DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Page 2 of 17 FirstFirst 12345 ... LastLast
Results 26 to 50 of 401
Like Tree181Likes
  1. #26
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: [RADIOS] Verizon Galaxy Nexus Radios and Guide
    Quote Originally Posted by Android666 View Post
    I must be doing something wrong. Whenever i put my phone into recovery mode it will show the android with chest open and a red triangle with an exclamation point in it. But it will stay like that for a few minutes then just reboot without letting me do anything else. Am I doing something wrong or did I not install something I needed?
    Are you rooted/unlocked?
    Thanked by:
  2. Thread Author  Thread Author    #27
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by dmmarck View Post
    either that or you need to reflash recovery every time you want to use it if you are on stock-rooted/unlocked.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  3. #28
    Ok got it to work thanks for the guide.
    zero neck likes this.
  4. Thread Author  Thread Author    #29
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Updated post 2 with a couple hybrid radios.
    Working on fastboot instructions/radio .img files for fastboot flashing. Need some time for that tho, with school and everything.
    Thanked by 2:
    2defmouze likes this.
  5. #30
    Default
    Reply
    sent from a Android device
    I'm always on!
  6. #31
    Awesome stuff Zero Neck! Just flashed my 4.0.4 radios and went smoothly. I am not sure if this would be something to note but flashing the LTE radio was very quick but the CDMA radio took significantly longer, I would say a full minutes as opposed to LTE which took 10-15 seconds.
    Thanked by:
  7. Thread Author  Thread Author    #32
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    ^that seems a little long but as long as it shows the change in settings>about phone>radio baseband version, you should be good (it should read FA02 for both cdma and lte on the 4.04 radios).
  8. #33
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by creccaj1 View Post
    Yes that's standard. I thought it was mentioned in his guide... But if not maybe you'd want to add a note about the CDMA radio taking a minute so ppl don't panic halfway through haha
    Thanked by:
  9. Thread Author  Thread Author    #34
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    i'll mention it when i have min
    thanks 2def
  10. #35
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Big Red Galaxy Nexus getting 4.0.4 IMM76K?
    You must be on the 4.0.2 radios to flash these. I recommend flashing 4.0.2--REBOOTING--going back into recovery, then flashing the attached file.
    Edit: DT also has a file, with bootloader included.
    He says ==>
    "FYI, It will Flash the Bootloader, Revert the LTE, Patch the LTE to the New and Flash the CDMA. "
    Thanked by 3:
    davey11 and zero neck like this.
  11. #36
    So where is zero? We need the op updated NAOO. jk
  12. #37
    He says ==>
    Thats annoying how you cant just flash it over the leaked version...
  13. #38
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by callofduty4 View Post
    With DT's package you. I actually flashed his package just now OVER the new radios, and all is well. He does good work.
    This is essentially the new version of the "GET READY PACKAGE" he has for his roms. It also includes the 4.0.4 bootloader, while the other one--I believe--does not.
    Therefore, I recommend flashing his package.
  14. Thread Author  Thread Author    #39
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    word. i'll update OP but prolly not till later or tomorrow. (reading)
    or it might be best to get a version wihtout the bootloader so they can just be flashed without the reversion to 402.
    anyway - will flash dt's version and see how it goes.
    get at yall later.
    btw - dmm - and anyone else with dl links for these new radios - have md5?
  15. #40
    Im running AOKP though, not sure how that'd work
  16. #41
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by zero neck View Post
    get at yall later.
    Yeah, DT's version works best for people like us running 4.0.4 across the board. If you do flash back to 4.0.2, I can't recommend rebooting enough. This is the second time I flashed this without rebooting, and it didn't work (counting the leak in Feb that is). Rebooted, reflashed the .4 package, perfect.
    Don't worry about that; it'll flash fine. Flash his file in CWM, go to about phone to check if you have FC## under the basband.
    Also, in case anyone was wondering, you can flash DT's package on top of the package I just linked to, b/c I'm nuts and have to flash everything like an addict.
  17. #42
    So all I have to do is flash his file? and ill have the new radios?
  18. #43
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Yup. New files and new bootloader. You should be fine. If for some reason installation aborts, and you're on the 4.0.2 radios still (EK## under baseband), flash the file I uploaded in the linked thread. I do not believe that contains the new bootloader, however, while DT's does. If that's your thing, do what I did and flash DT's file on top of that.
    That being said, all you need to do--or should need to do--is flash his package lol
    Thanked by 2:
    Cyber Warrior likes this.
  19. #44
    There are md5's for the patch files, but since theory's file is better I think dmm should have that. Right dmm?
    Sometimes I skip checking md5, but on this type of file, you gotta make EXTRA sure of them md5 checksums.
    Thanked by:
  20. #45
    Wait so one more time to clarify
    1) Im running 4.0.4 AOKP
    2) Im running the leaked 4.0.4 radios
    3) It is still okay for me to flash his package
    4)Saying "Flash his package" is pretty funny
    So im good to go?
  21. Thread Author  Thread Author    #46
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by davey11 View Post
    word. HIGHLY RECOMMENDED you check md5's for radios and bootlaoders. Like, always
    That said i'm real busy but i'll try to update op with something by tonight, only dt's package or something. I dont like having people go back to 4.02 bc they might forget or not read the op
    then they
    i'll look for the md5 later on the hive when i'm done drinking 36 beers and reading the entire syllabus of every class ten times.
    davey11 likes this.
  22. Thread Author  Thread Author    #47
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    So im good to go?
    You can flash the DRoidth3ory package dmm linked above - its the one from droidhive
    Check the md5 first if dmm posts it up
    btw - this is the one you can "just flash"
    Thanked by:
  23. #48
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    I posted an MD5 for the file I uploaded. For DT's file, let me see if I can find one on his site.
    This is all I got ==> . He didn't post an MD5. I can try pulling one with an app?
    FWIW, my phone has yet to explode and it has FC##, so all's good with it lol.
    Thanked by:
  24. #49
    I guess ill wait for the MD5 before I try and flash it
  25. #50
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Don't worry, I'm getting it
    MD5 for DT's package = 251a34fd6bdb59458911315c712f0051
    Thanked by 3:
