Page 1 of 17 1234 ... LastLast
Results 1 to 25 of 401
Like Tree181Likes
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Post [RADIOS][VZW] Galaxy Nexus Radios and Installation Guide
    Installation Guide
    [NOTE]These .zip files are for the Verizon Galaxy Nexus and each .zip file contains both the CDMA and LTE Radio. These radios will work on all current Verizon Galaxy Nexus roms, stock or custom, and will work with any existing bootloader/recovery. Radios are not saved when you make nandroid backups, they will persist until you change them again.[/NOTE]
    [WARN]Flashing a radio incorrectly, or flashing a corrupted radio file, may harm your device, so please read the directions and pay attention when you flash: Verify that the md5 sum matches (explained below), make sure you have enough battery (MINIMUM 35% to be safe), and always make nandroid backups before you flash things just because (it's a good habit that will keep your phone safe). You flash at your own risk like always.[/WARN]
    How to Flash A Radio In Recovery Mode
    These radios are flashable in recovery mode, which makes them very easy to apply. To do so, you need to have flashed a custom recovery (typically this will be a version of clockworkmod recovery - see CyberWarrior's GUIDE for further instructions on how to flash recovery, make backups, flash roms, and beyond).
    Step 1: Make a nandroid backup in Clockworkmod Recovery ("CWM") before you begin.
    If you already have backups, skip. It's not crucial to flashing a radio, but you should have a backup ready at all times so just do it.
    Step 2: Download the radio you wish to flash from Post #2 below.
    Download the Radio .zip either from the phone's browser (which will save to Sd Card>Download; or download to your computer and copy over to your SD Card via usb.
    Step 3: Verify the MD5 sum that corresponds to the radio you are going to flash.
    I have listed the md5 sum for each radio .zip. You need to check the md5 of the file you have downloaded against the md5 I have listed to make sure that they match EXACTLY. If they don't match, DO NOT FLASH THE .ZIP - instead, try downloading again until they match. You don't want to flash a corrupted radio file, or you may have downloaded the wrong thing by accident.
    [TIP]How to Check the MD5 Sum
    Once the Radio file is on your SD Card, you can check the md5 sum using a file manager such as astro or OI file manager, or you can download the app HASHDROID in the market (all of these are free). Using a file manager, navigate to the radio file on your sd card, long press the file, and then check the md5 sum (the character string). In astro, specifically, long press the file and then go to Details, where it will list the sum. Using Hashdroid, open the app and navigate to the file you wish to check, then copy and paste the md5 I have supplied and it will check them for you.[/TIP]
    Step 4: Reboot into Recovery Mode and Flash the Radio .zip
    To reboot into recovery mode manually, turn off your device, then turn it back on while holding volume up + volume down + power simultaneously until you get to the bootloader screen (android guy on his back with his chestplate open). Then navigate to RECOVERY by pressing the volume keys, and select RECOVERY by pressing power.
    Once in Recovery mode, navigate with volume keys to Install Zip From SD Card --> Choose Zip From SD Card --> Find the Radio .zip file where you put it and select the file with the power button.
    The radios will install - don't be alarmed if the CDMA radio takes a minute or two - and then you will select Reboot System Now.
    Allow your phone to boot up, then you can check and see that the new radio was applied in Settings>About Phone>Baseband Version.
    To change it back just DL a different radio and repeat the steps.
    Thanked by 50:
    + Show/Hide list of the thanked
  2. Thread Author  Thread Author    #2
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Default Re: [RADIOS] Galaxy Nexus CDMA Radio Thread
    Recovery Mode Flashable Radios, MD5 checksums, and Information:
    Click on the Radio to Download
    NEW: 03/2013
    - "JDQ39" - Test Build Leak
    Contains CDMA Version: FK01
    Contains LTE Version: FK02
    MD5: b3f19cafec643f37cf074bab35ac3143
    - "JRO03O" - Test Build Leak
    Contains CDMA Version: FF02
    Contains LTE Version: FG02
    MD5: 52cb0605b23492e78d6e2c2de3969768
    - "PRIMELC03" - Official Google Release [Maguro] / Test Build Leak [Toro]
    Be aware that this may not work with ICS roms!!!
    ONLY contains the JB Bootloader - no radios.
