Page 4 of 17 FirstFirst 1234567 ... LastLast
Results 76 to 100 of 409
Like Tree183Likes
  1. #76
    Default Re: [RADIOS] Verizon Galaxy Nexus Radios and Guide
    Im on it now... Just did my backup and im on to flashing..
    zero neck and dmmarck like this.
  2. #77
    davidnc's Avatar
    Posts
    Global Posts
    6,667 Global Posts
    ROM
    Nexus(AOKP-jb_4.2.1)
    I flashed the new radio/bootloader this AM too. At work which has always been a lousy area for any smartphones I had (incredible, and dx).
    The new radio's made a little difference will know more when back on my home turf.
    However I can definitely see a lot stronger WiFi's connection then I did yesterday
    zero neck likes this.
  3. #78
    NotJustAPhone's Avatar
    Posts
    Global Posts
    11,758 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Default
    3G/LTE handoffs are nearly instantaneous now. In the past, it could take well over a minute to switch. (I'm in an area with good LTE and 3G service but keep data on 3G most of the time.)
  4. #79
    MegaSoundwave76's Avatar
    Posts
    ROM
    You Jelly Huh 2.1
    Default
    I flashed the FC04/FC05/bootloadee radios on BAMF Paradigm 1.25 and its been super solid for me. 3g/4g hand off has been great and getting around high 60's dbm compared to low 80's with the older radios. I think I found a winner.
    My Galaxy Note 2 tells me to have a beer! Okay!!!
    Thanked by:
  5. #80
    steveinil's Avatar
    Posts
    ROM
    aokp 34
    i flashed the new new radieos my baseband is i515.09 v.f04/i515.fc05
    is that right im thinking thats still the old radieos?
  6. #81
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Quote Originally Posted by steveinil View Post
    You mean your baseband is ==> i515.09 FC04/FC05?
    if that's the case, you're good to go .
    Old 4.0.4 radios = FA##.
    Thanked by 2:
  7. Thread Author  Thread Author    #82
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    those are the new ones.
    FC04 / FC05
    you're good
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  8. #83
    steveinil's Avatar
    Posts
    ROM
    aokp 34
    yep thats it just cant type lol mine does have a V in there though
    I515.09 V.FC04 and FC05
  9. #84
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Default
    So does mine ; )
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
  10. #85
    Yo you are the man.... I was looking for a step by step and this is beyond easy to follow.. Think im getting this rooting thing down... Next thing you know ill be building android phones.. Ok, I lied but it sounded good.. lol
    Thanked by:
    davey11, zero neck and dmmarck like this.
  11. #86
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by youngzayiles View Post
    You taking orders yet?
  12. #87
    Quote Originally Posted by 2defmouze View Post
    Yeah I have a octa core beast im building in my garage With a rom, kernel and radios to match... LOL! But on a serious note my freaking signal has changed dramatically.. Thank you 6lb 8oz baby Jesus...
    zero neck and 2defmouze like this.
  13. Thread Author  Thread Author    #88
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    I want mine to turn into a submarine shaped like an octopus.
    Thx.
  14. #89
    Just flashed over Liquid 1.35 with old 4.0.4 radios and worked like a charm. Now running new radios without a hiccup in the process! Thanks for posting again Zero!
    Thanked by 2:
  15. #90
    Gherkin Savorus's Avatar
    Posts
    Global Posts
    75 Global Posts
    ROM
    LiquidSmooth 2.1-Leankrnl
    Thanks Zero. Easy as pie. Up and running with the "new" 4.0.4 radios after flashing directly over the leaked 4.0.4 radios from a while back. Took all of 5 minutes.
    Thanked by:
  16. #91
    nice!
    Thanked by:
  17. Thread Author  Thread Author    #92
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    updated post 2 with 4.04 "imm76k" radios package without the bootloader.
    Thanked by 2:
  18. #93
    Default Re: [RADIOS][VZW] Galaxy Nexus Radios and Installation Guide
    Still figgerin' all this out:
    What is the point, risk or benefit of flashing the bootloader inclusive file vs just the radios???
  19. #94
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,964 Global Posts
    Quote Originally Posted by tacticalfats View Post
    You can't use the stock recovery... you need a custom recovery (CWM/ClockWorkMod Recovery) in order to flash the radios. In order to install CWM Recovery... the phones bootloader needs to be unlocked.
    1) unlock bootloader
    2) install/flash CWM Recovery
    3) install/flash radios
    Thanked by:
  20. #95
    I'm unlocked/rooted/running AOKP with the leaked 4.0.4 radios (FA versions).
    I'm just befuddled by the new radio files which are available with and without the bootloader packaged in.
  21. Thread Author  Thread Author    #96
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Currently you don't need the updated boot loader bc the radios will work on the old bootloader, at the same time it won't harm anything to flash it.
    The risk of flashing bad radios or boot loader is messing up your phone, so make sure to check md5 before you flash.
  22. #97
    Robots Will Kill
    Posts
    Global Posts
    11,964 Global Posts
    You needed to be on the 4.0.2 radios in order to flash the 4.0.4 radios... some of us were already running a leaked version of the 4.0.4 radios from a month ago and didn't want to have to revert back... potentially losing root.
    DT put together a package that downgrades you back to 4.0.2, flashes the new 4.0.4 bootloader and upgrades the radios to the official 4.0.4 radios... its much easier.
    Info is on page 2.
    Thanked by:
  23. Thread Author  Thread Author    #98
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    That's correct. That's why a day or two later I added the file with just the radios, for those who don't want the boot foe whatever reason, or already had flashed it, when just the radios were made available with the patch to circumvent rolling back to 4.02 to upgrade.
  24. #99
    So I can just flashed the non-bootloader equipped file and I'm GTG?
  25. Thread Author  Thread Author    #100
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Yup check md5 and flash in recovery mode
B
