- 04-21-2012, 05:17 AM
Thread Author #1
Faster LED Flash
Hoping someone can help me out.....I'm trying to figure out how to make the notification led flash at a constant pulse or at least a little faster.....any help would be great.....thanks
Sent from my Galaxy Nexus using Tapatalk 2Last edited by whiplash473; 04-21-2012 at 05:54 AM.
Droid X2 - Rooted - Stock Clock - Minimal X
If I have to explain, you wouldn't understand. - 04-21-2012, 06:19 AM #2
If you are rooted try light flow. It let's you tweak the colors and the speed.
Sent from my Galaxy Nexus using Tapatalk 2 - 04-21-2012, 06:27 AM #3
- 04-21-2012, 11:16 AM #4
Re: Faster LED Flash
Roms such as aokp, liquid, patient zero etc allow you to change the speed and duration of the glow without light flow.
*INCREDIBLE*MECHA*TORO*GROUPER* GALAXY S3 *
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 04-21-2012, 01:22 PM #5***GET IN WHERE YOU FIT IN***
Snitches get stitches
Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
Living Dead-iPad3,GalaxyNexus,Razr MaxxHD - 04-21-2012, 07:29 PM #6
I appreciate that I can adjust the flash frequency via my ROM, but I still use Lightflow to set different colors for different notifications. Then I know when to ignore the LED
*customized tapatalk signature*Thanked by: - 04-21-2012, 07:33 PM #7***GET IN WHERE YOU FIT IN***
Living Dead-iPad3,GalaxyNexus,Razr MaxxHD - 04-21-2012, 07:53 PM #8
Currently on AOKP b32. They keep dropping releases, but since they're on a feature freeze until the next milestone I'm just sticking on b32. Been great for me. Kept going through a bunch of different kernels, but back to Franco (on r141 nightly).
This particular device loves Franco's kernel. All the others I tried had lag, or data connection issues. I know devices are unique, and others have had really good results with all of the other kernels I tried... but mine is most solid/fluid/stable/butterific with Franco's.
*customized tapatalk signature* - 04-21-2012, 11:00 PM
Thread Author #9
Reply