    MD5: 2d8fb3aa57e1f529c75be7d8959e99a1
    - "IMM76K" - Official Google Release
    Contains CDMA Version: FC04
    Contains LTE Version: FC05
    Contains Official 4.04 Bootloader
    MD5: 251a34fd6bdb59458911315c712f0051
    MD5: 02f112aeb4d6be5cc29daddf652abcd4
    - "ITL41D" - Official Google Release
    Contains CDMA Version: EK01
    Contains LTE Version: EK02
    MD5: 3302017119dd24eaf99b2a6540ea3697
    - "ICL53F" - Official Google Release
    Contains CDMA Version: EK05
    MD5: a12743e6d3b80734831f69502bdae29b
    - "IML77?" - Unofficial Leak
    Contains CDMA Version: EK06
    Contains LTE Version: EK04
    MD5: c07f43102346b7e88ac30fe981dbbf2b
    - "IMM30B" - Unofficial Leak
    Contains CDMA Version: FA02
    Contains LTE Version: FA02
    MD5: bd63961006aa65e88100017bab2c7fbb
    - Hybrid
    MD5: 999b87799b5846af96694d25c62cea8b
    - Hybrid
    MD5: 24afbc22c9ba88e7cbdd248147762289
    - Hybrid
    MD5: 3383d0b47c5e9aaab0d638f6c2290a0c
    Special Thanks to DroidTh30ry for the official 4.04 getready, Goo.IM, ready5 for the hybrids, all those who obtained the leaks and everyone who helped package these radios for recovery.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
    Thanked by 30:
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    HOW TO FLASH A RADIO IN FASTBOOT
    [NOTE]This section will guide you through FASTBOOT installation of Verizon Galaxy Nexus CDMA/LTE radios. Radio .img files are flashable only in Fastboot with terminal/commands, and are not flashable in Recovery mode. Please refer to Post #1 for instructions on how to flash a radio in Recovery. [/NOTE]
    [WARN]As always, flashing corrupted radios will not be a pleasant experience (bricks are possible), so please verify md5 sums for each radio you wish to flash.
    DO NOT disconnect the phone from the computer or do a battery pull while flashing radios or waiting for radios to load.
    And lastly, you flash at your own risk etc. [/WARN]
    INSTRUCTIONS:
    These radio .img files must be flashed in Fastboot, using terminal/commands. Therefore, these instructions will assume that you have already set up ADB (android development bridge), Fastboot, and have some understanding of terminal/commands (that is, you know how to open the command window, and you can follow directions).
    [TIP]For those who do not have ADB/Fastboot set up, I suggest you read through this guide from AC MOD DMMARCK to get you Adb/fastboot for the purposes of unlocking the bootloader and rooting your device in the first place, which if you haven't already done so you should do so now, as flashing radios in fastboot requires that your bootloader be unlocked anyway.[/TIP]
    Step 1: Download the Radio .img file(s) you wish to apply.
    On your computer, download the Radio(s) you are going to flash (the files can be found below). Make sure you download the Radio .img files for fastboot, not radio .zip files (for recovery). Move the radio .img file(s) into the same folder as fastboot.exe.
    Step 2: Verify md5 checksum for the Radio file(s).
    Windows Users - There are lots of programs you can get to verify the md5 on a windows computer, this one is free but I have not used it so take this with a grain of salt. Anwyay, check the md5 against the character string provided below with the radio file download, and make sure they match exactly.
    Mac Users - The easiest way to check the md5 on a mac is to open Terminal and "cd" to the folder that contains fastboot.exe and the radio files you have just moved into the same. As an example, pretend that your fastboot.exe file is in a folder called "adb" and the "adb" folder is on your desktop. You would enter the following commands:
    Code:
    cd desktop
    cd adb
    md5 filename.img
    Make sure that the md5 checksum matches exactly the md5 listed for each radio you are going to flash, and if they do not match exactly do not flash the file. Instead, try to download again, and check the md5 again, to make sure you got a good download and the file is complete. Flashing a corrupted radio file can brick your phone.
    [warn]YOU MUST NOT DISCONNECT FROM THE COMPUTER OR PULL THE BATTERY OR RUN OUT OF BATTERY POWER WHILE FLASHING RADIOS IN FASTBOOT. THIS WILL HARM OR POSSIBLY BRICK YOUR PHONE. MAKE SURE YOU HAVE 75 PERCENT BATTERY AT LEAST TO BE SAFE.[/warn]
    Step 3: Reboot to bootloader.
    Make sure that your phone has "USB debugging" selected (settings>developer options). Next, connect your phone to your computer via usb (window's users will need the appropriate drivers installed ... for more info, see this GUIDE by CyberWarrior).
    Now that you are connected to the computer, you can reboot to the bootloader either manually (power off, then power on while holding volume up + volume down + power) or in the command prompt/terminal window by entering this command:
    PC:
    Code:
    adb reboot bootloader
    MAC:
    Code:
    ./adb reboot bootloader
    Step 4: Flash the radio file in fastboot.
    For the purpose of flashing radios in fastboot, you MUST flash the CDMA radio FIRST, and the LTE radio SECOND. The reason being that the CDMA radio may override the LTE radio.
