have to wait until I get power. My apologies. :-)
    If someone else wants to, please be my guest!
    06-30-2012 02:04 PM
  12. reeper55's Avatar
    If you would be willing, I would be truly grateful. No rush, I will be out this evening anyhow. GOOD LUCK getting that power back. I went 3 days without it in October when we got that huge snowstorm in Massachusetts.
    06-30-2012 03:02 PM
  13. dmmarck's Avatar
    I'm at my school (former) right now. If you want, I can walk you through the steps on a Mac. No idea how to fastboot crap on a Windows machine.
    I prefer doing it by Gchat. Do you have that?
    06-30-2012 03:34 PM
  14. reeper55's Avatar
    I only have a windows PC, no Mac here.
    06-30-2012 04:08 PM
  15. dmmarck's Avatar
    That is unfortunate! My apologies .
    06-30-2012 04:14 PM
  16. zero neck's Avatar
    Let me know if you still need help, I'm not 100 percent on PC instructions but I can help you.
    07-01-2012 08:55 AM
  17. dmmarck's Avatar
    Oh, I forgot about this option--but you can use Wug's to fastboot stuff.
    reeper55 and zero neck like this.
    07-01-2012 01:38 PM
  18. reeper55's Avatar
    Thanks a bunch. I'll give it a try in a bit. Trying to my baby girl down for a nap.
    dmmarck likes this.
    07-01-2012 01:48 PM
  19. dmmarck's Avatar
    Just make sure all of the drivers are installed and that you follow his instructions, but he should be able to make you right in a matter of seconds lol
    07-01-2012 01:52 PM
  20. reeper55's Avatar
    You were right!!!!! I am now rooted. Now i need to figure out how to get JB on there.
    Thanks for the guidance sir!!
    07-01-2012 03:40 PM
  21. dmmarck's Avatar
    Did you permanently flash CWM?
    07-01-2012 03:45 PM
  22. reeper55's Avatar
    I did.
    07-01-2012 04:13 PM
  23. dmmarck's Avatar
    I did.
    Then go read my Jelly Bean guide, particularly the first post.
    Read it twice too.
    07-01-2012 04:14 PM
  24. reeper55's Avatar
    Yeah I skimmed it but paid close attention to where you scare away noobs like me! LOL
    I am feeling a tad intimidated
    dmmarck likes this.
    07-01-2012 04:53 PM
  25. dmmarck's Avatar
    Just gotta be careful, really careful. That's all .
    07-01-2012 04:56 PM
154 ... 34567
