Page 5 of 17 FirstFirst ... 2345678 ... LastLast
Results 101 to 125 of 409
Like Tree183Likes
  1. #101
    Default Re: [RADIOS][VZW] Galaxy Nexus Radios and Installation Guide
    Cool. Thanks for everyone's help...flashing now.
    zero neck likes this.
  2. #102
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    You should update the bootloader.. its good practice to keep the radios and bootloader on the same version, that's why they are updated together. Will it work otherwise? Yes, usually, but like I said it's good practice. You can always revert back the bootloader just as easily as anything else on this phone if you need to
    Thanked by 2:
  3. #103
    I went back to the FA02 radios, just to see whats going on.
    I was randomly getting no service.(bar with an x through it. I live in a full 4g area. ). I am on aokp M5 and franco r156.Going to test it tomorrow and see if i get the same dropouts. This just started happening today. It occurred twice.
    Anyone else having the same issues?
    EDIT
    Update, it happened when I was sending a text message. Signal dropped out and also said message not sent. So I just tried it again on the FA02 radios and it did it again when I tried to resend the message.
    Wierd!
  4. Thread Author  Thread Author    #104
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    They might be working on your towers or something. Not sure where you're at
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  5. #105
    Default
    Just happened to me too?
    sent from a Android device
    I'm always on!
  6. Thread Author  Thread Author    #106
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    my signals good. NY
    new 404 FC radios
  7. #107
    Default
    Quote Originally Posted by jmiesse134 View Post
    EDIT
    Wierd!
    It's strange, the signal dropped when I pressed the send key for the text.
  8. #108
    Default
    These radios are definitely more stable for me. Didn't boost signal strength but now I actually hold on to 4g better.
  9. #109
    Default
    Took forever for 3g to come back?
    I wonder what that is called?
    When you flash radio and nothing...
    Oh yeah FAIL!
    No foreal what happened?
    I'm always on!
  10. Thread Author  Thread Author    #110
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Quote Originally Posted by axne1 View Post
    Oh yeah FAIL!
    I'm always on!
    how long did it take? sometimes radios need to calibrate when you first flash them. shouldnt be more than five or ten minutes tops.
  11. #111
    rob90262's Avatar
    Posts
    Global Posts
    432 Global Posts
    ROM
    stock ice cream
    Default
    I just want signal at my job even with the new radio I get nothing
  12. #112
    Xanth269's Avatar
    Posts
    Global Posts
    452 Global Posts
    ROM
    AOKP Build5
    Ok so I am trying to follow all the "updates" to the radios. I have Liquid 1/35 with the extras, and I flashed the radios with Baseband version I515.09V.FA02 / I515.FA02. From what I have read I need to go back to 4.02 radios and than flash the new 4.04 radios or use as I read on page 2 use DT file and it will do it all for me , downgrade to 4.02 and than upgrade to 4.04. Please advise.
    Thanks,
    Xanth
  13. Thread Author  Thread Author    #113
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Quote Originally Posted by Xanth269 View Post
    Thanks,
    Xanth
    You don't have to roll back to 4.02. You can flash either 404 with boot loader or without, both will revert to 402 then patch to 404 FC04/5 radios.
    But you may as well flash with the bootloader.
    Thanked by:
  14. Thread Author  Thread Author    #114
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Quote Originally Posted by Robert90262 View Post
    Sorry man you look into changing prl version?
  15. #115
    Xanth269's Avatar
    Posts
    Global Posts
    452 Global Posts
    ROM
    AOKP Build5
    Quote Originally Posted by zero neck View Post
    So would that be the DT File? or is there another file/link for this.
    Thanks for your help,
    Xanth
  16. Thread Author  Thread Author    #116
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Xanth
    Yes there's a dl link in post 2 of this thread.
  17. #117
    Mr.Gadget's Avatar
    Posts
    Global Posts
    275 Global Posts
    ROM
    Vicious JellyBean 4.1.1
    I'm on Liquid ROM as well and just re-flashed the radios over my leaked versions. I hope it makes a difference!
  18. #118
    rob90262's Avatar
    Posts
    Global Posts
    432 Global Posts
    ROM
    stock ice cream
    Default
    Honestly I wouldn't even know how I just know sprint gets reception at my work and Verizon struggles
  19. Thread Author  Thread Author    #119
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    are you in a 3g only area or 4g?
  20. #120
    rob90262's Avatar
    Posts
    Global Posts
    432 Global Posts
    ROM
    stock ice cream
    Default
    I would say a strong 4G area always 3-4 bars
  21. Thread Author  Thread Author    #121
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    oh i dunno if a prl change would help then. i think that's more for 3g signal. there's a thread out in the general section i think its called ... *228558 or something like that about the result of member alphanu changing his prl, getting a new sim, and the results if you want to check that out.
  22. #122
    rob90262's Avatar
    Posts
    Global Posts
    432 Global Posts
    ROM
    stock ice cream
    Default
    I'll give it a try thanks
  23. #123
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    little guy was hiding all the way down on page 2.... I BUMP YOU.
    Thanked by:
  24. #124
    gregs1213's Avatar
    Posts
    Global Posts
    257 Global Posts
    ROM
    AOKP (M5) Franco (M4)
    I'm on AOKP m4, Francos Nightly and went from the unofficial 4.04 leak to the new "IMM76K" - Google Release. I am getting the exact same numbers as before (-96 on 4g, -93 on 3g)
    Thanks for the post, hopefully I see better numbers at work (where i really want them).
  25. #125
    Beyond Fire's Avatar
    Posts
    Global Posts
    546 Global Posts
    ROM
    AOKP B4 JB/Franco M5
    Default
    Quick question.. When I flash the new radios and bootloader will I need to unlock the bootloader again? Wanna make sure I back up my files before I do anything if that's the case
B