    Now that you are in fastboot (your phone shows the android on his back with his chest plate opened up), in the command prompt/terminal window enter the following commands:
    Windows Version - This assumes that the folder that contains fastboot.exe is in c:
    Note that I am going to call this folder "adb", but you will have to use whatever name your folder is called, and where it is located (ex: c:) in your command prompts.
    So, assuming all of that, in the command prompt window, enter the following commands (press enter after each line):
    [cmd]
    cmd
    cd c:/adb
    fastboot flash radio radio-name-cdma.img
    [/cmd]
    Allow it to install - This may take a few minutes, don't panic, AND DO NOT DISCONNECT OR PULL THE BATTERY.
    Next, install the LTE radio:
    [cmd]
    fastboot flash radio radio-name.img
    [/cmd]
    Mac Version: Let's assume that your folder containing fastboot.exe ("adb") is located on your desktop, as in the example from above, so you will enter your commands like this:
    Code:
    cd desktop
    cd adb
    ./fastboot flash radio radio-name-cdma.img
    ./fastboot flash radio radio-name.img
    Step 5: Power off.
    After you have installed the radio files, you can scroll with the volume keys to "Power Off," and select that with the power button.
    When your phone powers off, you can exit the command/terminal window, disconnect your phone, and then restart.
    You can check the radio version by going to Settings>About phone, where you can verify the baseband version(s).
    Fastbootable Radio Downloads ... Coming soon.
    Thanked by 2:
    Wicket and JkdJedi like this.
  4. #4
    Paul627g's Avatar
    Posts
    Global Posts
    13,813 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default Re: [RADIOS] Vzw Galaxy Nexus Radios and Guide
    Great job zero neck ! The community always appreciates options available to them like this.
    Once again another one of our Advisors stepping up to the plate to serve the community, awesome
    - Paul627g
    Thanked by:
    zero neck likes this.
  5. #5
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default Re: [RADIOS] Verizon Galaxy Nexus Radios and Guide
    Good call Zero
    Thanked by:
  6. #6
    oxymoron's Avatar
    It's been real...
    Posts
    Default
    Just noticed this, nice! Now I don't have to link people in AC to Rootz when they ask about radios. Thanks dude!
    *customized tapatalk signature*
    Thanked by:
    zero neck and dmmarck like this.
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Thanks. I'll track down the hybrid radios and include the fastboot radio .img alternatives if there's any demand for it.
    Thought it would be nice to have them in house.
    Thanked by:
  8. #8
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    DO IT.
    Excellent excellent excellent.
    Thanked by:
  9. #9
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Definitely should Sticky this!
    Thanks!!!!
    Thanked by:
  10. Thread Author  Thread Author    #10
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    ^no space for new stickies but it'll be in my sig or a search should work
  11. #11
    Recently have had a lot of ppl asking about radios...this is good stuff.
    Thanked by:
  12. #12
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Agreed good to have them in house.. And +1 for getting the fastboot images up.. More encouragement for ppl to learn how to use it
  13. #13
    Quote Originally Posted by zero neck View Post
    But but, noo I don't like to be a **** and tell ppl to search! LOL
  14. Thread Author  Thread Author    #14
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by davey11 View Post
    hahhah true
  15. #15
    DB12088's Avatar
    Posts
    ROM
    Muzzy / Stock for now
    Default
    I flashed the 4.0.4 radios and the are working like a champ and I running liquid smooth v1.25 thank you for the post and directions
    Thanked by:
  16. Thread Author  Thread Author    #16
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by DB12088 View Post
    Awesome glad it helped!
  17. #17
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    I'm going to put a link to this in my Hitchhiker's Guide, if you don't mind .
  18. Thread Author  Thread Author    #18
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by dmmarck View Post
    by all means
    Thanked by:
  19. #19
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    by all means
    I might even--gasp--install fastboot on my Mac and see what's what. But alas, probably not .
  20. #20
    stbxxl's Avatar
    Posts
    Global Posts
    553 Global Posts
    Just did this today (after unlocking and rooting my Gnex yesterday). Works like a charm so far.
  21. #21
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,982 Global Posts
    ROM
    CLΞΛNЯOM
    Great write up... nice
    Thanked by:
  22. Thread Author  Thread Author    #22
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by Cyber Warrior View Post
    thanks cw! hope you don't mind but i have been linking your guide(s) all over the place
    Thanked by:
  23. #23
    resu_ruot's Avatar
    Posts
    Global Posts
    61 Global Posts
    Thanks zero neck for all of the help and for this easy guide on how to flash radios.
    Thanked by:
  24. Thread Author  Thread Author    #24
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Np, man
  25. #25
    I must be doing something wrong. Whenever i put my phone into recovery mode it will show the android with chest open and a red triangle with an exclamation point in it. But it will stay like that for a few minutes then just reboot without letting me do anything else. Am I doing something wrong or did I not install something I needed?
