Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Like Tree12Likes
  1. #26
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: Galaxy Nexus 4.0.4 root help
    Quote Originally Posted by Steve Hall View Post
    Okay . . . as I showed above, that's not quite the filename I have, but I assume I use the filename I downloaded? (And I can go be sure I get the actual CW Touch img, too.)
    Yes. Just substitute your file name for that.
    Thanked by 2:
  2. #27
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Yup whatever the cwm img is called
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  3. #28
    Thumbs up Re: Galaxy Nexus 4.0.4 root help
    Quote Originally Posted by zero neck View Post
    cd desktop
    cd adb-fastboot
    ./fastboot boot recovery clockworkwhatever5.5.0.whatever.zip
    that should get you into recovery temporarily, then you flash the su zip on the phone thru recovery, then you reboot system now, unplug the phone when it starts back up (not in fastboot mode! regular mode) - and from there you should be able to download rom manager and just flash cwm the easy way.
    good luck!!!
    Finally home and FINALLY getting around to fixing this. Turns out you had an extra 'recovery' in the fastboot command line; once I got rid of that, voila! So now I'm well on the way to getting CM9 installed.
    Thanks again for the help—couldn't have done it without you!
    zero neck likes this.
  4. #29
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Awesome. Time to flash roms???
    Steve Hall likes this.
  5. #30
    Yup yup . . . just rooted via Superboot; going to flash CM9. Have CM7 on my Nook Color, so I'm comfortable with it. Any other suggestions for ROMs to check out?
    And I can do that completely from CW Rom Manager, right?
  6. #31
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    You can do it thru rom manager but I never do. I dl the file from goo.im or a rootz thread, place in downloads folder, and flash thru recovery mode.
    I like aokp and when I'm feeling a change lately its been paranoid android. Cm9 is heating up tho. I was a big fan of cm7 on my incredible.
    Thanked by:
  7. #32
    **sigh** Okay . . . have flashed CWM Recovery, both regular and Touch (Touch is awesome, btw), and SuperUser 4.0.4. Several times. Problem is, as soon as I try to reboot into recovery, I get the dead Android with the red triangle. I thought SU404 was supposed to fix that, by overwriting the VZW file that keeps wiping out root? And even with root inspectors, I can't change the filename or delete the file, because it's read-only.
    Enough for today, but I'll try again tomorrow. (I really think the 4.0.4 OTA from Verizon, with my bootloader unlocked, has something to do with this, but not really able to think clearly about it now.)
    So any suggestions are welcome.
    Thanked by:
    bjs188
  8. #33
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    You have root access (to apps, like rom manager), right?
    you need to reflash recovery every time you want to boot into it, if you are stock and havent overwritten the stock recovery file manually - once you reflash recovery (thru rom manager or fast boot whichever you prefer) you should be able to boot into it. then, once you've flashed a rom, you won't have to keep doing that - it'll work without reflashing recovery.
    just make sure when you flash the rom, wipe data, cache partition, and dalvik cache when you go from stock to a custom rom.
    gl!
    Thanked by 2:
    bjs188 and Steve Hall like this.
  9. #34
    gl!
    Bingo! Going straight to Recovery after flashing CWM was the secret. Dunno why I didn't do that before, but I'm now running CM9. (It was the only one I had on the phone, and I didn't want to screw around with trying to find something else!)
    BTW, I couldn't find AOKP at goo.im, but I think I have a link for it elsewhere.
    Thanks again for all the help—and the patience! Hard to believe I had an easier time flashing CM7 to my DroidX! Guess I am getting older.
  10. #35
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    np, if you search goo for aokp it will always bring up the latest version. it can be a pain locating it otherwise
  11. #36
    greyhd's Avatar
    Posts
    Global Posts
    619 Global Posts
    I downloaded Wug's toolkit, can I use it to unlock and root my Nexus phone running 4.0.4 or will I need to download the new su file from the links provided? TIA
  12. #37
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by greyhd View Post
    Wugs has it I think just select that you are rooting 404 stock
    Thanked by:
    greyhd
