dmmarck
Retired Moderator
Re: [RADIOS] Verizon Galaxy Nexus Radios and Guide
Yeah, DT's version works best for people like us running 4.0.4 across the board. If you do flash back to 4.0.2, I can't recommend rebooting enough. This is the second time I flashed this without rebooting, and it didn't work (counting the leak in Feb that is). Rebooted, reflashed the .4 package, perfect.
Don't worry about that; it'll flash fine. Flash his file in CWM, go to about phone to check if you have FC## under the basband.
Also, in case anyone was wondering, you can flash DT's package on top of the package I just linked to, b/c I'm nuts and have to flash everything like an addict.
word. i'll update OP but prolly not till later or tomorrow. (reading)
or it might be best to get a version wihtout the bootloader so they can just be flashed without the reversion to 402.
anyway - will flash dt's version and see how it goes.
get at yall later.
Im running AOKP though, not sure how that'd work
