Results 1 to 11 of 11
- 04-29-2012, 04:03 PM
Thread Author #1
- 04-29-2012, 04:13 PM #2
Re: What is the easiest way to flash different themes?
Usually you download the theme you want to apply (make sure it goes with the rom version/build you are using), place the theme flashable .zip file on your sd card, and reboot to recovery mode.
in recovery mode, wipe cache partition and dalvik cache, then install zip from sd>choose zip from sd card>find your theme .zip and select it.
it will install, then you can select reboot system now.
*INCREDIBLE*MECHA*TORO*GROUPER* GALAXY S3 *
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 04-29-2012, 04:17 PM #3
Well said zero...
Always make sure you do the cache partition & dalvik cache wipes, if you don't the theme your flashing will only overwrite whatever is new. In other words without doing the wipes you could end up with a mix of your old theme and the new theme.
Some people do this on purpose at times to see what type of crazy "hyper breed or cross breed" theme they come up with
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 04-29-2012, 04:58 PM
Thread Author #4
- 04-29-2012, 05:04 PM #5
It could take 5-10 min to boot up. When it's done optimizing the apps it should start up.
Did it finish optimizing?
Are you sure the theme is the right one for your rom?
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 04-29-2012, 07:03 PM
Thread Author #6
- 04-29-2012, 07:21 PM #7
you could try dl'ing the theme again, maybe the dl was incomplete or corrupted.
* [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] * - 04-30-2012, 06:41 AM
Thread Author #8
- 04-30-2012, 06:53 AM #9
I'm the ROOT man
G Talk: Upstreammiami3o5Let me help you ROOT your phone - 04-30-2012, 08:05 AM #10Google Nexus Class Devices (Nexus7, Nexus4, Galaxy Nexus lte VZW)...@moosc on twitter ...
- 04-30-2012, 08:40 AM #11
Reply
