Page 15 of 17 FirstFirst ... 121314151617 LastLast
Results 351 to 375 of 409
Like Tree183Likes
  1. #351
    Default Re: [RADIOS][VZW] Galaxy Nexus Radios and Installation Guide
    i had a horrible time getting 4g to stay working until the newest radios FF02, FG02 now it works so well im happy my GNEX is now how it should have been
  2. #352
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Default
    Quote Originally Posted by SKYLER616 View Post
    Glad to hear that!
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
  3. #353
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    ROM
    SKAnkCM10/Milestone6
    I have to air this OPINION of mine on how cluttered the stickies are in this forum. It seems like we have two Jelly Bean discussion threads and two or three how to restore your NExus threads up there. What gets me is you then have a very descent thread like this here that SHOULD BE A STICKY just hanging around with the rest of the layman threads here.
    JEdi
    Thanked by 2:
    ohiomoto likes this.
  4. #354
    Masheen's Avatar
    Android OG
    Posts
    ROM
    Stock (for now)
    I'm glad to see the new radios. For me, the hand-offs were faster but I now have 3G in areas that previously displayed 4G. Sucks that people have different experiences, but that's how it goes. Cheers.
    Thanked by:
  5. Thread Author  Thread Author    #355
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Quote Originally Posted by JkdJedi View Post
    JEdi
    While I dont determine what is stickied, I can see where some of the threads could be combined or something. But, Often different members have put their time into the thread, and combining them would be logistically difficult.
    Anyway, this thread usually floats around the first page, and its Always in my sig.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  6. #356
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    JEdi
    We have a max number of stickies. I'll see what I can do .
  7. #357
    I installed the 4.1.1 radios on my VZW Galaxy Nexus using TWRP. When I reboot it says "R" above signal indicator. I am guessing this means roaming. When my phone connects to my VZW network extender it says "Network Extender" in the notification pulldown instead of "Verizon Wireless". I went back to the old radios. Any ideas?
    I am using Bugless Beast - Jelly Bean and Lean Kernel.
  8. #358
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Sounds like something conflicting. I have not seen an "R" since I messed with a .xml file a couple of months ago. Could be that file (IIRC, eri.xml?) or simply the Network Extender interfering.
    Thanked by:
  9. Thread Author  Thread Author    #359
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    You hsould be able to flash back to the 4.04 radios in the OP.
    Someone else said they were seeing R (roaming) and net extender indicators. A few pages back i believe.
    Thanked by:
  10. #360
    JEdi
    I agree. Why not drop the Chatter thread from the top? It's being used as an "off topic" thread anyway. This thread should be up there. Combining some thread would might be helpful or dropping a few that are referenced in other threads.
  11. #361
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by ohiomoto View Post
    Banned!
    Jk
    zero neck likes this.
  12. #362
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    I didn't put it there and I'm hesitant from touching stuff I don't (1) own, or (2) know why it's there. I'll take a look see when I have some time and see what can be spared and what's vital .
    - - - Updated - - -
    Done .
    Thanked by:
  13. Thread Author  Thread Author    #363
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Quote Originally Posted by 2defmouze View Post
    Banned!
    Jk
    Hahahahahahahaha yup. See yya.
  14. #364
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    7,013 Global Posts
    ROM
    BB JB
    So is it ok to flash the new verizon cdma radios via fastboot? or do you need to do it via pc?
    Bit confused.
  15. #365
    AppleBonker's Avatar
    Dag, yo!
    Posts
    ROM
    AOKP/Franco & PA/Franco
    I don't believe anyone has pulled the images out of the zip and made them fastboot flashable (at least I haven't seen it). I flashed mine through recovery.
  16. #366
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by tony bag o donuts View Post
    Bit confused.
    Fastbooting needs to be from your pc... the zips can be flashed in recovery, or alternatively you can pull the .img files out of the zips and fastboot them.
  17. #367
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    I haven't checked this specific zip but I know the one I have doesn't have an image for one of the radios, it's just a patch. Damned thing.
  18. #368
    Quote Originally Posted by user313 View Post
    I see the R when I am on my network extender.
  19. #369
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Anyone know if there is a zip file created yet for the binaries from JRO03R?
    Motorola Droid Maxx
    Samsung Galaxy Nexus - RIP
    CM10 Jellybro Jelly Bean
    Asus Nexus 7
    AOKP JB Milestone 1
  20. #370
    Xanth269's Avatar
    Posts
    Global Posts
    452 Global Posts
    ROM
    AOKP Build5
    I flashed latest radios and it seems my signal got worse, is that even possible. I get almost no wifi next to my wireless router where as before full signal. Lower 3 & 4g signals as I travel. Is it OK to flash the older radios so i get my signal back.
  21. Thread Author  Thread Author    #371
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Yeah man
    Thanked by:
  22. #372
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Quote Originally Posted by SeigaGen View Post
    Check my compile guide. I have links to where the binaries are kept.
    Thanked by:
  23. #373
    bulvine420's Avatar
    Posts
    Global Posts
    177 Global Posts
    ROM
    liquidsmooth
    I would do a full wipe and install the official Verizon 4.1.1 from Google it has jb boot loader and newest radios. Fastest way is galaxy nexus tools found in these forums even has one click root and unlock.
  24. #374
    Just putting this out there for everyone that still has radio issues. I updated to MMuzzy's Jelly Bean - 4.2 - JOP40C AOSP I found on XDA and I have had absolutely zero problems with my radio.
  25. #375
    If I'm flashing new radios in recovery mode, do I need to wipe the cache partition and Dalvik cache if I am just flashing different radios? It mentions in CyberWarrior's guide you only need to wipe these if you're only flashing themes,etc. I wasn't sure if flashing new radios required a full wipe, or any wipe for that matter.
B
