Results 1 to 25 of 26
- 05-04-2012, 06:02 PM
Thread Author #1
Flashed liquid now battery drains ?
Hello all I just flashed liquid been on it for the last week. Unrooted prior to that. I only used 3g because I am plagued by the data drop on 4g. I am on 4.0.4 radios and losing battery like crazy I'm on my third charge of the day and back at 50%. While stock I could go 6-8 hours without charges now maybe 2 -3
Sent from my Galaxy Nexus using Tapatalk 2 - 05-04-2012, 07:26 PM #2
Its because your phone is not sleeping. Get a app like better battery stats to see why your phone is awake so much..
Sent from my Galaxy Nexus using Tapatalk 2 - 05-04-2012, 11:36 PM
Thread Author #3
Thx I will give that a try.
Sent from my Galaxy Nexus using Tapatalk 2 - 05-06-2012, 12:31 PM #4
Re: Flashed liquid now battery drains ?
Just curious to see if anything changed for you in here. BetterBattery Stats is great recommendation but I would also download CPU spy from the market just to see what % of load the CPU during the time you get the large drains.
[GUIDE] Unlock Your Note 2 Bootloader! | [ROM] AOKP Jelly Bean for Verizon GS3
[GUIDE] VZW ROM Listing and Guide | [GUIDE] VZW Galaxy S3 Flashing Guide
[GUIDE]Freezing GS3 Bloat with Titanium Backup! | [GUIDE] Restore Back to Clean Factory Stock Updated 9/22
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 05-07-2012, 08:44 PM #5
- 05-08-2012, 08:39 AM #6
- 05-08-2012, 09:33 AM #7
I've used them all I think and I prefer badass battery monitor for checking what's causing wakelocks. That's definitely OP's problem, you can see you have a ton of awake time in your intervals where the screen is off for long periods, so something you have installed is running amuck in your system.
- 05-08-2012, 11:44 AM
Thread Author #8
Thx all. I switched to gummy from and getting about 6 hours with 4g off. I need to try a new sim card. I appreciate the help. I may switch back to liquid one day.
Sent from my Galaxy Nexus using Tapatalk 2 - 05-08-2012, 12:05 PM #9
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 05-08-2012, 03:29 PM
Thread Author #10
I just installed bad *** battery this morning. I dunno if that regulates or just monitors but I'm at 5.5 hours at 50% I can live with that bit I'm also on wifi. I'll post a pic very soon of battery stats
Sent from my Galaxy Nexus using Tapatalk 2 - 05-08-2012, 03:32 PM
Thread Author #11
I don't want to swap for a razor maxx but it has crossed my mind but that thing is ugly. My main issue is #1 4g data drop but I will be trying a new sim card this week. #2 YouTube always buffers never did it on my tbolt. #3 the battery drain that I can live with coming from a bolt. I also have the 2100 battery which helped.
Also I appreciate everyone's help
Sent from my Galaxy Nexus using Tapatalk 2Last edited by thirsty1258; 05-08-2012 at 03:43 PM.
- 05-08-2012, 06:45 PM #12
What Kernel are you using? One that came with Liquid? Also, what version of Liquid are you running? 1.35? Your Kernel should not be eating up as much as it is, my app usage generally is dominated by Android System after Screen. Kernel should not be taking up that much battery.
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 05-08-2012, 07:26 PM
Thread Author #13
- 05-08-2012, 07:47 PM #14
- 05-08-2012, 11:00 PM #15
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 05-08-2012, 11:26 PM
Thread Author #16
Jeez is there a link for Franco. Or do you use the app
Sent from my Galaxy Nexus using Tapatalk 2 - 05-09-2012, 06:21 AM #17
I use the app, just quicker and easier. If you want the 192 CPU clock setting you need to download the nightlies for that since Milestone 3 still does not have that setting. I would not recommend doing the auto-flash feature, I would just download the zip and boot into recovery and flash it yourself.
I know its a lot of work to get your phone working right when you find a bug but trust me, its worth it. I have been "tinkering" with my device to get it just the way I want it and I love this device even more!
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3!Thanked by: - 05-09-2012, 09:14 AM
Thread Author #18
Oh yeah btw I meant jeez cuz you guys are getting crazy battery life. I will tryout the Franco app. I'm familiar flashing zips with recovery somewhat but never messed with a kernel. I will update you all cuz last I checked my kernel was up to 25% consumption !!
Sent from my Galaxy Nexus using Tapatalk 2 - 05-09-2012, 10:01 AM
Thread Author #19
OK I have Franco milestone 3 running. Kernel consumption dropped to 3%. Question about governor. It is set to interactive would I get better life on hot plug or on demand ? Also looks like my data drop may have improved to early to tell.
Sent from my Galaxy Nexus using Tapatalk 2 - 05-09-2012, 10:38 AM #20
For best battery life either use Conservative, Hot Plug or Lazy. Ill give you a quick explanation to the best of my ability...
Conservative should theoretically give you the best battery life since it will scale the power based on load and will do its best not to give too much juice to the CPU. Hot Plug I believe works on the same scale as Lazy but it will keep one of the CPU cores asleep while it is not needed (not to be confused with Hot Plug Setting in the next tab of the app that will disable a core when the screen is off). Lazy is just another governor that I like that is a good balance between conservative and something like Interactive.
I currently am using Interactive since I have nightly 158 that gives me the option to have the cpu speed of 192 which is underclocked.
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3!Thanked by: - 05-09-2012, 11:10 AM
Thread Author #21
OK thanks. I've been messing with it. Screen on a lot and I'm down to 69% in an hour with 4g on. I'll try out those governors. I really appreciate you taking the time to help.
Sent from my Galaxy Nexus using Tapatalk 2 - 05-09-2012, 11:22 AM #22
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 05-10-2012, 09:25 PM
Thread Author #23
11 hours and 30% axiom from Franco kernel awesome
Sent from my Galaxy Nexus using Tapatalk 2 - 05-10-2012, 10:31 PM #24
Very nice. Franco kernels make a huge difference and ROMs do too. Just got to keep tinkering until u find a happy medium.
Edit Here are some of my newest battery stats running AOKP B35 with franco 158. Not bad for the screen time, while I was expecting a little bit better I think that it also had to do with that a good chunk of the time the screen was on (about 10-15%) it was on bright, not dark.
Sent from my Minty Green AOKP Galaxy Nexus.Last edited by creccaj1; 05-11-2012 at 07:35 AM.
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 05-11-2012, 07:46 AM
Thread Author #25
That's sick I'm turning my email sync down to half hour and I'm going to have Facebook update less hopefully get a few more hours out if it.
Reply
