Results 1 to 8 of 8
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Vitreous,JellyBelly,OEM
    Default Stock nexus DPI
    What's the stock dpi setting? I normally have mine set at 270 but I can't get certain apps to be "compatible" within the play store. I tried to restore to 320 to try and get what I need then revert but I'm not having any luck. I cleared data in the play store already as well. Any help is appreciated. Thanks. :thumbup::beer:
    Dropped from LiquidNexus1.35 via Xparent Tapatalk2
    ***GET IN WHERE YOU FIT IN***
    Snitches get stitches
    Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
    Living Dead-iPad3,GalaxyNexus,Razr MaxxHD
  2. #2
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Stock density is 320.. Changing it back should resolve the market incompatibilities. Maybe right after you change it back reboot, clear market cache and data then immediately reboot to recovery and wipe cache and dalvik..? That's what I'd try next..
    Thanked by:
  3. #3
    Default
    I use LCD density moder to fix market compatibility(:
    Thundercats Are Go!
    Thanked by:
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default
    Quote Originally Posted by sgtcuddlekitten View Post
    Thundercats Are Go!
    Google play app? Can you link me?
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default
    Thanks for nothin. Found it myself. Not really worth $2.99 though for the pro version.
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default
    Got this figured out without having to pay for the app. I had to update almost all if my apps.
  7. #7
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    Quote Originally Posted by sicario666 View Post
    Hit me up fool
    I'm the ROOT man
    G Talk: Upstreammiami3o5
    Let me help you ROOT your phone
    Thanked by:
  8. Thread Author  Thread Author    #8
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,350 Global Posts
    ROM
    Default
    Quote Originally Posted by Upstreammiami View Post
    Hit me up fool
    Lol. Its all thanks to you bro!
